FixYa.com
Tags:
M&S Systems AirVac AVP1200 Platinum Series Central Vac - 12,000 sq ft Bagged Central System Vacuum
Central vacuum not sucking (by 2 users)
posted by mrsspronk on Nov 23, 2007
Hi, for no apparent reason our central vacuum has not suction at all when we insert the hose into the suction hole. We've cleaned the filter and emptied the bag. The little white breaker switch won't stay in. Can you help?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jan 04, 2008
i have a beam ducted vacuum system and it is not sucking at all. i have emptied the bin, I do not know what else to do.
Solution #1
posted on Feb 05, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 88%, 1090 votes
Usually when there is no suction, and the main unit is running, then either the hose or somewhere in the piping there is a clog. If you move the hose to another location, is there suction? If not then the hose is clogged. You can unhook the pipe at the unit, flip the switch to manual, if it comes on and there is suction there, then there is a clog in the piping, If in the piping, tear up small strips of paper and mark them by number and insert one in each inlet, run the unit on manual to suck them up, and which ever numbered strip isn't there in the bucket, then that is the inlet that is clogged.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Vacuums problems?
Vacuums
do you take the filter
do you take the filter out of a... Answer This...
Vacuums
Get fan off a Kirby
Get fan off a Kirby Class III. Answer This...
Vacuums
Dyson dc16 handheld vacuum...
Dyson dc16 handheld vacuum... Answer This...
Vacuums
does not work - how
does not work - how would I... Answer This...
M&S Systems AirVac AVP1200 Platinum Series...
central vac
our central vac will not work... Answer This...
Repair Service
Find Vacuum Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
