Question about Panasonic PT-50LC13 50" Rear Projection HDTV
How do i replace the bulb? How do I find the air filters?
  • fredv8 Aug 03, 2009
    Thanks for the assistance. I replaced the lamp. Still no picture. I'll check the site to see what the next troubleshooting step is.
  • 167 Answers
There is a small removable door on the lower right or left hand side. It should have a screw holding it in place. Remove the door and you will see the Lamp assembly.This generally has a screw keeping it in place. Remove that screw and pull the handle attached to the lamp assembly and it will pull out.Make sure you buy a Lamp assembly that is complete with housing and not just the Lamp. You may not be comfortable swapping the new lamp into the old housing. Do not touch the Lamp with your bare hands or fingers as the oil from your skin can cause the Lamp to burn out prematurely. Take a small vacuum tip and vacuum out any dust inside the Lamp compartment before yor replace the Lamp.
Posted on Jul 30, 2009
  • Mark Wakefield
    Mark Wakefield Aug 03, 2009
    Make sure the Lamp compartment door is secured because there is a safety switch that will keep the TV from turning on. If it still don't work then it is time to call a good TV Tech for an estimate. There is nothing else you can do unless you are a trained TV Tech and have a training manual on how to work on this type of TV.
How do you remove the headlight bulb
  • Take the keys out of the ignition and switch the headlights off. Then, open the hood using the primary and auxiliary release latches.
  • 2 Use a socket wrench to remove the two 10mm bolts holding the coolant overflow bottle in place. Pull the bottle out of the engine compartment and set it on the ground (passenger's side bulb replacement only.)
  • 3 Undo the bolt at the top of the air filter box, lift the top open and remove the filter from the engine compartment. Then, undo the fasteners holding the air dam in place and remove it from the filter box (driver's side bulb replacement only.)
  • 4 Pull the entire air box out of the car to access the backside of the headlight assembly.
  • 5 Turn the bulb socket counterclockwise to remove it from the assembly. Then, release the retaining spring, undo the electrical connector and carefully remove the old bulb from the socket.
  • 6 Hold the new bulb by its plastic base and insert it into the socket. Reattach the electrical connector and replace the retaining spring.
  • 7 Switch the headlights on to test the new bulb. If it works, reinstall the air box or coolant bottle and close the hood
  • Dec 04, 2010 | 2000 Nissan Altima
    Light engine
    here is a forum that discuss the same problem you have.
    http://www.avsforum.com/avs-vb/archive/index.php/t-353230.html
    Essentially, on the right side of the bulb compartment is the filter compartment. Open it from the front and you will see the filter. There is only one screw to undo.
    Good luck
    smeags
    Jan 03, 2008 | Panasonic PT-50LC13 50" Rear Projection...
    How do i change the headlight bulb on my 05 uplander
    On my 2003 trailblazer (as far as I know they are the same), See note below for passenger side. Remove the dust cover on the back of the head light assembly (black round rubber cover about 3" in diameter, just pull it off), disconnect the plug on the bulb, turn the bulb a 1/8 turn and pull it out. Then reverse the process for assembly. ***NOTE***If you are trying to replace one of the bulbs on the passenger side, remove the air filter housing cover and displace the filter for access to the dust covers on the back of the head light. 2 screws hold the air filter housing cover on, one directly behind it and one on the side (drivers side of air filter housing).
    Aug 23, 2010 | 2005 Chevrolet Uplander
    Light won't go on; Model MMV1153WB-O
    You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
    Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
    Or just get it here, to be more exact.
    On page 4, it says:
    "Installing/Replacing Filters and Light Bulbs
    ■ Grease filter: Grease filter is on the underside of microwave
    oven. Clean monthly. Slide the filter away from the tab area,
    and drop out the filter. To reinstall, place end of the filter into
    the opening opposite the tab area, swing up the other end,
    and slide it toward the tab area.
    ■ Charcoal filter: The charcoal filter is behind the vent grille at the
    top front of the microwave oven. The charcoal filter cannot be
    cleaned, and should be replaced about every 6 months.
    Remove 2 screws on the vent grille, tilt the grille forward, lift it
    out, and remove filter. To reinstall, place the filter into its slotted
    area – wire mesh side up, replace vent grille, and secure with
    screws.
    ■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
    the underside of the microwave oven, and is(are) replaceable.
    Remove bulb cover screw, and open the bulb cover. Replace
    bulb, close bulb cover, and secure with screw.
    ■ Cavity light: The cavity light bulb is located behind the vent
    grille at the top front of the microwave oven, under the bulb
    cover, and is replaceable. Remove 2 screws on the vent grille,
    tilt the grille forward, and lift it out. Open bulb cover and
    replace bulb. Close bulb cover, replace vent grille, and secure
    with screws."
    HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
    You can find links to helpful exploded view diagrams and part ordering help here.
    I recommend that you bookmark that link to your favorites. Hope this covers it.
    William E. Miller
    prototech@usa.net
    http://www.microwavedisplay.com
    May 06, 2010 | Maytag Over-the-Range Microwave
    Primer button on homelite gas trimmer
    It's possibly the filter, can't help there. I would check for a split line or loose connection between the tank and bulb and even splits in the bulb itself.
    Apr 24, 2010 | Homelite Mighty Lite Lawn Trimmer
    How to change headlight bulb 2006 chevy trailblazer
    Jan 03, 2010 | 2006 Chevrolet Trailblazer
    The toro will start and run for 2 seconds then quit. We took apart the air filter and cleaned the gas line as well as cleaned the plug. No improvement. Thought it may have been bad gas or a plugged gas...
    I am not sure what type of carb you have so I will give you a couple of ideas.
    1. If the carb is one of the plastic ones that attaches directly to the gas tank take of the air cleaner and press the primer bulb. If you get a spurt of gas and not a stream of gas get a new diaphragm for the carb. It goes between the tank and the carb.
    2. If there is a sediment bulb hooked to the carb drain the gas from tank and then carefully remove the sediment bulb and clean it.
    3. If there is a sediment bulb hooked to the carb and a flat paper air filter attached to the sediment bulb via a plastic air filter holder with a primer bulb built into the air filter holder replace the gasket between filter cover and sediment bulb.
    good luck
    let me know if this works.
    roundo4
    Aug 12, 2009 | Toro Lawn Mower With Toro Power Tools
    Primer bulb won't prime
    it sounds like the filter on the fule line is cloged try to remove the filter and then try to prime the trimmer. it it does you need to replace the filter. just about any filter that will fit will do.
    Jun 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
    Replace headlight for 2005 Chev Trailblazer
    59Shadow.
    Thank you for sharing the information on the light bulb. You just saved me money from having to take my 2003 Trailblazer in to have the low beam bulb replaced. I did exactly what you said.
    1 Open hood and lock.
    2. Take filter cover off (4 screws and they stay with the filter).
    3. 3 inch cover pulls off.
    4. Twist light bulb 1/8 turn.
    5. Unclip the wiring harness to light bulb assembly.
    6. Test by turning light switch on.
    7. Align assembly with light housing and turn 1/8 until it snaps in.
    8. Put 3 inch cover back on.
    9. Place filter cover back on and hand tight the 4 screws.
    10. Close hood.
    Dec 12, 2008 | 2005 Chevrolet TrailBlazer
    Bulb replacement-J-VM 172-001
    check instruction manual, other wise you check microwavae oven tharoly...you replace bulb very easy.
    Oct 19, 2007 | GE JVM3670 Microwave Oven
    Panasonic PT-50LC13 50" Rear Projection HDTV Logo
    203 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
