The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
The coils iced up. Now the unit is cycling strangely. Sometimes the compressor won't come on. Other...
(More)
The coils iced up. Now the unit is cycling strangely. Sometimes the compressor won't come on. Other times, when you remove the bucket to empty the water, the fan will come back on but the compressor won't. Also, only the two sets of coils in front seem to be cooling.
i have 4 ea new lhd659ebk dehumidifier and they make lots of noise and vibrate a bit, this is normal...
(More)
I HAVE 4 EA NEW LHD659EBK DEHUMIDIFIER and they make lots of noise and vibrate a bit, this is normal in these Dehumidifiers ..
The dehumidifier powers on and immediately stops with display error code Ch 01 Bucket is empty,...
(More)
The dehumidifier powers on and immediately stops with display error code Ch 01 Bucket is empty, outflow hose attached
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
