Question about Singer Quantum XL-6000 Computerized Sewing Machine
Lcd screen wont light up. The machine locked up. We found abunch of lint in the bobbin case area. Upon removing it a small piece of loosely woven fabric which appeared to have a piece of sticky tape on each end indicating it may have been part of the machine. We did get the machine freed up but the lcd screen does not line up and the machine wont run. Can you help? Thanks
  • Singer Master
  • 1,388 Answers
Take it in to a Singer repair shop, too likely there is some damage to wiring and sensors for a home fix from what you have said.
Posted on Aug 02, 2009
My machine will not sew. New not used but a few years old. once thread goes down to bobbin it locks and you can hear the clutch disengage. without thread you can run the needle at full speed then it
There may be a small bit of thread or lint caught somewhere in the bobbin case or bobbin holder. Brush lint away from the feed dog area, being careful not to brush lint into the workings of your machine. If you have the manual, look up how to clean lint from the bobbin. If you don't have the manual, try just taking the hook out, if possible. Run a clean toothpick around the housing and then use a clean small brush to brush out any lint or thread pieces. Put one drop of sewing machine oil on the hook of the bobbin housing. Then use a thread to "floss" your bobbin case. Run a thread through the slot and wiggle back and forth to loosen any caught thread bits. Good luck. ps If this doesn't work, repeat. Sometimes after you turn the hand wheel a bit, another piece of thread or lint will work loose and can be cleaned.
Dec 06, 2014 | Sewing Machines
The upper thread breaks immediately I start operating
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw
to remove the old needle, place the new needle in the clamp with the flat
side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then
tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads
or lint
Apr 17, 2012 | Sewing Machines
Bobbin is making a thumping sound and thread is clumping on bottom will not catch right
Remove bobbin.
Take your small sewing machine lint brush and sweep around the bobbin case to remove debris (lint, loose threads).
Make sure bobbin looks smooth with no visible bent areas or scratches.Sweep out feed dogs area. Gently get the brush bristles down in there but be very gentle, of course.
Make sure when you rethread your machine (which I HIGHLY recommend) that your needle is all the way up as high as it will go in the needle shaft. Flat side of the needle goes to the back and the rounder side should face you. Tighten the screw on the needle clamp securely.
How about the weight of the fabric? Maybe it's too heavy for the size needle you are using. Or vice versa. And thread should be of good quality and suitable for the weight/type of fabric you are using (i.e. can't use cotton thread to sew Spandex, etc.)
Make sure your bobbin is going properly into the bobbin case. The thread goes under the piece where the tension screw is (right to left) and up through the delivery eye. You can tighten or loosen the bobbin case screw, but just a TAD and test results, being careful not to over-turn this! It doesn't take a huge turn to change results it makes.
Hope this helps!
Jimmy
Mar 31, 2012 | Brother LS-2125 Mechanical Sewing Machine
I broke a needle and now it wont pick up bobbin tread
Hello
Make sure the needle is facing in the correct direction,stitches don't form, or skip badly when the needle is turned around.
Put the bobbin in the bobbin case (right way around) leaving a 2-3" tail.
Thread the top of the machine correctly, leaving a 3-4" tail after threading the needle.
make certain your bobbin in locked into position in it's case and the thread is coming from the bobbin in the correct direction. When holding my metal bobbin in my hand, the thread pulls counter clockwise before placing it into my front loading bobbin case.
Also check if the needle is not properly installed in the needle bar,the machine is not threaded properly or the machine needs adjustment or repair..
Feb 12, 2011 | Euro-Pro 416 Mechanical Sewing Machine
Bunches of threads on the bottom
You didn't give the brand, but if it's any of the older, non computerized machines, your problem is most likley in the tensions.
Loopies (tangles or nests of thread) on the bottom means upper tension too loose (or bobbin too tight).
Let's do the bobbin first...once it is set...99.9% of loopies on the underside are a problem with upper tension.
This is for bobbins that load on the front/side of the machine.. Take out the bobbin case...check the area (hook/race area) that the bobbin goes into for lint, tiny thread pieces, etc.). Now, most of this type of bobbin loads into the case with the thread going counter clockwise (when you are looking at the open side of the case), insert the bobbin in the case, and pull it through the hole/slott in the side of the bobbin case. To test for proper tension:
Lay the bobbin case in the palm of one hand, pull on the thread coming off the bobbin case. The bobbin will gently lift off your hand & if you wiggle the thread, the bobbin case should slowly drop about an inch at a time. If it's too tight, loosen the Larger (closest to where the thread comes out) screw on the side of the bobbin case about 1/16 of a turn...tiny bit...retest. Once that is done try a test stitchout. Remember to hold onto the bobbin & top thread for first few stitches.
If you still get loopies on the bottom...tighten the upper tension...it should be set between 4-5 for regular sewing.
Make sure the needle is in properly.
For a drop in bobbin...adjusting that tension is harder. You take the face plate (needle plate, the plate covering the sewing area of the machine) off and remove the bobbin case...First...look at the case in the machine...there is a little lip sticking out, usually at the bottom right corner of the open area (closest to you)...this is where you need to have the little lip when you replace the bobbin case.
Remove the case...check under it and inside the machine for lint/dust/threads & using a small paint brush (I use a childs tooth brush sometimes), clean the lint out. Now check the bobbin case for lint, especially where the thread fits..look at the inside of the case, you will see a little flat metal thing with a slott in it...make sure no lint in that slott. I use a pin to remove lint from there. Reinsert the bobbin case, rethread it all, (bobbin goes counterclockwise). Put the faceplate back on & test the stitches...still loopies with the upper set to between 4-5? Then you will remove the faceplate, remove the bobbin case & loosen the screw on the outside about 1/16 of a turn (these are usually covered in a colored coating) and retest.
I know that most home machine makers say not to adjust the bobbin..but that was back when you had one size thread...now we have many, many sizes and types of thread, so adjusting the bobbin may be needed sometimes.
Rule of thumb is:
loopies on underside...tighten upper tension
loopies on top...loosen upper tension.
But, like I said...with all the new threads..sometimes you have to adjust that bobbin.
May 12, 2010 | Sewing Machines
The machine keeps locking up. i have cleaned the bobbin and hook area. there was not much lint
if your machine has a front loading bobbin case, remove it and then remove the shuttle which the bobbin case fits into. most often there is thread or lint caught in the shuttle race preventing the shuttle from turning (it only needs a tiny piece of thread).
if you have done this check any gear meshing to ensure no lint or thread has been caught in the teeth of the gears.
if the machine sews ok and locks up after a few stitches then it sounds like needle threading or tension causing the problem. re-thread the machine and ensure there is sufficient needle thread tension to bend the needle a little when presser foot is down and thread is pulled through needle.
goodluck,
scott.
Jul 28, 2009 | Kenmore Sewing Machines
Sewing machine bobbin casing is loose and can't get it back in!
In the lower right hand corner of the bobbin case area, there is a small finger-like spring structure. Gently lift it and push it to the right. Take the bobbin case in hand and inspect it. It is a round piece of metal with a groove running down the edge of it. Now look at the hook, or the round piece of metal that is in the bobbin case area. It has a slight shelf-like structure. Place the bobbin case groove into the shelf-like structure in the hook so as to make it sit flush. With your finger, take the front of the bobbin case and push it to its left so that it is as far counterclockwise as possible and replace the spring.
Hope this helps.
Jul 20, 2009 | Yamata FY700 Mechanical Sewing Machine
My futura sewing machine seems locked up
Try removing the screws that hold the needle plate on and take it off, remove the bobbin case and check for loose thread in the bobbin area. Sometimes machines lock up when a small piece of thread gets under the bobbin case, this is called being "thread locked". Hope this helps. I'll see what I can find out about the "88" error message.
Feb 24, 2009 | Singer CE-200 Quantum Futura Computerized...
General up-keep and maintenance for activia 140?
Clean, clean, clean the bobbin race area, oil the designated oiling spots (if there are any), and change the needle for each new project (or 6 hours of sewing). I'm not a Bernina user but have sold another swiss brand and in our training the need to clean and CHANGE THE NEEDLE was stressed heavily. Many users will leave the needle in place until it breaks, sewing through thick and thin, knits and wovens. And there is always going to be lint building up in the bobbin race area which will eventually "felt" up into a wad if left. Simple cleaning is lifting the needle plate, (or opening the front flap if front loading), removing the bobbin case, and brushing around the whole area carefully with a small soft bristled brush. Then oiling (with quality light machine oil), running gently for a few seconds unthreaded, then reassembling. Also wipe down the exterior of the machine with a damp cloth and clean between the tension disks by sliding a single layer of fabric into them.
Jan 27, 2009 | Bernina Activa 140
My Bernina 930's lower tension is off. When I sew the stitches are tight on top, but loose on the bottom. How can I fix this? I've tried messing with the tension and have cleaned the bottom.
Hi - you might have a dirty bobbin case, or need a new one. IAfter awhile, little teeny dust bunnies can collect in your bobbin case and cause your bobbin tension to go wonky, especially if you use cotton thread. If you happen to have an extra bobbin case, try using the new bobbin case to see if that solves the problem. Otherwise.....
  • Remove your bobbin case and take out the bobbin. Find a small, stiff brush like the one that came with your machine and stand in very good light. Brush out the inside of your bobbin case, and push one or two bristles of your brush into any opening you can see. If you see any trace of dust but you can't get it out, use tweezers to gently pull the dust out. Now look at the outside of your bobbin case. In the small opening where you insert your bobbin thread into the bobbin case, there is a small piece of metal with screws in it the lays over the bobbin case. Brush that area carefully, and again, insert one or two bristles under than piece of metal and into any other small opening where the bristles will fit. Try sewing again. If you are still getting loops, take out your bobbin case with the bobbin thread still inserted and grab the bobbin thread with two fingers. Let go of the bobbin case - sort of like you are holding a yo-yo. If the bobbin case starts to drop as soon as you let go, your bobbin tension is loose. If the the case doesn't move, gently snap the bobbin thread you are holding and see how far the bobbin case moves down toward the floor (you might need to try this a couple of times, the bobbin has a nasty habit of flying out). When you do the snap, the bobbin case should move down about two inches and stop. If do not know how to adjust the bobbin tension, either check your manual or take the machine in for service.
  • If you haven't already, it's a good idea to remove the thread plate that sits under the needle and clean that area out with your brush. Also, get a really good flashlight and check the area where you insert your bobbin case. Gently turn your fly wheel and look inside the hook area - remove any dust or bits of thread.
In general, you should oil your machine as indicated in your manual as often as directed. You should change your needle every 10 hours of sewing - or each time you start a new project, and you should take your machine in for service every one or two years - even if you only use it once and awhile.
Hope this helps, Ginny
Dec 06, 2008 | Kenmore 19365 Computerized Sewing Machine
Singer Quantum XL-6000 Computerized Sewing Machine Logo
126 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
