Hit pause to add other clothes to the cycle, stopped running and now flashing sud and nothing happening. can't stop the machine to start over
    Brigadier General:
  • 8,619 Answers
Hi
This happens when SUDS LOCK (Overdose of Detergent detected during the Wash Cycle). The motor control unit senses a suds lock condition by analyzing the current draw on the drive motor. If "Sud" is displayed a potential suds lock is detected. This may signify a bad pump, an extra heavy load, excessive detergent, or excessive suds. You need to follow these steps:
  • If too much detergent was used, run the unit through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU)
  • Check/Clean Drain Pump Filter of foreign objects
  • Check Drain Pump
  • Check Pressure Switch
  • Check CCU
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 29, 2009
I have a Samsung eco bubble WF1804WPU model that started showing the error message SUD. Any time it happens the machine stops washing as if paused and I have to press the pause button twice for it to start...
The SUD error indicates an excessive amount of soap suds in the wash. It will be difficult for the machine to rinse / spin all the soap out during the cycle, and may need to be run thru the cycle again (do not add any more detergent!).
Remedy:
Stop using regular detergents! Front loaders specifically call for "HE" (High Efficiency) detergents as they require less detergent and clean better with the reduced amount of water in these machines. Look for your favorite brand and select the one with the distinctive HE logo show below:
Use only the amount as directed on the bottle - do not use too much. Clothes should come out clean and soap free - and the SUD error should no longer appear - if it continues - double check the amount of detergent you're using as it is probably still too much.
Jan 30, 2015 | Samsung Washing Machines
I own a wcvh6600hww front loading easing machine. I load the clothes, soap, etc...go to start the load. Hit power , choose my cycle, & then I try to press start, but nothing happens...the start/pause...
It sounds like it's gamed, the fact the button is flashing shows a major problem, turn off power, remove the motor still connected, if it runs o.k.the problem is the machinery, or vicer /verser, if it is jammed machinery take various parts off until things move.
Jun 28, 2014 | Washing Machines
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
Door wont unlock once a wash cycle has begun
that is correct ,. pump water out then the door will open.
May 20, 2011 | Kenmore Elite 45986 Front Load Washer
Duet whirpool washing machine stop and DLF sign appear
Initially unplug the washing machine.While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for five seconds.
Plug the unit back in, and run a rinse and spin cycle to test if the DL code is cleared.
If you still face the problem then follow the procedure:
Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Plug the washer back in and press [Power] to turn on the washer.
Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Press [Start/Pause] to begin a drain only cycle.
After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause].
This will remove excess soap suds and light residue from the drum.
Repeat this step until no visible suds are in the drum of the washer.
Hope this helps.
Shane
Apr 03, 2011 | Washing Machines
My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Light flashing halfway through cycle
Start with the basics. Do you have the right detergent and the right amount of detergent? It sounds to me like that could be it. Too many clothes or not enough clothes could do it too. These new washers weigh the load and make an attempt to fix problems by stopping. The motor over amps with suds problems. It has to run more cycles to get the water clear. Yeah the machine checks the water. So if you have too much soap or the wrong soap or the soap in the wrong portion of the dispenser that could be causing it and then their could be a clogged pump filter.
Apr 03, 2010 | Washing Machines
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
Top Washing Machines Experts
