This is part two for today. I have a new three week old front loading Frigidare Washing machine and when I put even a small load in it I can't hardly see any water. I know some comes in but I can't imagine that its enough for good rinse. I also see soap suds in the machine just before the final spin. Should I see a water level even an inch or two above the bottom of the glass window?
  • bdeacy Jul 29, 2009
    Thanks for the quick response. How can the clothes be rinsed free of soap with such little water? I still see soap suds before the final spin.
  • 305 Answers
Not always, most new machines are environmentaly friendly, and use very little water...i have just purchased a new washer drier, ( whirlpool ), and this uses very little water also.....but clothes are always spotlessly clean
Posted on Jul 29, 2009
Hi, I have a frigidare affinity front load washing machine and when it is running a cycle it sounds like the drum is banging around in the machine. It's a new noise, did something come loose? What
Hello gen0313 - From what you are describing it sounds like the unit could possibly have a broken shock/bearing or damaged tub. A certified technician will need to accurately diagnosis the bearing and pulling system behind the drum for repairs.
Feb 21, 2013 | Frigidaire Affinity ATF7000E Front Load...
MY FRIGIDARE INFINITY WASHER STOPPED SPINNING AT ANY CYCLE...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2011 | Whirlpool GHW9200L Front Load Washer
Frigidare washer, model LST6000ESO will not spin water out of the clothes.
heatman101
Jun 25, 2011 | Frigidaire Washing Machines
I have a Whirlpool Ultimate Care that was present in the house I rent; thus, I wasn't sure how old it was. It developed a loud grinding noise but continued to work until two days ago when it stopped...
I would put the money towards a new machine. I would also go with a basic direct drive top load machine. As you can probally see from this forum the appliance repair business is very busy mainly because of the constant electronics failures. If you go with a more energy efficient modern front load machine buy the extended warranty it will be worth it for just one repair.
Sep 09, 2010 | Whirlpool Washing Machines
Daughter washed a feather pillow which fell apart in front load frigidare washer now it wont spin and drain can u help plz?
The drain is plugged...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 30, 2010 | Frigidaire ATF6000ES Front Load Washer
Front Load Frigidare washer bouncing on spin, very bad!!!
Hi, not sure if you have resolved this or not, but you need to remove the 4 shipping bolts with spacers from the back of the washer. Thanks
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool front loader not working - Control Lock Light On
Press the End of Cycle Signal for 3 seconds until the Control Locked light turns off.
Apr 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What type and or brand of detergent is recomended
Use only the HE high efficiency detergent in a front load machine and only the recommended amount.
The brand is your choice.
Mar 19, 2009 | Frigidaire GLTF1670A Front Load Washer
Frigidare Model # FTF2140FS1 problems with spin cycle
not a very sturdy pedestal, front loaders need concret solid base
Mar 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Jan 20, 2008 | Washing Machines
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
