Question about LG WM2688HWM TROMM SteamWasher
We purchased a Tromm Model#WM2233HW S/N MOLD growing in the rubbe
We purchased a Tromm Model#WM2233HW S/N 704Kwcf03443 and have a MOLD problem. The robber gasget around the opening to the tub does not extract the water and mold is growing on the rubber and can be found on the glass. I have two small children and I am worried. Can this be fixed? This is a design problem why have I not been called to have this problem corrected?
Chris Strobel
5930 Chatham
Hoffman Estates, Illinois 60192
1-815-651-4530
diannestrobel@sbcglobal.net
  • 23 Answers
Put 2 cups of bleach into the washing machine and run a cycle with HOT water (long cycle) Steam if possible. This should kill the mold...with a front loading machine you MUST use HE Detergent, and LEAVE THE DOOR OPEN AFTER THE LOAD IS DONE!!!!!!! the seal needs to dry, just like your shower curtain needs to dry. You should also wipe your seal with a dry towel after each load. It does state this in the owners manual, as well as the laminated sheet with the suction cup that came with the machine...
Posted on Jul 30, 2009
What are the Common types of mold in homes?
Mold is considered to be a big issue when it comes to house management; this is largely down to its capability of growing anywhere. Mold biologically is a form of fungus that grows in the presence of moisture. There are different varieties of mold that can grow and some of them are harmless while others in extreme cases; can be fatal. In this article, we have looked at three harmful mold varieties.Check out here and know more about Molds - AWDR Water Damage Alpharetta Ga Restoration Water Removal Emergency Cleanup
Apr 26, 2018 | Washing Machines
What is white bread mold?
Molds are microscopic fungi that live on plant or animal matter.Mold grows from tiny spores that float around in the air. ... A mold that grows on strawberries is a grayish-white fuzz. A common mold that grows on bread looks like white cottony fuzz at first. If you watch that mold for a few days, it will turn black.
Food Molds - Are Molds Dangerous - What's Cooking America
https://whatscookingamerica.net/Q-A/Mold.htm
Feb 24, 2018 | Kitchen Appliances - Others
Our LG WM2233HW Tromm when not in use slowly fills up with water. For example if we do not use it for 24 hours there may be as much as 2 inches of water sitting in there.
The water inlet valve has failed. They tend to get debris inside and not seat properly. You will need to replace the water inlet valve. They are usually not to expensive and easy to replace. Here is a link that should help Water inlet valve replacement You can also get diagrams and illustrations of your specific model at the same site.
Oct 28, 2010 | LG WM2233H Front Load Stacked Washer /...
I am so unhappy about the mold problem in the door gasket of my LG Tromm washer. I keep the door ope to ventilate, I dry it out, STILL mold and slime! I periodically bleach the washer to...
Hello- Well, you are not alone in your frustration and the only real solution, unfortunately, is to replace the gasket. As far as the internal parts I have rarely seen mold growing on those parts (in any front load washer), most of the the internal parts are hard plastic and stainless steel and these do not seem to allow the mold to grow even though they are wet a lot of the time. The internal hoses as well do not seem to have this problem. Though it gives little solace or immediate remedy I do think the manufacturers are going to have to come up with a rubber formulation that is not such a friendly environment for the mold. Considering the number of these gaskets, door boots, I have replaced over the years there must be some real issue with the engineering of this rubber or else they would have found a solution years ago. You could try contacting LG and asking them to replace it for free or at least send you the part for free. It usually takes a Tech about an hour to replace. Best regards.
Oct 05, 2010 | LG Washing Machines
How do i get the mold out?
A lot of times liquid detergent and liquid fabric softener will cause this. Dry the door seal after use and leave the door open. Don' t use bleach if you're on a septic system. There are products that are septic safe to clean the mold. Powdered detergent and not closing it up after using should help a lot
Mar 01, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Mold grows on dishes in bosch dishwasher
Put a bowl filled with 2 cups of clorox on the lower rack and run a wash cycle (nothing else in the machine) this will kill the mold spores in the machine, and clear the smell.
Jul 29, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Odor coming from inside washer
There is a tub beyond the tub you see. Run a load of water with chlorine bleach. This will kill the mold & mildew spores that are causing the odors. ****Do NOT add clothing to this washload****
If possible, keep the door open when not in use. This will allow the inside to dry and mold & mildew cannot grow.
Jul 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
New oregano pod has mold fuzz
sounds like you have to much moister and not enough air flow, i would start over and place in a better air flow area..
Feb 13, 2009 | Aerogrow Aero Grow Aerogarden White
Black Mold growing inside dishwasher
this is an easy fix use 1 part bleach to 10 parts water and wipe down this will kill the mold you may need to do this several times
Dec 08, 2008 | Dishwashers
Washing Machines Logo
249 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
