Question about GE JVM1650 1000 Watts Microwave Oven
My GE 1650 stopped heating. What can be the problem? Would it be cheaper to fix it or replace it?
  • 5,911 Answers
The microwave oven high voltage network is what generates the microwaves that heat your food. It is usually comprised of these four basic components:
1. Magnetron (WB27X10429)
2. HV transformer (WB27X10254)
3. HV Diode (WB27X1160)
4. HV Capacitor (WB27X10240)
In most cases these heat related problems are caused by a bad magentron. The magnetron is the main component of your high voltage network, and it is also one of the most expensive parts. Worst case scenario, you're looking at $110.
Now, YOUR microwave oven also has a thermal cut-out (TCO) on the magnetron (part number WB27X10166). It is designed to protect the magnetron and other internal components from an overheat condition by blowing like a fuse. It could be that your TCO is blown. A resistance check with the component removed should read zero ohms if good. Best case scenario if this part is bad is about $21 to replace.
You can view an exploded view diagram of your microwave oven at pcappliancerepair.com. I have already given you all the part numbers. The magnetron is listed as item 73. The TCO is item 77. I'm not guaranteeing these to be the cause of your problem, but I will tell you these parts fail the majority of the time.
So...I've given you some options to consider. I'm not sure how much a new microwave will cost, but it may be worth your while to repair this one (especially if the TCO is the only problem).
If you have any questions, please let me know. I hope this helps you.
Posted on Jul 29, 2009
My GE over the oven microwave does not heat (1.5 years old). The heating and turntable stopped working at the same time. When you start it, it sounds fine, but nothing heats. You can hear a relay or...
It does sound like a relay malfunction or similar switch. Could be repaired but call for a quote or better yet, take it to a repair depot (probably cheaper).
Dec 13, 2014 | GE Microwave Ovens
Ge jvm1850sm2ss suddenly does not heat food any longer
time for a new one... new ones are cheaper then the parts
Apr 08, 2014 | Microwave Ovens
GE 1650 microwave quit working after heating multiple pitchers of water for 3 mins. Has done this before same situation But started working few hours later. Possibly "humidity sensor "- fried - need
Too much vapor has fried the computer in it, you have to replace the microwave, part, or continue using it waiting for it to work over and over
Nov 24, 2012 | Microwave Ovens
My microwave stop heating what could it be is it worth fixing
The magnetron is gone, or the inverter board, "if 7 years old or less" To answer your question, not worth fixing, cheaper to buy.
Apr 28, 2012 | GE Microwave Ovens
My jvm1540 microwave runs fine but just stopped heating. Only 1 year old. Help.
If your micro looks like it is running and you get no heat than it is your magnitron tube. This is the most expensive part of the micro, if it is in warranty GE will fix it, if not it will be cheaper to replace it.
Jul 08, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave not heating
The Magnetron has stopped working in this case and, you will need a replacement Magnetron heating device. this will fix your heating issue.
Replace the Magnetron. Runs about a 160.00 or maybe cheaper in most cases.
May 30, 2009 | GE Microwave Ovens
JVM141G001 Spacesaver microwave; fan and heat not working
The average cost of a over the range microwave is around $550. You would have to call around or go visit an appliance store or a place like HOME DEPOT or LOWE'S to get a price quote on replacement parts. If it is cheaper, FIX IT. Good luck.
May 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped heating
The magnatron capaciter is burnt out (this is what heats the food!) it can be replaced but it may be cheaper to buy a new oneYjis should fix ya!
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Built-in Microwave (JE1540w002) NO Heat and turntable not moving.
locate the diagram and check you monitor switch it is one of your door switches
Feb 15, 2008 | GE JE1540 Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
344 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
