Question about Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP Gas Powered Lawn Mower
What kind of lawnmower oil does my lawnmower takes the model number is 10640
    Problem Solver:
  • 5 Answers
Lawn mower grade strait 30
Posted on Jul 30, 2009
What kinda of oil do i use for my lawnmower
Two choices I'd recommend if you change your oil faithfully than you can use a SAE 30 weight oil. A lot of manufacturers will recommend using the newer version of oil that doesn't break down as quick where as a lawn mower motor runs at such high temperatures due to being an air cooled engine. Most auto supply stores or lawn and garden dealers will carry the longer life based oil, but personally I prefer to stay with what has worked for me for many years. Preventative maintenance , (Faithfully) for me means every spring. Good Luck
Jul 10, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Help line for craftman lawnmower
Could you check the model number again and provide the Brand?
Jun 03, 2014 | Craftsman 20 Hp 42" Deck Lawn Tractor
My lawnmower takes 15 -20 mins to warm up.
Check oil may have low oil shutoff and drain gas and start with new
Feb 25, 2014 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
SPARK PLUG FOR POULAN LAWNMOWER #600Y22SHP AND WHAT KIND OF OIL TO BUY. wANT TO DO MAINTIANCE.
Take the old plug out and it will have numbers on the side. Simply match them up and you can cross-reference them on the package of any other plug that looks like it fits. But I'm guessing that mower has a Brigg's and Stratton engine and the plug will probably be a RJ19LM (Champion Number), which is what 99 percent of the engines I work on take (gapped at .030). Also, most mowers today run on straight 30 weight oil (not a multi-viscosity such as 10W30, Just 30 weight). Hope this helps you and good luck. P.S. Your owner's manual will tell you what you need to know and the engine sticker will tell you the oil.
Jun 27, 2011 | Poulan Pro 22" Self Propelled High Wheel...
HOW MUCH OIL AND WHAT TYPE FOR BRIGGS STRATTON 6BSXS.BT ON TROYBILT GENERATOR 30245 NO OPERATORS MAULA lIVE IN cULLMAN NO POWER SINCE D
imogenerhode-
This engine takes a four cycle engine oil. SAE 30 weight should work fine. Any oil made for lawnmowers would do.
You may find the troybilt manual for this unit at: Link
The briggs and stratton manual can be found at their website at: Link. To look find the correct manual you will need to find the model and revision number from the inner side of frame, next to the engine. The model number will be a six digit number and the revision number should be two digits.
If you have found this helpful please take a moment to give me four thumbs up.
Regards,
DIYpro
May 01, 2011 | Briggs & Stratton Electrical Supplies
Hi, what kind of oil can i put in my ridind lawnmower craftsman?
The domestic engines (Briggs, Tecumseh) take SAE 30 weight motor oil. The import engines (Honday, Kawasaki) usually take 10W30 motor oil. In either case, I recommend using a good quality name brand oil like Castrol, Pennzoil, etc. Most riding mower engine take about 48oz from a complete drain. If your engine has an external filter, it might require a few more ounces.
I hope this helps.
Aug 27, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
New Lawn boy 10640 mower - had for approximately 2 months, always worked fine. Saw that it was low in oil (naturally), added oil (did not overfill) and the pull cord won't work. It's stuck - everthing...
Don't throw it out. Remove the top plastic cover and it will be easy to access the starter/recoil unit. It should be easy to remove and take that off and diagnose the problem. Post back if need be.
Aug 13, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
What kind of oil should i use for my 6.5 briggs
Doesn't matter what kind of oil you use, as long as its SAE 10w-30.
Jul 03, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Lawnmower engine idling to low
First, follow your throttle cable down to the carb. Locate the clamp that holds the housing in place and loosen it just enough to move the cable. Start the mower and adjust the idle by the screw that touches the same plate that your cable hooks to. Then push the throttle control to idle and retighten the cable clamp.
Apr 26, 2010 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Oil, how much
If you have the model number for that mower then go to www.managemyhome.com and download the owners manual. It will tell you how much oil the mower will take.
Jul 28, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP  Gas Powered Lawn Mower  Logo
270 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
