Question about Belkin USB Hub
Seems like my belkin usb travel hub doesnt have enough power to run mouse and verizon pc card can this be possible, neither will stay working
  • Belkin Master
  • 32,281 Answers
The hub draws it power from the computer and cannot deliver enough power for the devices connected to the hub.
Does the Belkin hub have a power socket? If so get a power adapter for it. If this isn't available then purchase a powered USB hub to use with the computer.
Posted on Jul 30, 2009
I purchased a Belkin 4 port USB hub today and connected my Seagate external hard drive. Unfortunately my computer, Toshiba Satellite L655D, doesn't recognise the hard drive when located within the...
This is likely due to power consumption, if a hub doesn't have it's own power adapter, then it is drawing bus power from your computer, and will not have enough power to drive larger devices.
May 07, 2011 | Belkin Electronics - Others
Will not power my usb devices. seems as if there's not enough power getting to the hub
Small travel hubs use power from the Notebook's USB port, the issue you are experiencing is "most likely" caused by there not being sufficient power output to allow all devices to run successfully - the following devices should be connected directly to the notebook:
* External hard drives
* Printers
If the issue occurs with Mouse, USB Key / Dongle Drives, Keyboard then the issue is either a faulty peripheral ( the mouse/ Key etc) of with the Dongle itself.
May 03, 2011 | Targus 4PORT USB 20 TRAVEL HUB ACH7405US...
Usb drive not recognised
First of all THe Belkin F5u237 is not a USB Drive. It is a USB Hub. If your running Windows XP it should see any device connected to the hub. If it dosen't see anything connected you may need to add the power supply to the hub.
Dec 14, 2010 | Belkin (F5U237) 7-Port USB Hub
My both usb ports r not wrking n hangs when eithr card reader or pen drive is inserted bt works well when tata photon usb port or mouse port or key board port is inserted ?model- EMACHINES E275
Sounds like your laptop's USB ports are not capable of providing enough power to operate your card reader or pen drive. I suggest you buy an active USB hub (one with external power source, rather than the one which draws power from the laptop's USB port), & attach your card reader and/or pen drive to that USB hub.
Nov 28, 2010 | Acer Computers & Internet
When i plug my usb mouse or the webcam on my new motherboard my PC does not open,.while the ps2 mouse it works,.moments ago i restart the PC and it has a message POWER SURGE ON HUB PORT!!.HOW can i solve...
you are connecting your mous mous or web cam through a usb hub which is not having power to run the device instead you should attach a device directly to the system or use a hi speed usb 2.0 hub
Sep 16, 2009 | XFX GeForce 6200 Graphic Card
One day the Belkin 7 port hub works the next day it doesn't
Your problems with the Belkin 7 port are not due to the Dell computer or the XP OS. To problem solve, select on USB port and stay with it, not the 2 top ports for your keyboard and mouse. 1. Plug in the power adapter, wiggle it about, widen the prongs, change outlets at the 120 v. end. 2. Use an simple hand magnifier and peer closely at the DC input plug and be positive that the center post and the minue side piece of metal if in firm constact with the plug. If cannot insure a firm fit, sligtly bend that tiny metal piece towards center. Option 2, use another adaptor with the precise voltage as the original and the idential pin that inserts into the module. 3. Use another or new USB connector.
This list does not imply a specific order of diagnosis. Your fundamental problem is the failure to delive DC power to the Belkin hub or to capture the hub to USB port signal. In a phrase, you gotta short somewhere.not an issue with the computer or the XP operating system. Bill Miller
Aug 25, 2009 | Belkin (F5U237) 7-Port USB Hub
Wireless hub
I had the problem that,even though the hdd connected it would fail after a period of time (video streaming or file transfers). Set up was Samsung Q45 running wireless g connected to a belkin draft N Router. 3 other PCs (all g) using 2 different OS (Vista and Mac) had same problem.
Solution after months of searching, problem solved. Fitted Draft n PCMCIA card, and to ensure it was running at 300Mb had to use WPA PSK + WPA2 PSK security mode . Now works brilliantly and has managed to stream a full HD movie!! The Wireless link is now running faster 10Mbs compared with 4Mbs on g, although not fast it at least enables the HHD to be used in a stable configuration. Problem seems to be that the unit will not work properly unless wireless n link is used.
May 18, 2009 | Belkin Wireless USB Hub
I-rocks IR-4300 4-Port USB Hub doesnt work
You shouldn't need a driver for it, Windows has bundled native drivers that will be enough to make it work.
Does anything else work in the port you plug the hub into?
Jul 11, 2008 | i-rocks IR-4300 4-Port USB Hub
Not sure
Every plug and play devices are compatible with Vista.Vista have a huge range of drivers under its hood.So there is no doubt on that belkin usb 2.0 lighted travel hub is compatable with windows vista
Oct 21, 2007 | Belkin (B5U034) 4-Port USB Hub
Belkin N1 Wireless Adaptor not connecting on PC
what the adviser meant was your pc cannot provide enough power to the usb port to power the unit, assuming you have tried other ports and it still wont work; you will need to either purchase a pci usb 2.0 card adapter or purchase a mains powered usb hub and connect to this instead.
Sep 15, 2007 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin USB Hub Logo
257 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
