Washing Machines Logo
Posted on Jul 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have model 110 24642300 top load. took the back
I have model 110 24642300 top load Kenmore washer, ser#CR263815.I took the back off to repair and when trying to replace the back panel I can't get those 2 shiny metal clips to engage the back panel? what's the trick?
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Jul 30, 2009
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2734733
Points
22413
Actually the washer should have come apart by removing the outer casing while leaving the back in place on the frame. The following steps explain how to remove the casing and reinstall:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
To reinstall the washer case, follow these steps:
1. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
You may try going through these steps and make sure you have the back of the washer correctly in place on the frame prior to reinstalling the case. It may sound like a lot, but this is actually the proper (and easier) method.
If you have any questions, please let me know. I hope this helps you.
Kenmore washer MOD 110.24422300 SER CP4427442 the washer wont spin, it makes a harsh and loud noise when it comes onto the spin cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Kenmore Extra Capacity Heavy Duty Washer, Model 4151090, Ser. No. Ca2301977, unable to find a parts list for this. Agitator won't spin, motor and pump works, it's older but can it be repaired?
I would try http://www.appliancepartspros.com/ I am sure that they can find the parts you need. They are the best place for parts and customer service. You will have to contact them because your model number doesn't come up in the search area, but I'm sure they can help. Ive gotten parts from them for a 35 year old GM Frigidaire washer.
11helpful
22432 won't spin or drain
CHECK THE LID SWITCH THE PART THAT PUSHES THE SWITCH DOWN MAY BE WORN ENOUGH TO CAUSE THIS PROBLEM. WITH THE LID OPEN START THE WASHER IN THE SPIN CYCLE AND PUSH THE SWITCH WITH A POPSICKEL STICK AND SEE IF THIS PROBLEM STILL HAPPENS
Model nbr 110-92580100 ser cd 3347297. wouldnt
your kenmore sounds like it lost the coupler do you feel ok opening the machine and inspecting the part?
the loud noise may be the coupler. I think your timer is working ok. because it goes through the cycle..
If you inspect it to be a bad coupler you can go here www.techray1.com and click on the link
let me know
All funcions of the washer work except the drain at the end
is your drain hose kinked near the back of the washer. try to look behind the washer without moving it. if the hose is not kinked its probably the pump..
1helpful
Top Washing Machines Experts
john h
