Question about Maytag Neptune MAH5500B Front Load Washer
Faulting out on LR - Maytag Neptune MAH5500B Front Load Washer
  • 15,935 Answers
The LR error on your non-spinning Maytag Neptune is usually, though not always, accompanied either by a burn spot or a blown fuse on the Motor Control Board.
Maytag upgraded the motor and motor control board because this problem was so prevalent. Big rash of these a few years back... and insludes replacement instructions with the kit.
The LR code means "locked rotor" which is just a way of saying the control is not seeing the motor turning.
The image below contains the wiring diagram for this washer as you requested but there are some other things to consider.
Usually when the LR code is displayed the motor has stopped turning for some reason.
By definition the LR code means the control has tried to turn the motor but was unable to.
The error code can be caused by to large of load, to much soap/suds in the water or a problem with the spin bearing.
The cause of the LR message can be little problem like suds or a major problem like the spin bearing and sometimes it's difficult to pin down.
You don't mention in your question if the LR code occurs every load or once a week.
Try running a rinse and spin cycle empty and see if the washer completes the cycle.
The 2nd image contains the information on how to enter and run a diagnostic cycle which may help pin the source of the problem down.
This test completes all functions of the washer is a short time. It will fill, tumble, drain and spin all is a few minutes.
At the end of a successful test cycle a PA should display which means "Passed" and is what you want to see.
Image 1: http://media.fotki.com/1_p,sqwrrqkkqkstsftxgtqsskgwtqkq,vi/kkwrfdskkxkgbffwfww/1/1303472/5961857/image53872img-or.gif
Image 2:http://media.fotki.com/1_p,sqwtrsgdwsqtqsqxgtqsskgwtqkq,vi/kkwrfdskkxkktggsfsw/1/1303472/5961857/image53908img-or.gif
From another source..."Installing replacement motor, motor control harness, and motor control circut board.
Pretty easy install. On a scale of 1 to 10 (ten being hardest) I'd call it a 3.5. If you can use a screwdriver, a wrench, and have played with legos before, you can probably do this job. It took me about 3 hours to do, but this was with inferior tools, and two smoke breaks included.
Minimum tool requirements: Adjustable-head cresent wrench (8 or smaller handle), phillips head screwdriver, utility knife.
Recommended tool equirements: Small ratchet with socket set, ratcheting screwdriver with phillips head and small socket attachments, brew.
The instructions are pretty clear. Once you pull the front panel off, there are two braces at 45 degree angles on the lower corners of the washer. The instructions don't ask you to, but I would remove the brace on the left to make life easier. This gives your arm more room to work and makes it easier to pull the motor out the front.
They ask you to remove the wiring harness from the motor first and then pull the harness out with the control board. My wrench was too big to get to the bolt to remove the harness from the motor. All I did was cut the harness - since they supply a new one - then pull out the control board, then pull out the motor. As far as getting the pulley off, slip it on and off at the large wheel, this is much easier than taking it off at the small motor drive shaft. The only other thing of note is to make sure you look at the diagram for the conectors a few times before you snap it together. There are a few ways you could hook it up wrong so pay attention. There should be no loose ends when you finish. Also, I couldn't get the flange back on on the rear acess panel when closing it up, but it doesnt seem to serve muc purpose besides asthetics, so I tossed it.
The $200 for the parts and shipping was well worth it. I saved about $150-250 to do it myself...."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$
Posted on Oct 01, 2010
My 1998 cad. seville sls reads check underbody , do not exceed 90 mpr, what could be wrong ?
SPEED LIMITED TO 90 MPH -- 113
When the RTD detects that a suspension related malfunction desist and the PCM has received a class 2 message to limit vehicle speed. The PCM sends a class 2 serial data message to the IPC requesting that this message is displayed.
RTD
Real Time Damping
Your best bet , take it to the cadillac dealer
DTC C1326 Battery Out of Range
DTC C1650 RSS Control Module Fault
DTC C1658 RSS Control Module Calibration Fault
DTC C1710 LF Damper Actuator Short CKT to Battery
DTC C1711 LF Damper Actuator Short CKT to Ground
DTC C1712 LF Damper Actuator Open CKT
DTC C1715 RF Damper Actuator Short CKT to Battery
DTC C1716 RF Damper Actuator Short CKT to Ground
DTC C1717 RF Damper Actuator Open CKT
DTC C1720 LR Damper Actuator Short CKT to Battery
DTC C1721 LR Damper Actuator Short CKT to Ground
DTC C1722 LR Damper Actuator Open CKT
DTC C1725 RR Damper Actuator Short CKT to Battery
DTC C1726 RR Damper Actuator Short CKT to Ground
DTC C1727 RR Damper Actuator Open CKT
Aug 10, 2017 | Cars & Trucks
Why does Land Rover Dicovery display "engine system fault" on dashboard please?
The engine's computer has detected a problem with the operation of the engine and the warning you have means you need to take the LR into the LR dealer or to a LR specialist who can scan the engine for the fault codes that the computer will now be generating. It may be a minor issue causing this but until the engine is scanned and the fault codes pulled up you cannot begin to diagnose the cause of the problem.
Don't delay having it checked out because if it is a significant issue that might get worse the computer can send the engine into "limp mode" and in that event the vehicle will be low on power and will only be able to be driven quite slowly.
Jun 19, 2016 | 2007 Land Rover Rover Discovery
I have a 2005 dodge caravan the ingine light came on today the codes read p1776 and p0700 what does the codes mean
i'd go with the Transmission Control Module being the cause , either loose connection or worst case needs new unit
Oct 14, 2014 | 2005 Dodge Caravan
What this code is p-1784
P1784-LR PRESSURE SWITCH SENSE CIRCUIT
This is a transmission fault code. Diagnosing it will require the DRB3 scan tool, or equivalent aftermarket scanner, and the transmission simulator tool.
Remove the VB(valve body) and the solenoid pack is easy to change and a shift kit comes with a non stick switch valve.In most of the cases is faulty solenoid pack causing this eror code.But there are other possibilities to.
When Monitored and Set Condition:
When Monitored: Whenever the engine is running.
Set Condition: The appropriate code is set if one of the pressure switches are open or closed at the wrong time in a given gear.
POSSIBLE CAUSES
LOSS OF PRIME P1791 PRESENT.
RELATED RELAY DTC
Feb 23, 2011 | 2000 Jeep Grand Cherokee
My washing machine now reads lr and wont spin or wash
The lr fault code simply means Locked Rotor.This indicates that the main motor is not being detected as running by the control board in the console.This could be a wiring problem between the motor control board in the right hand base area and the main control board up top.Itmost likely is a failed motor control board or drive motor.
Aug 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
What does Lr on the display mean? There was a considerable amount of water on the floor and in the machine. I could not get the door to unlock to see what was going on, it just beeped several times and...
the LR code means "Locked Rotor". when this happens the cause is one of two items. 1) the circuit board at the top of the unit has lost connection to the motor and its control board at the bottom (connector loose) or 2) the motor and or control board at the bottom have trashed and need to be replaced (P/N 12002039).
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Service and repair manual above.
May 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
What does C1175,C1236 and U1900 mean?
For
C1175 - Speed Wheel Sensor LR Input Circuit Failure C1236 - Speed Wheel LR Input Signal Missing U1900 - Communication bus fault
If the cluster is working fine, ignore U1900.
There are so many recalls and so many technical bulletin for the problems on Ford 350.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | 2006 Ford F 350 Super Duty
No spin
Code Lr indicates a fault or failure with the motor. Manual refers user to contact a service rep. First check your warrantee and do a look up on recalls (you can use the Maytag homepage) as some of the earlier versions of this model were recalled and Maytag has agree to some forms of restitution/repair and or replacement assistance.
Dec 10, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
