Question about Fujitsu Siemens Celsius 460 (LKN:FKR-547310-032) PC Desktop
No signal on the screen
Dear Sir or Madam, i am having a serious problem with the my computer. when you try to put it on the power light comes on alright but there is no signal on the screen. please kindly help me with the possible courses of this computer problem. please e-mail me with this e-mail "" thanks.
    Problem Solver:
  • 6 Answers
Re: No signal on the screen
Did you check if you connected the singal cable properly? If the signal cable drops, you can reconnect it again and see if it works
Posted on Nov 24, 2007
0 characters
3 Points
Sir why a power supply become fuses and blast when computer vga and power cable is put in the cpu?
You have a serious electrical short in your computer which causes the fuse to blow.
Depending upon how old your computer is, it may not be worth repairing and in this case I suggest you put your money towards a new computer or laptop.
Aug 31, 2011 | PC Desktops
I plugged in my tower and i heard a loud high pitch beeping sound the green led light in the back was on but the power button turns green and the green led light in the back turned off there is no signal...
the green led light is it beside the network cable connector. if it is so, then it is always meant to be like that when you power up your computer. it is not something serious and it is normal.
Aug 18, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Dear sir display is not coming little beep is coming from motherboard i have checked rams, power supply also try only single motherboard for display but vain
plz try by removing the mother board and put a paper below it and try to boot ( connect all the cables). if the problem is there then your motherboard is having problem.
Aug 10, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Compaq D5S computer no signal to monitor
Have you tried putting your video-card into another socket(if possible), or just plugging it out and back? If you have, you might have some more serious problems with your hardware. It would be satisfying if you could hear the winchester booting up windows (and seeing the HDD led flashing while the OS starts). That way you'd know that there are no serious problems with the motherboard, and the source of the problem is the video card. Otherwise, if you see no sign of serious winchester activity that could men that your motherboard is dead. If you are lucky, replacing the ram modules will call your machine back to life.
Dec 08, 2009 | HP Compaq EVO D5S PC Desktop
Blank Screen when turning my laptop on
dear sir,
it doesn't matter how old your laptop is..matter is in laptop their are two type of IC (integrated circuit) horizontal and vertical. i am sure one of your ic ge damaged due to power failure so just check it at the near by shop.
regards golu_fixya (guru)
Jul 04, 2009 | Fujitsu Siemens SCENIC P300 PC Desktop
When put power cable in orange light comes on power button and wont boot up
Orange light usually comes only if your system stays in low power mode or sleeps, So u get orange light immediately when u switch on the system, try pressing the ESC Key on the top left corner of the Keyboard, and if not try pressing the power button again...
If not working,tell me Whether do u get any sounds in system?
Your system Operationg System?
And What u get on the screen, when u switch on?
Thanks, Regards
Jun 29, 2009 | Dell GX270 P4-2.8 512/40/24X/XPP/NONE...
What does blinking green light mean on power button of Xerox monitor? The screen no longer comes on.
Could be 1 of 2 things - Either the computer is not sending a signal to the monitor or the monitor is not responding to the signal. Try plugging another monitor into the computer, if it comes on then the monitor needs repair
Dec 30, 2008 | PC Desktops
When I power on the computer, the monitor comes on a nano second, then goes black
Dear sir/madam,
it is the common issue related on inverter board. we have to do something in that board. contact your support engineer for monitor, if you are not able to find that. because it is related on electrolytic capacitor.
thank you
Aug 28, 2008 | HP PC Desktops
My keyboard won't work at all
Dear sir/madam,
please do the following tips to solve:
1. checkout the cable connection between your keyboard panel and port on your computer.
2. checkout the keyboard port, whether its working or damaged (check the keyboard cable connection's pin also)
3.checkout the post settings of computer with keyboard (commonly, keyboard light would blinking on and off at the time of computer boots)
4. if the post will be come properly, then you have to view the keyboard settings in the control panel of operating system.
5. commonly, keyboard issue comes with in the above instructions only. if its not working, you keyboard cable will be damaged or the keyboard have a problem related with in.
here, you can only change the keyboard.
thank you,
Aug 23, 2008 | Compaq PC Desktops
I have got a computer game and read the instruction to install it but it comes up and says that it runs in unsual way and then quits
Dear sir/madam,
you have to follow the minimum requirementsof the game, as well as software and hardware requirements.
most of the time, it quits due to screeen resolutions,directx software status, and memory management
please check out the above things, to overcome this issue.
you can reinstall the directx and setup the screeen resolutions and game screen settings properly as per the game instructions.
thank you,
Aug 23, 2008 | PC Desktops
Fujitsu Siemens Celsius 460 (LKN:FKR-547310-032) PC Desktop Logo
214 people viewed this question
Top Fujitsu PC Desktops Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you a Fujitsu PC Desktop Expert? Answer questions, earn points and help others
