Question about Precor Exercise & Fitness
Precor efx 546 version 1 Screen locked up and right bottom screen shows two upside down FF and diagonal lights going across the top and bottom of the main screen. Turning it on and off does nothing.
  • Precor Master
  • 1,594 Answers
SOURCE:
  • 4234 Answers
SOURCE: Repairing JVC AV-27D202 27" TV
This is caused by a bad capacitor in the vertical circuit. If you can solder, you may be able to resolve this yourself. If you wish to attempt this repair, please update this and I will provide additional details and instructions.
Dan
Posted on Mar 21, 2009
dylanfinance
  • 3 Answers
SOURCE: Red line across top/blue line across bottom of screen
Adjust your convergence. Under menu I think its the last choice at the bottom of settings or picture menu
Posted on May 05, 2009
  • 8081 Answers
SOURCE: upside down and flipped numbers
Press [CLEAR] to erase the screen. If that does not work reset the RAM
Press [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER]. Then press [CLEAR].
If these steps fail, you should read the article.
Hope it helps.
Posted on Oct 30, 2009
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
  • 3 Answers
SOURCE: samsung a950 main screen display is backwards and upside down
My Samsung U700 had the same problem (display went back-to-front and colours all reversed and low-res.) It seems to be a problem with the flex cable (the cable between the main phone body and the sliding screen) wearing down and screwing up the data being carried between the display and the phone. Flex cables are cheap to buy and there's plenty of info online showing how to replace them yourself. Good-luck. Google: samsung u700 replacement flex cable
Posted on Aug 25, 2010
Where do i find akeykpad for the procor 546
Fixya is unable to suggest sources for Procor parts.
Sep 01, 2018 | The Computers & Internet
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
Precor EFX 546 Version 1 making clunking noise
Someone needs to look at this as noise issues can be from anywhere and anything.
877-805-1030
Book An appointment
Feb 11, 2014 | Precor EFX 546i Elliptical Version 4
Precor efx 546 wobbles when raising incline
It may be either the front shroud is installed incorrectly or broken, or the corkscrew for the incline motor is bent. If it is bent, it would need to be replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Feb 10, 2014 | Precor Efx 546 Version 1 Lower Body...
Service manual 546
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Please use your model and serial number to narrow down your search. In the middle of our Web page you will find the service manual for your machine.
Sep 03, 2013 | Precor EFX 546i Elliptical Version 4
How to repair a 546 efx precor
Assuming the buttons are working, the numbers change on the display, and the incline works, it may be the lower circuit board or the generator. If it is a very old unit, it may be the electromagnet or the data cable that connects the two circuit boards.
May 08, 2013 | Precor Efx 546 Elliptical Version 2...
Efx time out after 7 sec
My Precor Elliptical EFX 546 Timer Stops After 7 Seconds, what is wrong? The most common cause for the Timer to Stop After 7 Seconds on a Precor Elliptical is NO RPM Feedback.
Knowing the status of the unit from its last use as well as the last service or part replacement is a great place to start.
Check the connection of the speed sensor to the lower board. Reset connection if necessary.
Check the magnet. The magnet is located on the user's right crank arm on versions 1 and 2 and the user's left on version 3. The magnet passes the speed sensor with each revolution of the crank arm. The magnet should be installed so that its south pole is facing the speed sensor. You can check the magnet polarity with another magnet that has marked poles or a compass. The north pole of the marked magnet or the south facing needle should be attracted to the magnet. Correct magnet installtion if necessary.
You may also check the spacing of the speed sensor to the magnet. The spacing should be 1/8" to 1/4". Adjust if necessary.
My Precor Elliptical Shuts Down After 7 Seconds what is wrong
Feb 02, 2012 | Precor EFX 546i Elliptical Version 4
My precor efx 544 has stopped recognising that i am using it. does not display strides or calories burned. any ideas?
Also see the following link for additional information.
Replaced Crank Arm on Precor EFX 546 and Display Doesn Work
Jan 14, 2011 | Precor EFX 546i Elliptical Version 4
Error 45 on Precor EFX 546 Elliptical
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
61 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Ross Metcalfe
Ross Metcalfe
Jose Pino
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
