Question about SanDisk Sansa e250 MP3 Player
Will not charge, computer not detecting advice
  • 43 Answers
Press hold home up to 15 sec.
Posted on Jul 30, 2009
My Toshiba nb505 netbook run with the AC adapter, but will not run on the battery. The battery shows that it is charging but the charging percentage does not increase. Any advice?
I own the Toshiba NB505 netbook and the very same thing was happening to me. Here is what I did to fix my issue:
Step 1: Shut down the computer and remove the battery. Then turn it on but now with the battery out. It should say "battery not detected".
Step 2: Open control panel and open the "device manager". Under "batteries" (the first one), uninstall the one that says "Microsoft ACPI Compliant Control Method Battery". This is the battery driver.
(Don't worry. The computer will automatically re-install it)
Uninstall the driver and shut down the computer.
Then reinsert the battery and power on the computer. The driver should have re-installed itself. Check to see if the battery is now charging.
(It will take awhile for it to fully charge to 100% Best to shut it down and let it charge. The far left indicator light on the front of the Netbook will turn green when it is fully charged)
Hope this helps. Yeah I had to figure this one out on my own. Toshiba support staff over the phone were useless!
Good luck!!
Sep 24, 2012 | Toshiba Turquoise 10.1" NB505-N508TQ...
Dropped the hard drive, won't detect. How do I retrieve the files (mostly pictures)?
Bring it to a computer repair store, they have additional tools that will extract the files in most cases.
Jun 29, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
Where can I find the drivers on my computer so I can charge my Ipod
Hi ewaf3,
You mentioned that you need a driver to be able to charge your iPod Nano on your computer.
I do not think you need drivers for an iPod Nano to be detected on a computer or to be able to charge it, I believe you are experiencing issues that when you connect your iPod it doesn't get detected right.
Try installing iTunes on you computer if you already have iTunes then the iPod most probably gets detected.
iTunes is the only software program closest to a driver that will make an iPod get detected by windows.
Check this link
I hope that this can help with your query/
Thank you for choosing Fixya,
mvincentc
Jun 07, 2011 | Apple iPod nano
Bought a new battery and it wont charge, says on AC power
Take the Battery back Its defective , New batteries should charge for 18-24 hours, and the computer should tell u that it wont run till the battery is fully charged.
Jul 22, 2009 | HP Compaq Presario V2000 Notebook
My new missil mp4 is not being detected on my computer!
I think I have this same type unit. When I first got it and connected it, my computer would not detect it until it charged for about an hour. then the device powered up and i was able to read its drive.
Mar 24, 2009 | Network Computing Devices (NSH800S/A)...
When I plug in my Zen Micro to the PC to chage all i get is the flashing charge signal but the devices does not recgharge. This is the same USB that i have used successfully on another PC. it also wont...
I use to have that little player and i remember how it could be tricky on different computers.
from http://www.anythingbutipod.com/forum/showthread.php?t=27711
If these don't work please report back:
4. If the Zen is not detected by or charging from the computer when connected, make sure you are using a USB port on the back of the computer (built into the motherboard) instead of one wired to the case (front or side). That way you are using a USB port with the proper power output.
5. If the Zen is not detected by or charging from the computer when connected, make sure the USB port you are using are USB 2.0 and not v1.1. If you computer is a newer computer, this shouldn't be a problem, but if it is an older computer, it may only have USB 1.1 ports which doesn't output enough power as USB 2.0 ports.
6. If the Zen is not detected by or charging from the computer when connected, make sure you have no other USB devices plugged into the computer (front and back ports), but the Zen. That may be worth a try to see if you can get enough current from the USB ports to begin charging it again. Usually the more devices you have plugged into the USB ports, the less current that will be available for charging due to the power being shared with all other devices plugged in.
7. If the Zen is not detected by or charging from the computer when connected, make sure that the drivers are loading for it properly under Device Manager (no conflicts showing). I believe the Zen will not be detected or begin charging unless its drivers are loaded and working properly.
Jul 30, 2008 | Audio Players & Recorders
Sansa cant be detected by computer
i had the same problem with mine and my computer didn't detected it so try plugging it in and out a few time it might work.but if that doesn't work go on settings and change the usb setting
Apr 06, 2008 | SanDisk Sansa e260 MP3 Player
MP3 player dead
well did you push the it all the way in the USB Port? Sometiems I don't connect it all the way and it doesn't charge. I go to my school and charge it on there computers too and it charges fine.
Another advice is to actually use the Sonicstage to avoid viruses. It's not that hard to install or download music files.
Dec 14, 2007 | Sony NW-E002 MP3 Player
Computer cannot detect my motorola l7
ther must be a problem in the phone data port cause u can even charge the phone so go to a nearby servising center for changing ur chargingpoint
Sep 08, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Camera will detect camera then come up with error message
What Operating system is your Lappie? If it is XP or 2000 no driver required. Best advice is to remove the camera soft ware from the computer. Plug the camera in and Windows will detect it as a new drive in My Computer. The best advice for software supplied with cameras is - Leave it in the Box and let WINDOWS DO THE WORK
May 10, 2007 | Kodak EasyShare C330 Digital Camera
SanDisk Sansa e250 MP3 Player Logo
210 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
