Question about GPS
Unit appears to be dead - GPS
    Brigadier General:
  • 4,090 Answers
Well as there is no brand or further details that is like saying I have a piece of string!
Dead GPS = flat or dewad battery
Either charge it or replace it
When was the last time it was used, charged, worked.
What do you think went wrong? did the maps load last time you used it?
Posted on Jul 30, 2009
Ainol Novo 10 Hero 10 won't turn on :( it appears dead :'(
Sounds like it is not charging.
The unit will power on momentarily if low batter but power off straight away
Get an electrical competent person to check the output of the power unit or use know good unit.
Dec 06, 2013 | Ainol Novo 10 Hero 10 Inch Tablet Pc IPS...
The unit appears to be dead but the green and yellow channel LED's continuously flicker.
I am guessing that the lights are near the network cable plug? This simply shows that there is a signal on the network cable that is plugged-in. The laptop may be dead. Is there a light on the power supply? If you remove the battery, plug the power in and press the power button, what happens?
Dec 15, 2012 | Computers & Internet
Brought my first Arhcos 5 in the US,dropped into water so brought anther one and wanted to transfer the gps but tech support uk less than helpful and code registered to a dead Archos 5. I shouldnt have to...
unfortunately you destroyed the original when you submerged it in water
AS it appears that each unit has it's own special registration code you will have to get a code for the new unit
( should have come with the new unit )
now as the dead unit was in the water , there is every possibility that any information and data on the unit would be lost as well
you don't have a good one doing until you buy the licence for it
Jan 10, 2018 | Archos 5 Internet Media Tablet
Remote handset is dead. No settings appear on its screen. New batteries have been inserted according to the instructions of the manual. For a second the time setting appeared, however when the ON Key...
Based on what you said, the only way to solve the problem is to order a replacement hand held remote from Mitsubishi. You will have to program it to match the codes on your AC unit. The instructions on how to do that, should come with the replacement remote controller. Consult your Owner's Manual on how to order parts from Mitsubishi.
Jun 24, 2011 | Mitsubishi MSZ09UN Air Conditioner
Whirlpool dryer epny spin belt not broken
althoug intact was it taught???? perhaps it "popped " off the idler/tension pulley. or if hte unit appears dead, then oyu either have a bad door switch/ or a fautly thermal fuse behind the unit.
Mar 01, 2009 | Whirlpool LER5636P Electric Dryer
My maytag dishwasher appears dead just after 1 year
You probably have a bad main control or console control unit in there. Turn power off to the machine, be sure that BOTH of your door switches are ok. Unplug your membrane to control panel ribbon cable, then put everything back in place. Leave the door open, then turn power back on to machine. (also, be sure the thermal fuse hasnt tripped while your in the console). After re-appling power, close the door, and wait a few, if the console unit is bad, the machine will go into drain mode (you will here the unit start in drain). If no drain mode, then your control is shorted. You dont have to see any burn marks, etc for one to be bad, in fact, 98% of the boards we replace, dont show any signs of problems. Let me know what you find out.
Nov 15, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Dead batter
If it is very flat it can take quite a while to appear to be doing anything.  Try using and external charger and resetting it after 15 mins on charge
May 05, 2008 | HP iPAQ H4355 Pocket PC
Dead hx4700
So check the battery lock switch at bottom of unit. It easily moves over to unlock position and then the 4700 will appear dead.
Sep 12, 2005 | HP iPAQ HX4700 Pocket PC
GPS Logo
126 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
