Question about Dell Latitude D600 Notebook
My dell latitude d600 won't recognize the AC power adapter and doesn't show that the battery (which is new) is charging. I had to leave it plugged in for about a week when I put in the new battery before it would even turn on at all. It will not operate unless it is plugged in to wall, but the battery is not recharging. Can you help?
  • 57 Answers
There was a class action suite against Dell for this problem with this model laptop due to overheating and destroying the power supply. Browse the web for more information. I have one and it is a parts machine now.
Posted on Jul 29, 2009
Dell m5110 laptop won't charge new battery and ac adapter is not recognized in bios
Try another AC cord/charger with the EXACT same specs as original. Is the battery a genuine Dell battery, if not return it? Some aftermarket laptop batteries don't play well with your computer, the pin-out connections aren't correct and MAY be a fire hazard.
Apr 06, 2013 | Dell Inspiron Computers & Internet
Dell latitude runs but does not boot up
Remove battery + power cord from AC adapter. Wait 10 minutes. Plug in only the power cord. Power-on the laptop.
If laptop starts correctly, plug in battery while it is up using the adapter. Leave on for battery to recharge.
Oct 19, 2011 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
My Dell D 600 will not charge the battery and a message appears at start up that says Ac adapter not recognized What do I need to do to get my computer to charge the battery
If the AC adapter is not recognized by the system, the battery charger circuit is disabled. Things you can check:
  1. In the barrel of the connection to the computer, the small wire in the center is the sensing wire. If bent or broken, then the adapter will need to be replaced.
  2. If the pin is not bent or broken, try a different AC adapter (Any D-Series Dell adapter will work) IF that adapter works, replace the AC adapter.
  3. If a known good/new adapter doesn't resolve, then a motherboard needs replacement.
Jan 10, 2010 | Dell Latitude D600 Notebook
How do I chaarge the battery on my lap top
1. connect the ac adapter from a known good power source.
2. plugin the battery to the laptop.
3. check bios if batt is recognize or performing normally (to do this turn on laptop keep tapping f2 to boot to the bios options)
4. just leave the laptop with the ac adapter connected and it will charge laptop automatically, just leave it for about 4 hours.
Oct 13, 2009 | Dell Latitude D600 Notebook
Charger isnt recognized
Dell portables use a sensing wire in the barrel of the adapter plug to determine the wattage of the ac adapter. If that fine wire in the center of the plug is bent or broken, the system cannot ID the adapter and the battery charger is disabled.
SO, first try a known good AC adapter for a D-Series Dell (You might be able to check with Geek Squad at a local Best Buy if you don'e have access to another ac adapter) If a known good ac adapter works, then replace the ac adapter.
If a known good AC adapter does the same thing then the fault is in the charging circuit of the motherboard and the motherboard will need to be replaced.
Oct 03, 2009 | Dell Latitude D600 Notebook
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Dell latitude d600 blinking battery light
I would say its defective. Bring it back to where you bought it and show them. Bring your laptop charger also so you can show them it in action. Hope this helped.
Jan 04, 2009 | Dell Latitude D600 Notebook
Power Problem
This could ba caused by several things. First, a bad power supply. Second, a bad battery, try starting it without the battery. Third, a bad memory chip. And fourth, the power management chip on the motherboard. If it's not the battery, power supply, or memory chip, then it's the pm chip and the motherboard will have to be replaced.
Jun 25, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 won't accept charger
Had the same problem, My other Dell charger would work fine but the original one that came with this laptop would throw an error message that the Charger wasnt recognized. None of the suggestions on the forums worked.
I held the chord by the circular flex thing at the end, and pushed in the power pin with force into the laptop, held it for a few seconds and now it works fine. If you push the pin slow and gently into the laptop, it doesnt recognize the adapter. I think the problem is either with the power chord connections inside or with the adapter inside the laptop. Try it!
Apr 12, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 new battery won,t charge
the charger in the laptop is not functioning. pc will need repaired
Dec 28, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
391 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
