Samsung P28 freezes or blue screens on startup
My Samsung P28 has started freezing or blue screening on start up. I'll try removing the processor heatsink and reseating with new compound. My thoughts are the cause is a failing solder joint, connection or PCB failure. If anyone can advise on where to start looking I'd much appreciate it. Its been a cracking machine and i'll be sad to see it go.
  • Bobcatflusa May 11, 2010
    Is that bios startup or windows startup. Is it a warm machine or cold machine.
  • 748 Answers
Hello
This laptop is kind of old to put much money into it. I'll have to assume that you're diagnosing an overheating problem - screen lock up. BSD's or blue screen of death is caused by drivers. Before going to all the trouble of diagnosing hardware do a Windows repair. This is part of the original CD. If this doesn't work then do an operating reinstall. This should clear up all possibility of a BSD. Now to the hardware. If your fan has failed then I suspect the CPU and/or the video chip. You can check solder connections around the power supply connector. Good luck
Posted on Jul 30, 2009
Dell 8100 dimension keeps freezing
I need more than that to tell you how to troubleshoot the problem you're having. Most freezing or locking up is caused by a program not functioning properly. Start your computer in safe mode. Go to your start button, type in the search RUN right click and run as Administrator, then when the box opens type in MSCONFIG and click run/yes/okay (which ever you see). This will bring up a new window. On the main tab you'll see three options. Normal start up, Safe Mode, and Selective Startup/Custom Startup. Click safe mode hit okay and it will restart the computer into Safe Mode. This will prevent all startup programs and services from starting. Let the computer run and if it still freezes then you know it's a hardware issue. If it doesn't, it's a program error. Take the time then to diagnose either the hardware or the software. If it's the hardware, check to make sure that everything is seated correctly, that the ram is firmly and fully in their sockets. Make sure your hard drives are connected correctly. Check the power supply make sure it isn't dying and causing you too lose power.
Look at the motherboard and check for heat damage, blown resistors and other components.
If it's software, go back into MSconfig, go into selective start up and choose one or two programs at a time and restart the computer until it freezes. If you get it to freeze with a specific program you know it's the culprit.
Also, freezing tends to be related to bad configurations. I dont' know if you've been trying to overclock the processor, the ram, or the video card (onboard or dedicated) could also cause these issues. Check your bios and make sure your settings are correct. Stop using any overclocking software.
Lastly check temperature. The normal operating temperature of a desktop PC is 130 degrees F with some of the more powerful processors and video cars. 90 degrees F while not under load. If your temperature is getting too hot it could be crashing. This could indicate a bad processor, a heatsink that isn't seated or in contact with the processor anymore, malfunctioning fans, poor circulation, or even dust/grime/dirt getting into the computer.
You could be experiencing this GUI lag or freezing if you have background processes that are taking priority over it while they run drawing more of the computers resources. Let it sit for a little big and see if it corrects itself.
Lastly, if you're getting blue screens of death because of windows, get the logs for them and post them so we can go over them and see if anything else is happening.
Oct 16, 2013 | Dell Computers & Internet
Aspire 5475 freezes on startup
It is most certainly a driver, but if you cant access the safe mode also that could be a hardware issue.. Try to troubleshoot with a windows installation cd. Put it in and boot the pc. It will start the windows instalation, you choose repair computer and not install windows. The command prompt will open, try to troubleshoot from there.. Thanks!
Mar 19, 2013 | Computers & Internet
Pls,i have a nc6000 Hp laptop of 40GB Hard disk, 1500MHz processor and a 256MB RAM which i added 512MB RAM to upgrade to 768MB RAM. It started to freeze/hang and prompting the mouse cursor to...
from the off position, turn on, continuously hit the F8 key to force the startup menu, select last known good configuration and reboot. If this does not work, do the F8 thing again, and select safe mode. If you cannot reboot, you will have to do a clean reinstal using your factory recovery CD. If you can get into safe mode, immediately start saving your files to whatever media device you can.
go to start/run and type cmd and hit enter - type in chkntfs /c e and hit enter, reboot. This will start and system checking procedure on bootup. Again, if this does not fix things you will have to boot from your recovery CD.
Jun 16, 2011 | HP Computers & Internet
Blue Screen of Death
yeah unfortunitly you might have to reformat the entire hard drive and start from scratch
May 05, 2010 | Dell Dimension 3000 PC Desktop
Dell inspiron 6400 freeze after startup
do a system restore before it started doing it.
Nov 08, 2009 | Dell Inspiron 6400 Notebook
P28 laptop blue screen it starts up with the windows logo then shuts down
hello
i have problem my laptop no work and i search laptop P28. i want buy model laptop P28. i need in changer block mainboard for loptop P28
If you can me help. please help me. i buy old laptop Samsung P28
hope you help me
Thank you
my e-mail: Live29@yandex.ru
Sep 24, 2009 | Samsung V25 XVC 2800 Notebook
Freeze and black screen after re-boot
Go into bios screen and set the settings to optimal default and save then try again. if this gives you no results try f8 at the windows starting screen and safe boot if this allows you to enter window in safe mode your problem is outdated drivers. try any old vga video card and again see if you can enter windows normaly. and remember do not get frustrated this is how we all learn how to fixya.
Sep 22, 2009 | Computers & Internet
Freezes on startup
just call sony and talk to an operator and they'll send u a box to send your consule to them. You'll need your receipt though.
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
Samsung p28 laptop will not boot up
Do you not have a Reoery disk with this machine?
Jun 22, 2007 | Samsung V25 XVC 2800 Notebook
Computers & Internet Logo
195 people viewed this question
David Payne
David Payne
