Question about Ovens
The transformer in our ge double oven is broken and we are unable to find a replacement part. GE says the part is not available and we have searched the internet as well.
  • 67 Answers
If you have the specifications for the transformer try Radio Spares? Other than that, try, take the transformer to a motor/transformer rewind shop.
GOOD LUCK
Posted on Jul 29, 2009
Ge double oven f1 error model jkp55wot1
F-1 error code.
Sometimes one or more buttons on the touch panel "get Stuck"
Nothing you can do to reset them, Good Luck.
Many times it means the touch panel needs to be replaced.
Jul 09, 2014 | GE Profile JTP56 Electric Double Oven
Installation instructions and manual
Most of the installation manuals for GE appliances are available on their support page: http://www.geappliances.com/ge/service-and-support/literature.htm . I found several double wall oven models with the JKP27 designation. However, the G0J4BG does not fit as part of the model number. There should be 4 letters after JKP27 in the model number. These letters primarily indicate the color of the exterior. For the JKP27 models, the installation manual says that the cut-out should be 32 1/2" above the floor. The depth has to be 23 1/2". The cutout width should be between 25" and 25 1/4" (these are an absolute minimum and maximum). The cutout height should be between 27 5/8" and 28 1/8".
The direct link to installation manual for one of these ovens is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003675840.PDF . See page 6 for the cut-out dimensions.
I hope this helps.
Feb 05, 2018 | GE JKP27 Electric Double Oven
GE profile wall oven transformer part WB20X5063
I have one WB20X5063 in stock in original GE Box unopened.
LISI in Miami 305-653-2284
Apr 16, 2013 | Ovens
Jrp24bod1bb GE Double Oven
you would need a minimum of 48&1/8" high,23&1/2" Deep, and 22&1/2" wide and 14" off the floor for ventilation per G.E quick specs
Feb 18, 2013 | GE JRP24 Electric Double Oven
How to install GE JKP35DPBB 27" Double Electric
The specs for this double oven give a rating of 5.1kW at 208V so it needs a 30 Amp circuit breaker. This assumes that the oven is the only appliance on the circuit. So you should be able to use the same circuit breaker.
A bigger consideration is that the opening for the double oven needs to be larger than that of the single oven. If the opening does not have a solid bottom, it must be able to support a heavier load. The runners and braces under a single oven has to support 200 pounds (91 kg). A double oven must have braces and runners designed to hold 375 pounds (171 kg).
Also check if your household uses aluminum wiring. The new oven has copper and problems will occur at the interface if you do not use the appropriate precautions. (Products designed for mating copper and aluminum are available - follow the directions).
I hope this helps.
(btw: you can find the User's Guide and Installation manual for the double oven at GE's website: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JKP35DPBB . See the section Literature and Manuals on the left hand side of the page below the picture of the oven.)
Oct 29, 2010 | GE 27" Built-In Double Electric Convection...
My ge jtp56woa1ww double electric oven will not bake in the top oven. broiler in the top oven seam fine. Lower oven functions great in both features. What to do?
Sounds like the bottom element, or element wire in the top oven is burned out, Check to see if the element is broken, or swollen. Two signs of a burned element.
Oct 08, 2010 | GE Profile JTP56 Electric Double Oven
Oven door
Contact your nearest appliance store. Most have GE parts in stock. This may be more available than you think. I have seen someone take tempered glass and literally glue it with special heat resistant glue and it looked really pretty nice. The edges were beveled and not sharp. This of course is a last resort.
Feb 05, 2009 | GE Ovens
Bottem Oven Over Heats
GE announced a recall for some of its wall ovens this week for an overheating problem. Have you contacted a GE dealer yet?
Nov 20, 2008 | GE JRP24 Electric Double Oven
GE monogram double oven display getting extremely hot
Usually the knob type controls uses the bulb for temperature regulation. There is usually only one adjustment available - otherwise the thermostat has to be replaced. - that dial with the temperature graduations on it. the whole unit - the bulb in the oven is connected to it.
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Ovens Logo
49 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
