Question about Hoover S3765-040 WindTunnel Bagless Canister Vacuum
Windtunnel belt I have a new Hoover Windtunnel canister. The belt keeps coming off. It happened a couple weeks ago (several times after putting the belt back on) so I assumed I might need a new belt as it might have dried out at the store. I ordered new belts and today I used it for about an hour and the belt came off again, twice. There doesn't seem to be anything to hold the belt on the stem as it seems to slip off. I have tried it centered, to the left and to the right....can you help. I am very frustrated and about 300 miles from the store where I purchased it! I read the suggestion to put a smaller belt on it but it is already pretty small. What # might that be? It doesn't seem to have worked for the others. Thanks.
I've successfully used a compatible belt - Royal 104425001 .It's still new, but for the time being at least - it works.
Posted on Dec 21, 2009
2 Suggested Answers
ThinkVacuums
  • 144 Answers
SOURCE: need help with Hoover S3765-040 WindTunnel
The belt could be stretched and that could be causing the slip. Or you could have the wrong belt if you've replaced it recently
Posted on Sep 04, 2009
Hoover Windtunnel Bagged upright vacuum is smoking and belt is slitting and burning
you probably need to replace your brushroll seeing that your belt is burning means motor is turning. first check you brushroll and see if there is an obstruction keeping it from spinning if its not spinning freely replace
Jan 16, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover windtunnel t series belt is loose- roller brush doesnt turn. Its brand new belt is slipping. we bough new belts and putthem on same problem. Can not find solutio in manual. Is the belt supposed to...
I also have a loose belt and have bought additional belts but have the same problem. I put the it around the metal rotor and around the brush roller a shown by he Hoover video, and it is loose.
Nov 28, 2010 | Hoover S3765-040 WindTunnel Bagless...
HI, my motorized brush barely turns.It makes a hot rubber smell. I took apart and noticed the spindle the belt turns on discolored from heat. Cleaned it, but still no turning of the brush.The vac is a...
That means that the belt is stretched and it is slipping on the motor shaft, that is why it is hot and smells like burning rubber. You need to replace the belt. Here is the correct belt you need:
Hoover Windtunnel Canister Belt
Dec 24, 2009 | Hoover S3765-040 WindTunnel Bagless...
The belt keeps on slipping off causing the brushes to stop
Over time the belt stretches and gets to big to stay put all of the time. Get a new Hoover belt and install it. That will solve your problem
Jun 16, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Hoover Windtunnel - the belt keeps coming off & it is the correct
One compatible belt that I use and works (at least while its new) is Royal 104425001. Try that.
Mar 01, 2009 | Hoover S3765-040 WindTunnel Bagless...
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
HOOVER WINDTUNNEL VACUUM MODEL U6454-900 BELT KEEPS COMING OFF
Have you put on a new belt or just keep using the old one. If you haven't replaced it in the last 6 months, then it has stretched to the point where it won't stay on. Another cause is catching throw rugs, towels or something that gets in there and knocks the belt off.
May 31, 2008 | Hoover Vacuums
Hoover S3765-040 WindTunnel Bagless Canister Vacuum Logo
169 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
