Question about Kenmore Washing Machines
Change keeps getting into the pump of washer - Kenmore Washing Machines
  • 99 Answers
Remove change from pockets before wash.
Posted on Jul 30, 2009
Is there a fuse for the washer fluid pump?
Yes; but it usually is tied into other systems, if everything else is working, then more then likely it is the washer motor. Turn on the ign. and have someone hold the washer handle in and tap on the washer bottle (that is if you can get access to it) If the pump starts working keep it running for a little while then start and stop it 4 or 5 times. The problem with washer pump motors is you only use them occasionally and because of that then can seize up. If you get the motor working use it every now and then to keep it loose.
Mar 06, 2013 | 2001 Oldsmobile Intrigue
The ul keeps coming whether it be one small sock or filled with bedsheets. I put a new pump on thinking the old was not pumping all the water out causing it to ul. Nothing has changed. Please advise
this is usually a main control circuit board problem...you can try and clear the board by unplugging washer and get access to board area.. unplug the touch pad and wait two minutes..now leaving touchpad off..plug washer in for tw minutes...now unplug the washer and install the touchpad and put together and plug washer back in...this should clear codes..if it works ok Great..if not, order main ccu board
Jan 21, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
The washer keeps getting stuck on F
The reason for "F" flash is that if your machine doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely if it's frozen or stiff replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thank you !!
Jul 25, 2010 | Kenmore HE2 Plus Front Load Washer
What oil to use in the power washer water pump
Oil used in engine is SAE30, I would suggest adding bit of Nulon or similiar Teflon based before even first run as it will extend life of the engine, This is air cooled Honda and therefore overheat easy.
Oil used in pump is Universal Tractor Transmission Oil.
Except two, all pumps are equiped with sight glass, fill as indicated on sight glass or dipstick.
To extend life of your equipment, change oil in both, engine and pump after 50hrs.
If you live in colder climates, where freezing is possible, do not forget to drain pump and high pressure hose from water to avoid winter damage.
Hope this will help keep your equipment in top notch for years to come:-)
Jun 22, 2010 | Northstar Pressure Washer 3000 PSI
2003 kia rio- water pumps
I would follow the mechanics recommedations. I think he's taliking about the cam and crankshaft seals. Yes the water pump should be replaced as well. The pump that sprays windshield washer fluid onto the windshield is called the windshield washer pump. The water pump is on the engine and pumps water (coolant/antifreeze) through the engine to the radiator and heater core.
Oct 29, 2009 | 2003 Kia Rio
Why do we keep getting pennies in the drain pump? We search our clothes carefully but apparently it is only pennies. Is there a possible broken screen?
no broken screen when washer goes in to spin the pennies move up the inner tub to the outer tub to the pump inlet remove pennies from close
Oct 14, 2009 | Maytag Bravos MTW6600T Top Load Washer
Loose change keeps getting into the water pump and then the pump goes out.
This is simple ... remove the change from the dirty clothes before you put them in. Put the money in your pocket ... or better yet, put a vacation jar on top of the machine and start saving for your next vacation or special event.
Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Jun 05, 2009 | Admiral AW22 Top Load Washer
My washer gets so far then says fp
fp indicates a pump failiure so either clean the pump filter, or if the pump filter is clear then you will need to replace the pump as this is indication of a knackerd pump
Jan 24, 2009 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
