SOURCE: Need a radio code for
Keep in mind that the "radio code" is one unique security code for each vehicle devices, so, Chrysler/Jeep codes are virtually impossible to be obtained for free from anywhere on the Internet.
Generally this code is in the last pages of the owners manual or in a label located in side of radio (will need take off t check). In additiona,
for the correct code you can try seek further advice here... CLICK HERE
Finally, I suggest visit your Jeep dealer and, with your VIN number and radio serial ask about this information, sometimes they send this data for free, JUST SOMETIMES.
Hope this helps.
SOURCE: hi my jeep went into
You can get the code at your local dealer. You will need your VIN#. It will cost a little, but is worth getting the right code.
Testimonial: "thanks for that..will ring them in the morning cheers chris"
SOURCE: C-3423
The error code means there is some thing wrong the fixing unit. I believe it for to many paper jams in the fixing unit. Remove all of the paper jams and to rest it > Turn the Main power Off and when turning the copier back ON, press and hold the utillity button till the screen changes and the Trouble rest show on the display screen. Press the "OK" and let it do it's thing & then turn it off and back ON. Good Luck
