Question about Roper RAX4232KQ Top Load Washer
Water leaks on floor during pumpout
Have checked all hoses and the drain tube and find no leaks.
    New Friend:
  • 63 Answers
There may be a crack in the pump housing. I once found a paperclip in the pump housing that punctured a hole when it was propelled by the pump impeller.
Posted on Jul 29, 2009
Water leaking on floor of 2005 camry AC
Ok well had same problem. The drain hose is blocked and is backing up and coming out of top of drain plug and tube into the car so the tube hanging down in engine bay left side of motor may be blocked with mud dirt or something else so check it and with aircon on if the water is not dripping out of the drain tube then it is blocked
May 29, 2014 | 2003 Toyota Camry
Maytag washing machine model a 210 (1982) leaks above filler. how do i get into cabinet to check natureof/cause of leak?
see this cause and fix it:
During fill only
air/gap deformed or crack , replace see the diagram
the rubber tube run between water inlet valve and air gap can cause leak +inlet spout can be crack cause leak replace.
During drain and spin only
inspect main drain hose and fix it. steel or plastic outer rub can be rust,split if this happen you must replace the entire outer tub.
All the time
check the hot and cold hoses water tighting or replace
main tube seal leaking
pump defective leaking.replace
outer tube, split , rust, causing leak, replace
see the diagram
God bless you
7_19_2012_7_39_57_am.jpg7_19_2012_7_40_20_am.gif7_19_2012_7_40_43_am.gif7_19_2012_7_41_02_am.gif
Jul 18, 2012 | Maytag Washing Machines
Some water is leaking under the dishwasher and on the kitchen floor during the end of the wash cycle.
Does it leak during pump-out only?
If so , must be drain hose .To see everything,remove kick plate to isolate leak. Check hose connections. Fill and drain and observe.Or run a whole cycle with kick plate off to find leak.
Good luck
Aug 15, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
My machine is a 501 smartdrive and is not filling te bowl it is all going onto he floor instead
Hello there:
I will answer this in 2 seperate post's for you ok?
Your washer can develop several types of leaks. You can track down a leak based on when it occurs: During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Sep 26, 2010 | Fisher and Paykel Washing Machines
Freezer leaking water and freezing
you probably have a plug in the drain line that normally drains the water when your freezer goes into the defrost mode. at the base of the refrigerator there is a evaporative drain tray where the water drains from the freezer into the tray and evaporates during normal operation of the unit. You should be able to see the drain tube just above the tray. Attach a hose to it and use compressed air to blow through it and clear it out.
Mar 16, 2010 | Refrigerators
CA message, leaking water on floor, won't drain
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
CA Cl Average current limit Or Instantaneous current limit If a status signal comes back from the motor controller that a current limit has been breached, the unit will return to standby mode and display either CA for average current limit trip or Cl for instantaneous current limit trip.
Average current trip occurs if there is a 2 second average of current draw greater than 5.55 amps at the motor windings.
Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem.
May 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Dumps water on floor
During fill only
All the time
Apr 26, 2009 | GE WJSR2070B Top Load Washer
Bosch dishwater backed up/leaking
You may have upset the lower door gasket, a kind of "wiper" that keeps the water inside during wash/ Look for a wrinkel in it. Maybe push it down some. the track where it goes my be you can see and it will be self explaning. As for the water not draining.... A hose kinked, A pumpout drain valve not gettign power, I just had the same problem with mine and found a small piece of a plastic baggy in the pump sump covering part of the drain hole. And after that I had no drain and just squished the drain hose at the outlet. I suspect a buildup of grease or maybe some more plastic was inside the the outlet tube. Mine drains fine now. Look for these. And let me know please
Apr 05, 2009 | Bosch Dishwashers
Washing machine spilling water out on the floor
During fill only
All the time
Apr 03, 2009 | Whirlpool LSR5132PQ Top Load Washer
GE Top-loader Leaks Water from Vert Tube Behind Tub on X-Large Loads
During fill only
All the time
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 18, 2008 | GE WBB4500EWW Top Load Washer
Roper RAX4232KQ Top Load Washer Logo
101 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
