Question about Intel Server Board SE7501BR2 Motherboard
Need pin layout
I need to see the diagram of the board so I know where to hook everything up from the case.
  • mark184 Jul 29, 2009
    sorry, it is the Intel se7501br2 server board and generic case and power supply
  • Bobcatflusa May 11, 2010
    what is the board model and make and what case?
    President:
  • 2,666 Answers
PDF available here
http://www.intel.com/support/motherboards/server/se7501br2/sb/cs-007202.htm
Posted on Jul 29, 2009
Motherboard layout diagram Gateway GT5654
usually if the wires have a name on the end of them check your motherboard very carefully probably with a torch or lamp you will see the same name as on the end of those wires on pins connectors on the motherboard if it says audio ac'97 on the end of the wire you will find the ac'97 pins on the motherboard then connect if it doesnt work take out and turn the connection around the other way to see thats all i can offer hope it helps
Dec 16, 2011 | Gateway Computers & Internet
I have not the manual for this motherboard (cliping power,reset and led button
Usually this can be found in small print right on the motherboard, use a magnifier and/or flashlight and look next to the pins on the board. In some cases, there is a diagram next to the pins showing the layout.
Nov 26, 2011 | Chaintech 7NJS-ZENITHh Motherboard
Hi i have a Codegen model 450x case and i am trying to install a Gigabite GA-P35-DS3R motherboard and am having troulbe with the start switch wires, the cases wires do not matgh the diagram in the...
I'm not sure what you mean when you say the case wires don't match the diagram. You might mean there is already a plug on the end of the wiring, and this plug doesn't match the board header. If you're reusing the case from a name-brand machine like a Dell or HP, this is possible. They often get custom versions of motherboards made, and their front panel connectors are usually a nonstandard layout. On the other hand, in a generic retail case, the front panel wires normally have separate connectors on the ends for the switches, indicator LEDs and any front panel USB and audio jacks.
This is the front panel header diagram I found in the manual for your board (I looked at version 2, but the connections should be the same if yours is a different version):
This board has an Intel standard layout for the header. If your wiring has separate connectors, the start (power) switch wires will plug onto pins 3 and 4. I have never seen a retail case come with anything other than a two-pin plug on the end of the power switch.
If you are dealing with a custom plug on your case's wiring, what you can do is remove the pins from the housing. They almost always are held in by a plastic tab on the connector shell that engages a tang on the pin. Use a thin object like a small flat-blade screwdriver or a knife tip to lift the tab and you can slide the pin out. Insulate each pin with small-diameter heat-shrink tubing if you have it, or a layer of electrical tape. (I prefer the heat-shrink tubing, which is neater and more permanent.) Then you can put each pin over the corresponding pin on the motherboard's front panel header. Unless the pins are very loose, they will stay in place by friction. I often use this technique when salvaging a case.
As for the CPU fan, be sure you have the connector over the right pins. Here is the diagram from the manual:
You might need to rearrange the pins in your fan power connector if they don't line up correctly. This layout looks a little strange.
Dec 21, 2010 | Codegen (PS-450W) (PS450W) 450-Watt Power...
Swapped my ma785r board to a new case and need the pin layout for power switch and reset switch
ok i dont hqave it but as i buld a lot of used pcs and new ones its usaly goes like this there is a 9th pin and a tenth one missing next to and in a straght line down the way nest to where the missing pin is is the on of under it is the reset pins next to the reset one is the hdd led and that leaves 1 set of 2 pins left if you want e mail me and ill draw a diagram for you hope this helps
Mar 17, 2010 | Computers & Internet
SP283983 001 pin layout
You need to get the motherboard number and look it up at the manufacturer site under support you should be able to download a tech specs for that board showing the pin layout [owner manual may have it too.
Oct 31, 2009 | Computers & Internet
Emachine T3958
Hopefully eMachines are consistent with their wiring/layout design, that being the case this diagram for T2898 (by benz18724) should point you in the right direction...
Alternatively compare the abbreviated pin symbols on the header to the motherboard and match them up.
Jan 31, 2009 | Computers & Internet
Mother board layout diagram
Here is the support webpage for you model which may show you some things. It doubt that it will give you a wiring diagram.  To receive that you would have to know who made the mother board, then cross over the board numbers.
http://h10025.www1.hp.com/ewfrf/wc/product?product=3771735&lc=en&cc=us&dlc=en&submit.y=3&submit.x=8〈=en&cc=us
Jan 06, 2009 | HP Hewlett Packard Pavilion a6510t- Intel...
4to8pin atx
You don't need an adapter from 4 to 6 pin, the mother board needs a 4 pin atx connector.
You can download the complete manual from here: http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=685&CategoryID=1&DetailName=Manual&MenuID=46&LanID=9
And you can see the pins layout.
Let me know if you need more help
Sep 29, 2008 | EliteGroup GeForce 6100SM-M Motherboard
HP MCP61PM-HM motherboard diagram
Hi RobPu,
I have searched everywhere. I even entered a chat windows with Compaq & asked for a site to download the manual for Compaq Presario SR5015LA Desktop PC which has the motherboard MCP61PM-HM in it. (Nothing). This board was made by
ECS known as EliteGroup. Still nothing. Forms for the most part do not help, only with drivers. Drivers for the board can be found on Compaq's web site.
http://h10025.www1.hp.com/ewfrf/wc/prodinfoCategory?lc=en&cc=us&dlc=en&product=3411762
But the manual will not download. That's what is needed to hook up the front panel pins to you're case. I even looked for other possible boards who's layout was close to the MCP61PM-HM.
Nothing! I did find other Compaq PC's that also had the same board in it but after looking through the manuals, not one actuallys shows where to plug the front panel LED's on to the board. Why? Because Compaq does not support a user changing out their case for another. There is no money in that.
For the most part RobPu, system boards share some things in common. I am posting a picture for you. This pic is upside down for you so try & work with me here. Hook up you're LED's as shown. This should work for you. Pin 1 is you're starting point.
daa3370.jpg This is standard for ECS boards even if it's being sold by Compaq. Like I mentioned, for you it is posted unside down.
Try it, I'm sure it will work for you.
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 22, 2008 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
To fix front usb and audio to the mother board
Consult the user manual for the motherboard. It should have a layout diagram showing all connections. Or go online to manufacturer's website and download the user manual there. Also, using a bright light and magnifier you may be able to read the small print on the motherboard by the connectors.
Apr 24, 2008 | A-Top XBlade Mid-Tower Case
Intel Server Board SE7501BR2 Motherboard Logo
190 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
