Question about RTO Cat Backhoe Tractor
The lift bucket on my 416c backhoe is having problems lifting up it only has problems lifting up things everything else works.
  • 3 more comments
  • pasilvage Jul 29, 2009
    everything is fine as far as that goes it seems to be bypasing the valve or its not geting enough fluid. the bucket tilts and goes down but will not lift up
    yes it is working correctly
    are you talking about a relief valve
  • pasilvage Jul 30, 2009
    we have had this valve apart and everything look good
    thank you so much we are going to try that and replace the valve and if we have any problems again is there a better way to contact you email me at pasilvage@hotmail.com
    President:
  • 1,723 Answers
This can be a bit difficult for you to diagnose. The hydraulics involved are not simple
and require a working knowledge of hydraulics and tools. There are a few things
to check. Look for any leaks from the cylinders. Look at the hydraulic hose lines going back
to the valve. Also look at the control stick to see if it's has full motion and tight to activate
control line to valve
Posted on Jul 29, 2009
  • 3 more comments
  • Craig Butler
    Craig Butler Jul 29, 2009
    is the control line activating from the lift lever correctly?
  • Craig Butler
    It sounds like the valve is not activating and opening hydraulic flow to the rams.
  • Craig Butler
    No, the main valve for the rams
  • Craig Butler
    Craig Butler Jul 30, 2009
    It may 'look' good but not be opening when it gets the hydraulic flow from the control line
  • Craig Butler
    There can be a very small amount of contamination that will stop it from 'spooling 'open.
Fiat tractor lift arms wont go down but will go up
back lift arms on 100-90 fiat will go op but will go down very slowly
Mar 24, 2014 | 70 HP 4WD Tractor w/ Front End Loader...
Finding hydraulic filter
i'm having problems with my ford 555b bcket stick . it want lift and lower in the right position. when i try lifting the front tires off the ground it hold until i let the stabilizer down.
May 05, 2012 | Ford 555 backhoe
We have a 200' deep well. The pump is not working and we cant pull the pump up. It has been sujested that we hook a backhoe onto the plastic pipe and wires lift up and pray. Before I do this are there...
I would try to tie off at the fittings and wire at well cap and lift carefully with backhoe a few feet. I would use double line of 1/4 well rope at least 1250 p.s.i. tensile strength. Lift for a few feet ,enough to get access to suction line and wire. Thentie off lines with double x knots and use electrical tape to make several wraps around pipe,ropes, and wire. Use a stainless steel gear clamp to secure everything in place.From that point lift carefully and as straight up as possible and repeat process.
Continue doing this and just go slow and steady. The main thing I would worry about is that depending what type of pipe and fittings were used is that fitting that is connected to pump will break. I know this is a slow process but I have done this several times with good success. If you tie off and secure with gear clamps every few feet and make sure you have the wiring hooked in tightly it will hold a lot of weight as the wire gauge should be at least 10.
Wishing you the best. Thank you.
Feb 24, 2011 | Home
The hydraulic steel line on my 2010C bucket loader broke and I dumped a good amount of fluid before shutting everything off. Replaced line and filled tank up, everything worked fine for about 1/2 hour,...
Like other hydraulic systems, there is probably a procedure for bleeding the lines after loss of most of the fluid. You may still have air trapped in the system and once it works its way to the cylinder, the cylinder is working with air instead of fluid and the air compresses instead of doing work.
Sep 16, 2010 | John Deere 420,1020,2010,2020,2510,2520...
RTO Cat Backhoe Tractor Logo
279 people viewed this question
Top RTO Toys Experts
The Scrivener
Pete Bruk
rostit
Are you a RTO Toy Expert? Answer questions, earn points and help others
