Question about GE Monogram ZE2160SF Convection / Microwave Oven
Complete Shut-Down My GE Monogram completely shut down. It is as if it is completely unplugged. I re-set the circuit breaker, but it did not work. There is power to the outlet. Is there an internal fuse that I can replace?
  • jim06 Sep 01, 2008
    The microwave shows the clock display, but the clock has stopped. Pressing any button does not give any results. Nothing works. There is also "o" with two dots above it in the upper right hand corner and a flashing bar in the upper left hand corner.
  • GE Master
  • 9,098 Answers
I woulds first suspect a blown internal fuse or a thermal cutout on the magnetron in your case, but a microwave can be dead for many reasons.
If it goes dead for just a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power on again.
If it's intermittent or random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya:
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Posted on Nov 25, 2007
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Ge profile space maker xl 1800 shut down during cooking
Unplug unit..reset circuit breakers..check agin and then see if it starts up. It may need drying out due to excess steam
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My unit will shut down completely periodically
Some appliances do not work well when used on a gfci protected circuits. Move the microwave to an outlet that is not reqiured to be gfci protected and it should work fine . If you do not have a dedicated outlet for your microwave , it is a good idea to install one , or have an electrician install one for you.
Jan 07, 2010 | GE JVM2070 Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
JVM1850BH02 Microwave completely shut down, not working after...
The extreme heat has opened up one of the thermostats / thermal cutouts (TCOs) in the oven.
If it was the bottom TCO or magnetron TCO, you should be able to access them by just removing the control panel.
But if it's the one on top of the cavity, the oven will have to come out of the wall, then you need to pull of the outer cover..
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You should locate and look this over first.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver XL 1650 microwave shuts off after a few seconds
this would be the digital control board that would need to be replaced
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
After self cleaning the range the door won't open....
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Hope this may help;
Sep 06, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
My GE Microwave oven, blows the circuit after running for a short while
I sent you private e-mail.
Door switches or problems with wiring or the breaker, or something esle on the same breaker (a "no no") are the most likely problems.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 09, 2007 | GE JVM1630 Microwave Oven
GE Monogram ZE2160SF Convection / Microwave Oven Logo
662 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
