Question about Electrolux Kenmore 30 in. Gas Freestanding Range Range
Oven hums while gas is on. - Electrolux Kenmore 30 in. Gas Freestanding Range Range
    President:
  • 1,922 Answers
More than likely the gas solenoid is loose and vibrating when powered up to open gas valve, you can try to tighten its mounting,but if its the solenoid itself internally loose its new solenoid time
Posted on Aug 02, 2009
Our gas oven has not worked in over a year. The electric panel was malfunctioning. The burners work fine. We just had some work done and had to turn off the radiators and manually fill the boiler an
The hum may be a b ad regulator in the stove. Pull stove out and see if regulator is humming. It's where the gas line connects to stove.
Maybe the power was interupted to the stove which may have reset power to control board.
Oct 22, 2014 | Kitchen Ranges
Oven will not heat up. The Oven igniter glows but the gas pipe does not light up. The broiler gas pipe at the top of the oven lights and so does the stove top burners. Do I need to replace the Flat...
Microwaves use a magnetron to emit the waves, they make a very characteristic (and loud) humming sound when they 'kick-in.' If it is not making this sound that's your problem. It is not a user-replaceable part so please take it to an appliance repair shop, or purchase a replacement (which will probably be the same or lesser cost than repair unfortunately.)
I hope that this will help in solving the problem....
Aug 08, 2011 | Microwave Ovens
My oven turns on, however, it takes a long time for it to bake anything. It does not seem to be getting hot enough. I have noticed that it makes a humming noise when I turn it on. Help please!!
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 06, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Runs normally, but makes loud hum. not heating. in defrost mode, loud hum, then normal sounds, then loud hum, then normal...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 15, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
Viking Oven Not Working After Self-Cleaning
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 15, 2010 | Viking Professional VGRC365-4GD Stainless...
Ge profile oven/convection oven humming when on convection settin
ensure that your convection fan is turning
a hum on this model usualy means that the convection motor can seize up a bit
sometimes all you need to do is redjust the fan blade
Oct 13, 2009 | Ovens
I've got a humming sound coming from my oven when baking. Can you help me solve this problem?
Could be a air flow situation.
Too must air at the burner causing a poor ignition possibly flame lifting situation.
Adjust the burner air
Mar 15, 2009 | Frigidaire FGF366E Gas Kitchen Range
Tappan gas oven dooor won't unlock
We were able to solve the problem by accident. As I think I mentioned the door must of locked when we were cleaning the control panel. Anyway the door locked and the burners would not ignite.The door was open so you were not able to shut it to try and clear it. I searched the owners manual, there were no solutions as to how to reset the Range. I even checked the manufacture's web site. I got down to inspect the door and ran my hand along the inside edge of the oven and there was a button on a spring. I pushed on it and there was a hum and the latch opened and the Range must have reset. It's working perfect now.
Dec 07, 2008 | Tappan TGF320 Gas Kitchen Range
Electrolux Kenmore 30 in. Gas Freestanding Range Range Logo
441 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
