Question about Gateway FPD1775W Monitor
My monitor light comes on but there is no signal.
My monitor light comes on but there is the screen display no signal it then the screen blacks out..
    President:
  • 2,923 Answers
Isolate the problem. Connect the problem monitor into different computer. If the problem monitor worked on another computer, try connecting a CRT monitor to the problem computer. Once the display comes back, change the screen resolution.
Posted on Jul 29, 2009
SOURCE: I turn my monitor on and it displays BENQ and then goes to -No Signal Detected- Power light changes to orange..help?
IT MUST BE A DPI.IF UPPER THAN 60Hz THE PROBLEM WILL BE OCCUR AGAIN.I THINK
Posted on Oct 04, 2007
Fix-4U
  • 293 Answers
SOURCE: black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Posted on Sep 08, 2008
SOURCE: 713N samsung monitor; No display
Necesito Manual de servicio, con todos planos y circuitos, defectología
Posted on Sep 04, 2009
  • 788 Answers
SOURCE: monitor starts then goes off, no signal
I would check the LCD against another monitor. It does not have to be a LCD, a regular monitor will do.
This will tell you 2 things, 1. The Video card is good or bad, 2. The Cable is sendinf a good signal.
If when you startup the monitor, you see a display and then after a few seconds it display's a no signal message, this is consistant with a Bad cable or cable ends. or Bad VGA card from computer.
Hope this helps. Good luck..
P.S. If you have move the PC, you may want to open the unit, and re-seat the Card. If the card is not making a solid connect on the board, it will display these syptoms.
Posted on Sep 12, 2009
  • 23 Answers
SOURCE: Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Posted on Oct 28, 2009
When I connect my monitor to my lab top the green power light comes on then turns orange and I get "no signal" message on the monitor
you may need to tell the lap top to display from that screen the new screen has no image or signal so goes to sleep to save power.on your lap top try the (FN) key on your laptop then select a blue picture on the keyboad of to squears one black one blue this will alter the display.OR in windows look at Start>controal pannel>display
Jun 03, 2010 | Sharp LL-173C-B (Black) 17" LCD Monitor
Display will not come up, screen remains black, blue light on front of monitor flashes on and off
Check that the monitor is still receiving a signal it could have gone into standby mode.
If not you either have a faulty inverter or the back light has gone, to test this when your computer is on is to check you can still see a faint image on the screen that means the backlight has gone, if not its the inverter.
Jan 22, 2010 | Gateway FPD1975W 19" LCD Monitor
After starting the computer the screen is black and only displays digital analog on screen and the blue light is flashing. It then displays a box say "check signal digital analog." please help me. Thanx.
This blue light flashing means there is power to monitor bu NO video signal. No Analog or digital Video . analog is the regular plug for PC to Monitor, the other is HDMI digital or other digital. Check signal digital/analog means again: No video signal from PC detected.
Daddy
Dec 02, 2009 | Samsung Syncmaster 940BW LCD Monitor
Monitor screen begins as computer is booting up and then screen goes black. Message says there is no signal.
If the power light dims or changes color after the no signal message comes up, that means the monitor went to sleep.
While the monitor is plugged in and on and the computer is also on, Try unplugging the VGA cable from the monitor. wait 30 seconds and then plug it back in o see if the power button light comes back to normal color and the screen flashes on.
If not, then the monitor is not getting a signal from the computer.
If using a desktop computer,Try a different cord or try the monitor on another computer.
If using a laptop, you need to activate the laptop to use an external monitor. That can be done through the display settings, OR, most laptops have a shortcut key feature which usually involves pushing the Fn key and one of the F keys at the same time. The F key may say CRT/lcd or have a picture of a monitor and a screen.
If the power light does light back up and still no picture, There may be an internal issue on the monitor
Nov 17, 2009 | ViewSonic VG2230WM LCD Monitor
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
Screen saver displaying unwanted message
This happens on monitors with a sleep type function. Make sure that the sleep mode is turned off and that it is set to never turn off inside of windows. Then the no signal error should not come on again.
Sep 07, 2009 | Computers & Internet
Monitor comes up shows "acer" then says no signal and goes black
This Problem is Acer(s) Monitors. Though it is a nuisance one fix That has work for many is the Unplugging after it goes back to Good (viewable) screen.
I have hooked mine up to an inexpensive Power strip to make it easier for me and just turn off at time indicated above and Viola Simple is as Simple does :)
Apr 24, 2009 | Acer X241Wsd Monitor
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Gateway FPD1775W Monitor Logo
313 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
