Question about Siemens Dishwashers
My Siemens Lady Dishwasher doesn't pump out the water
After washing, the dirty water still remains in
aborcass
  • 2651 Answers
SOURCE: water in dishwasher
if you push the start/cancel button it should start to drain water out. can you hear it drainin into the sink???can you at least hear thje drain pump activated trying to pump???perhaps its humming... if so id check your drain connection under the sink for blockage, and then next remove the drain pump itself and look for debris clogged within it stoppin drain
Posted on Mar 30, 2008
reg501
  • 413 Answers
SOURCE: Dishwasher spray arms don't spin & spray water
Could be a a couple different issues.. Not filling with enough water or food chopper broke or food chopper filter screen clogged.
Check water level:
Run the DW and wait for the main wash to start (water will fill. pause then complete fill) The water should be no more than 1/4 inch below the heating element. If not there..replace water inlet valve.
Inspect food chopper:
1. Remove lower spray arm and rear water supply tube to upper spray arm.
2. Remove torx screws that secure the sump cover.
3. Remove primary filter
4. Remove food chopper cover to expose the chopper assembly. Inspect for breakage or blockage.
If you need further assistance, let me know
Regards,
reg501
Posted on Jun 29, 2008
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
SOURCE: Aquastopper.
have a look at your other problem question, which seems to be the same. ;)
Posted on Jan 25, 2010
  • 1382 Answers
SOURCE: Water wont drain out of bottom of tub.
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Thank you !!
Posted on Jul 07, 2010
Dishwasher not cleaning very well.
Hello do it heat up ok is the water Hot please
Nov 13, 2015 | Siemens Dishwashers
Siemens lady 130 dishwasher overfilling at start of wash cycle
There is a float at the bottom of the washer. See if it is stuck. It should move up and down freely. This activates the water shutoff when it reaches the proper level. If it is sticking it could allow the washer to overfill . If that is not the problem then I would look at the valve it activates itself.
Dec 31, 2014 | Siemens Dishwashers
Dirty water standing in the bottom of the tub
There is probably some debris that is blocking the water from getting to the pump.For More information please visit Kenmore Parts.
Oct 04, 2012 | GE Nautilus 24" Built-in Dishwasher
Danby dishwasher not washing
see this possible causes: 1) water heating cycles;the water must be preheating,test the heating elements and thermostat. 2) Timer: test for defective, clean contact, repair any wires loose, burn, or break. 5_9_2012_1_15_39_pm.gif
May 08, 2012 | Danby DDW1899WP Portable Dishwasher
Siemens lady dishwasher is getting stuck on
I removed the dishwasher and put fill hose on mains pressure. (30 to 45psi or 2 to 3 bar). Working ok now. May be issue with water pressure switch ?
Mar 23, 2010 | Siemens 24 in. SL84A305UC Built-in...
Lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Dec 14, 2009 | Siemens Dishwashers
Siemens hydro sensor dishwasher not draining
sounds like a drain pump ... you may have a damaged drain pump or something stuck in it.. turn off the power the the dishwasher... .remove toe panel and you can see the drain pump on the left ..you can remove plastic hose on the left to drain the dishwasher ...be sure to catch the water will come out ... you can remove drain pump press release tab and turning drain pump ...hope it helps
Sep 19, 2009 | Siemens 24 in. SE53200 Built-In Dishwasher
My Diplomat built in Dishwasher fills with water and heats it and empties, however the water does not get sprayed thru the arms and the dishes remain dirty. Any suggestions on what the fault is and what...
The most common cause for no washing is a failed wash pump motor. Which is probably the single most expensive part to have replaced on a dishwasher.
Aug 11, 2009 | Dishwashers
I´ve got lady 420 siemens washdishes and it doesn´t works
we solved it, it was the condensator of the motor, we change it and it solve it!!, now she is wachine very well again!!
Dec 09, 2006 | Siemens 24 in. SE53200 Built-In Dishwasher
Dishwashers Logo
261 people viewed this question
Top Siemens Dishwashers Experts
Paul Bade
shaun taylor
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
