When powering up our Whitaker Brothers SMC 2602, we show a steady red light indicator that is preventing the shredder from working. Is there anything we can do to fix this on our end?
The paper sensing switch lever has bent or broken or the switch is faulty. Check between the wheels about in the middle of the shredder to see if you see if the little plastic finger. If the finger is visible and can be moved, the switch is faulty. REMEMBER TO UNPLUG IT BEFORE DOING ANY INVESTIGATION.
Check to see if both the upper and lower blades are turning. If the motor is running and the blades are not turning, then it is probably just a broken gear.
When a set is powered up, there are internal checks that are performed. The initial green light indicates that power has been applied. The flashing red light indicates that a problem was found that is preventing the set from functioning properly and it has shutdown to prevent further damaeg. If you can supply the model number, I may be able to provide additional details. Also, check to see if the flashing red light has a pattern. Quite often the pattern will indicate what problem was detected.
Yes. There are two electromagnetic sensors (front and back). If defective, the main board will show a yellow or red light. These sensors function with the cabinet which is magnetized in the center (front and back).
