Question about Haier Mechanical Air Conditioner HWF05XC7
Fan stopped turning
I have a Haier room a/c model #HWF05XC7-E, it is less than 1 yr. old and it ran great until the fan stopped spinning. I can spin it and it will run freely until it shuts down and won't restart.
    Guru:
  • 588 Answers
Check yhe capacitor.
Posted on Aug 25, 2009
Haier HWR06XC9 fan stopped working
Either the fan motor
the fan control relay
or the fan control relay switching transistor
the unit is re starting because the gas is not getting cooled
If competent check for voltage at the fan and work you way back
Apr 14, 2014 | Haier HWR06XC9 Air Conditioner
I need to order a new fan for inside my air conditioner
Hello, here is a link for parts for your AC http://www.searspartsdirect.com/partsdirect/part-model/Haier-Parts/Room-air-conditioner-Parts/Model-HWF05XC7/3126/0904032/50033646/00001
Jul 13, 2011 | Haier HWF05XC7 Thru-Wall/Window Air...
NuTone LS100 fan is squiling when it runs. Spinning the fan blade by hand when it isn't running doesn't make any noise. Am I correct in thinking that the motor needs to be replaced?
Sounds like it may actually be the bushing pack inside if the motor. Spinning the blade by hand is not going to spin it fast enough to hear the problem. If the unit is new, I would recommend returning it for exchange of a new unit. If it more than 1yr old, it's out of warranty and will be cheaper to just replace it rather than repairing it.
For less than $100 you can buy a newer, more efficient model. Depending on the size of the room is how should judge what unit to buy. An under sized unit will not pretty much nothing, except make noise and remove some of the steam. Remember to buy a fan with the lowest SONE rating as it will have the highest quality motor housing and best air removal.
Keith
Feb 28, 2011 | Broan-NuTone N-LS100 Exhaust Fan Exhaust...
The fan stop turning, this machine is a year 1/2 old
check to make sure that the motor is getting power, if it is then just replace the motor. You have a good unit, so it is worth spending the 50 dollars and replacing the fan motor
May 24, 2010 | Haier Mechanical Air Conditioner HWF05XC7
Gateway M-7315U "Major Fan Error" will not boot up, This is what it says on black screen when I turn on the laptop "Major Fan Error" and the fan is not spinning at all, How do I fix this problem? What is...
no need to buy a fan if u can uncover your laptop spin the fan through yr finger is it spin smothely or not & also check the fan jack inserted properly or not clean the fan with brush repack switch it on if problem persist contact me
Feb 24, 2010 | Gateway M-7315U Notebook
Won't "kick" on
need a little clarification but will try to answer....if the fan is not spinning or no air is coming out, then try taking off the front cover and spinning the fan by hand (With unit unplugged). it should spin freely and not feel rough or stop suddenly. if so the fan motor is bad. now if the fan motor works but the air does not cool then the compressor is not turning on in which case either 1. you are too low on freon (leak), 2. the compressor has gone bad, or 3. there is a wiring problem or bad run capacitor. i find it odd that this would happen to 2 units over the same storage period, any out-of-the ordinary environmental situations there? water damage? it could simply be a wiring short also.
Jun 09, 2009 | Haier ESA306 Air Conditioner
The fan won't turn on one of my HWF05XC5's
unplug unit, remove the screws that hold on the front cover, pull off front cover and try to spin fan by hand. it should spin freely and feel smooth and take a while to stop; it should not have any play or feel rough, or stop suddenly. if any of the above problems are observed, the fan motor is bad if the compressor comes on but the fan does not. if the fan spins freely but just does not come on (and compressor does) it could also be a wiring issue. if you have no compressor or fan action, try another outlet and check to see if the breaker at the end of the cord is set to "on".
Jun 09, 2009 | Haier HWF05XC5 Air Conditioner
Fan stops
The cooling fan for the condenser is probably running, getting hot and seizing up. Check to see if the fan is free spinning after it stops. Take a probe and try to spin it manually. If it turns freely, then it could be going bad with it's electrical windings, the internal coils that create the magnetic field that spins the rotor of the fan motor. I suspect it is seizing up, however, once a fan seizes up, it usually stays that way and won't spin even after it cools down. It could be a capacitor that is going bad and not starting the fan after it gets hot. A capacitor is a small round shaped can type with usually 2 wires hooked in series with the motor it is trying to start. That is what it does, help start the device (compressor or fan motor). Good luck.Ken from Henderson NV.
May 30, 2009 | Dometic Rooftop RV Air Conditioner
On my two stage snow blower--main auger stops turning .
Hi, I figured out the problem. The gear transfer case between the augers must be broke. The auger spins slowly until it hits snow and then stops-- The discharge fan continues to spin fast. I will try to get a local handyman to fix it or else but a new machine, this one must be at least 15-16 years old.
I thank you for your help, it is a great service. ojohn
Dec 10, 2008 | Garden
Haier XQBM22-C washer stopped spinning
It still doesn't work! I don't know how to fix it.
Mar 07, 2008 | Washing Machines
Haier Mechanical Air Conditioner HWF05XC7 Logo
231 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
