Ryobi 43cc brush cutter
SOURCE: Muculloch brush cutter wont start. No spark.
If you have correctly diagnosed the problem as no spark, you will need to replace the ignition module. Unfortunately McCulloch dealers and McCulloch parts are very hard to find these days. If yoou do not have a dealer in yoour are who has the part you need, contact southern supply company at 205-833-2525 or email them at [email protected] and I feel sure Jason or someone there can help you.
SOURCE: Ryobi bush cutter, what is the spark plug gap
Use a wire plug gauge or disk and Set at 0025,
SOURCE: I have no spark on my Ryobi Brush Cutter.
If the spark plug you have put in has the correct gap then u will next have to check or change the HT lead Change it if no spark is showing
SOURCE: my ryobi s430 starts well
Common problem is the fuel pump. It is a small diaphragm in the carburetor. The diaphragm deteriorates, especially with the alcohol in the gas now. You might rebuild the carb. The kits are about $20. Other problems include clogged fuel tank vent, clogged fuel filter (on the end of fuel finder hose in the tank, and clogged fuel jets which is less common.
