Question about Microsoft Xbox 360 Console
Disk drive door stuck, won't close.
Why somebody tried to steal my xbox360, and dropped it,now my disk drive door won't close, it's stuck?
    Problem Solver:
  • 16 Answers
If your warranty is already voided then you could try openning up your xbox and then openning up your dvd drive and just see what its getting jammed up against
Posted on Jul 30, 2009
How to remove stuck dvd from lg blu ray
sounds like the disk may be sticky on top and is now stuck to the chucking clamp. Try to cut power as the door tries to open, then open the door as much as it will aloow and you should be able to fish the disk out. If it is stuck, you may have to push down the disk with a screwdriver to release it.
Jul 28, 2014 | LG Televison & Video
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
Emachine disk door want open
I'm assuming the CD drive door is stuck and won't open. You will see a small hole in front of the drive. Take a pin and insert it in the hole and push it. The drive should open up.
May 05, 2011 | E-Machines e15t 15" Flat Panel LCD Monitor
I switched disk drive from 360 to 360 and now it wont play dvds someone please help!!
the issue is with in the swapping. The system inbedded a security code that is only identify by that single xbox360. In order for your system to recongize your disk drive in another xbox360 is if 1. the diskdrive is replica of the one swaped then only the chip under the drive is needed from that system or 2. flashing the disk drive. **BOTH ARE ILLEGAL**
you can manage either one by googling flashing xbox360 diskdrive ______ <--- the type of diskdrive you swaped out.
Mar 17, 2011 | Microsoft Xbox 360 Console
My disk is stuck insde the xbox360 after the red ring of death how do i get it out?
the disc try should still open and close as normal regardless of if it has the red rings or not. Be sure and take it out before you send it in
Dec 29, 2010 | Microsoft Xbox Console
A dvd is stuck the door wont open
Remove the top cover.
There will be several screws holding the top on. Remove all and slip the top cover backward to remove.
This will expose the internal system. You will see the disk inside under the laser disk reader.]
You will see a gear the drives the sliding disk holder/loader. This is the part you see come out of the door onto which you place the ****. Roll the gear with your finger and the holder will move. Keep going and the disk will come out as normal. Remove the disk and try to plug the unit in and press the close button. The unit may close as per usual. If not rotate the gear again until the holder goes full back inside. Again try to plug in and press open. It may start working. If not is had problems.
Hope this helps
Mar 08, 2010 | Symphonic WF803 DVD Player/VCR
My xbox disc drive keeps opening and closeing and wont let me play games
you will need to open this drive and clean the drive belt, or the tracks the tray use as they may be gummed up and dirty.
Open tray error is common, even more so on Samsung drives.
To fix this you usually really need to open your xbox360 so you can get to the disk drive so you can open it for a self-service. BUT first try to fix it with a laser cleaning kit, they don't cost much to purchase and you can get them from most electronic shops and also eBay.
If a cleaning kit did not work, then the problem may be your tracks, the disk spin head or the belt that moves the tray (drive belt).
Once you have your xbox360 opened (lots of good video guides on YouTube on how to open the xbox360) you will have to open your disk drive.
When its open, clean the left and right tracks, they can get gummed up with dust, and even tar if the unit is from a smokers home, when the tracks are dirty, it can stop the tray going in all the way then games don't play. Also if the spin head is dirty (the plate the disk sits on to spin the disk) then it does not grip the disk fully and thus does not spin at full speed, giving you read error. Finally the belt inside the drive can be removed and can be boiled in water for a minute or to, this cleans it and brings it back to its original shape, this helps the belt regain lost grip and can also fix this error your having, but belt problems are more for Samsung drives.
You should use rubbing alcohol to clean the internal components of your drive without causing any damage, you could even clean the laser yourself using a high quality kitchen roll sheet or micro fiber cloth, with rubbing alcohol and gently pass it over the lens to clean it. Once you have done all this, close everything back up and see if the problem is gone.
If your still having problems then chances are you need a new laser for your drive.
The following YouTube video may help you http://www.youtube.com/watch?v=6GLS1dndQLU
Let me know if you need more help.
Jan 02, 2010 | Microsoft Xbox 360 Console
Dvd door keeps opening. Won't load dvd. Won't stay closed.Compaq laptop. Bought at Wal Mart this summer. Problem started a few weeks ago. Aaaaargh.
Check and make sure a disk is not stuck in the disk drive. If a disk is not stuck try closing the door and hold the door close, shut down the computer. Start the computer and hold the the door while the computer reboots. Hope this fixes it. djmax1966@yahoo.com..
Nov 08, 2009 | HP Compaq Presario R4000 Notebook
The disk drive wont shut on my xbox360
Your disk drive shutdown, you will have to open up the xbox, unplug the disk drive then plug it back in.
Jul 16, 2009 | Microsoft Xbox 360 Console
Xbox 360: disk drive
try reseting the system in the system settings this, is sometimes caused by an update not downloading and or installing correctly. once you reset to default, try updating  the system on xbox live. if this continues you might have a drive issue. good luck....
May 27, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
1,519 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
