Question about Nokia N95 Cellular Phone
Blueant not working when buttons pressed
My Nokia N95 pairs up with my Blueant ST3 all right, but when a call is coming in, the Blueant won't respond whether I push the green button, or try voice response, which the Blueant stated was OK.
I can answer by pressing the button on my mobile phone, and then talk via the Blueant, but I can't then end the call by pressing the red button on the Blueant.
I can make calls out using it, as these don't require any interaction with Blue Ant itself.
Any suggestions?
My new iphone 4 wont connect to my blueant st3 device. I know how to pair it and have followed the process on both the phone and st3, but the phone simply keeps searching in Settings - Bluetooth and the...
To connect iphone 4 to Blueant when its not responding, try turning off the Blueant using the Green MFB. Once it has powered down hold the green MFB and either one of the volume control buttons until a siren sound goes off. The voice will say a few things and then it should be reset. Turn off again and then back on again and it should be ready to discover your phone.
Feb 17, 2011 | Cell Phones
Im trying to pair my iphone with my blueant but it keeps saying (make sure blueant st3 is turned on in range and ready to pair)
First off the device you are referring to is a ST3 and not a Z9. What you need to do is put the device into pair mode prior to searching in your iphones bluetooth menu, to do this with the device off hold down the green button until you hear a language loop. When you hear the language of your choice let go of the green button and press it once right away. You will hear a message about your phones bluetooth menu, when you hear that go to your Iphones bluetooth menu and select the ST3 and it should work.
Regards,
Rylan
Dec 04, 2010 | Blueant Z9 Wireless Headset
I have recently got a Samsung Galaxy S I9000 and when I try to connect to my blueant st3 a message comes back that the blusant rejects the pairing with the phone. I used to use the bluseant with a nokia...
Darrell 12/11/2010. make sure you have the phone set to sync then press green button on ST3 until it ask what language you require keep it pressed until it states on the screen that you want to sync press ok and you will find that it has connected. You can use the same system to sync it to an I Phone as well
Nov 06, 2010 | Blueant Blue Ant 091193 Supertooth II...
Having difficulty pairing BlueAnt ST3 with Blackberry Curve. Blackberry recognizes BlueAnt but does not accept code of 0000. Says "connection failed"
Make sure the device is in pair mode, to put it into pair mode hold the green button down until you hear a language loop (with the device off). When you hear the language of your choice let go of the green button and press it once right away. When you hear that go to your phones bluetooth menu and enter pin code 000 when prompted. If this does not work do a hardreset on your phone by removing the battery while it is powered on, when it is back up research and repair and it should work.
Rylan
Oct 14, 2010 | Blueant Supertooth 3
Cannot pair blueant ST3 wih Nokia 6300
Reste the ST3 and then pairi again. It worked for me. Check this link:
http://www.myblueant.com/knowledgebase/reset/st3.php
Deven
Dec 25, 2009 | Blueant Blue Ant 091193 Supertooth II...
Blue Ant ST3 will not recognize 0000 passcode.
  1. If the Supertooth 3 is on, turn it off by holding down the green Multi-Function button for about 5 seconds (until you hear a voice announce "BlueAnt ST3 powering down").
  2. Hold down "Vol +" and the green Multi-Function button until you hear a loud siren/distinctive tone.
  3. The Supertooth 3 will turn on. Hold down the green Multi-Function button for about 5 seconds to turn it off again.
  4. The Supertooth 3 has now been reset: all pairing and other information has been deleted. When you turn the Supertooth 3 back on again it will prompt you to select a language and then go into pairing mode.
You will now need to re-pair your phone with your Supertooth 3.
Jun 11, 2009 | Blueant Blue Ant 091193 Supertooth II...
My g3 iphone says blue ant st3 password incorrect but it's the only one they give you...won't connect with my phone
Hi - I had the same problem setting up my 3G S. Here's the solution. In "Settings/General" set the Bluetooth to "ON". Turn your ST3 OFF by holding the green button until she says it's Powering Down. Now press and hold the green button ON until Language Selection (British English) option. Select language by pressing green button again. Next she will say "Device Found-Paring Successful-Enter password 0000". Enter 0000 and your phonebook will start downloading. There ya go!
Jun 07, 2009 | Blueant Blue Ant 091193 Supertooth II...
The phone won't pair up with the blueant st3
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
May 27, 2009 | Nokia N95 Cellular Phone
Can not pair with my new Blackberry storm - Help???
Make sure the BlueAnt Supertooth 3 is turned OFF.
  1. Press+Hold the Volume Up button and then also press the green button to reset the unit.
  2. After completing the above reset, turn the ST3 OFF again and wait at least 10 seconds.
  3. Turn unit back ON and select language when prompted.
  4. Follow the voice prompts and pair the ST3 with your blackberry as normal.
  5. After pairing has completed you will hear the ST3 announce “loading phonebook – please wait”.
When your blackberry ask your permission to allow bluetooth to connect and donload phonebook allow it permanently.
May 04, 2009 | Blueant Supertooth Light Bluetooth Speaker...
Nokia N95 Cellular Phone Logo
143 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
