Question about Dishwashers
My maytag dishwasher MDBH970AWQ Quiet series 300 is more and more often not opening the soap dispenser. Also the number 9 flashes and can't seem to get it to go away. If I try to start the dishwasher over again with the hopes of the dispenser opening the dishwasher just runs for the countdown of 9 to zero. Help!
SOURCE: Maytag dishwasher legacy 300 quiet series
FYI... I followed Miss Midget's steps... and there it was... a piece of plastic... actually one of the end caps from the rack. Poor design if you ask me. So for all you "grinders" out there, it's an easy fix... just need the appropriate star screwdriver. It went back together easier than it did taking it apart. Thanks.
Posted on Nov 28, 2007
SOURCE: Maytag jetclean eq plus dishwasher: soap problem
clean the filters
Posted on Jun 19, 2008
SOURCE: MAYTAG QUIET SERIES 300 DISHWASHER MODEL MDB7600AWW
I had the same problem, my dishwasher needed a new brain. Cost around $150 to fix
Posted on Jun 21, 2008
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Posted on Dec 19, 2009
SOURCE: Maytag quiet series 300 dishwasher leaves glasses
If your dishes or glassware appear filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you’re using and adjusting your hot water heater’s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you’ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn’t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don’t use extra-hot settings such as “Power Scrub,” and use the “Energy Saver” dry cycle.
2) Adjust the detergent amount.
3) Don’t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading—dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home’s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20–120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn’t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals—the more grains per gallon you have, the more detergent you’ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn’t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn’t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn’t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren’t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Posted on Sep 03, 2010
How should I clean the Maytag Quiet Series 300 with vinegar?
just fill it with water no soap and drop in vinegar right in the water and let it run its cycle
Jan 27, 2015 | matag Maytag QuietSeries 300 Dishwasher...
Maytag Quiet Series 300 - it seems like the soap door is not opening and when it does the soap packets are not dissolving. I cleaned out all of the spray arms. That did not help. What else can I do??
  1. Be sure that you don't have something large blocking the dispenser door like a cutting board.
  2. Make sure the water temp is 125 degrees going into the dishwasher. Cold water won't break down detergent correctly.
  3. Make sure your getting water pressure: Run your dishwasher on normal. Wait until the cycle starts and the spray arms are spraying. Turn a cup right side up to catch water on the top rack if you run the dishwasher and wait 20 sec that cup should be half or full. If you don't have water in the cup you could have poor water pressure from your pump. This could indicate 1. Worn motor 2. Clogged pump
Have a great day!
Dec 07, 2010 | Maytag MDB7100AWB Dishwasher
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series 300 owners manual
my dishwasher does not want to work anymore it has a big L flashing
Jun 14, 2009 | Dishwashers
Maytag Quiet Series 300 Dishwasher will not turn off after it com
MY DISHWASHER KEEPS RUNNING, IT IS A WHIRLPOOL GOLD QUIET PARTNER IV
Apr 05, 2009 | Dishwashers
Maytag dishwasher quiet series 400. Dishes have hard stuck on grit and food particles after rinsed and dried.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
Mar 14, 2009 | Dishwashers
Dishwasher soap cup lid will not open during a wash cycle
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
jj
Dec 31, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
99 people viewed this question
Top Dishwashers Experts
