Brand new purchase from Amazon. I threw away the packaging so Amazon refuses to refund.
Celestron 31035 AstroMaster 76 EQ Reflector Telescope
All I see when viewing the moon is a slight white glow.
Yes the cap is off.
The likely hood is, that the scope needs collimating.
If you don't have a collimator, you can easily purchase one, online.
I discovered the same problem with my scope, until I collimated it.
There are many different types available, 'Red Dot' lasers, or just simply a pin hole in a eye piece fitment.
The 'catseye', is the one I got.
It may seem a little complicated at first, but after you have figured it all out works, it will become clear, and once you've collimated for the first time, it takes no time at all to re-collimate.
There ya go, fixedYa!
P.s, don't forget to give a good thumbs up thankyou :)
We were out last night trying to find the moon. It was driving me crazy then finally I got it in view. It takes some patience. The scope is hard to calibrate or we just are not doing it right. You can manually scan the sky and look for any light coming through the eyepiece. Then try to focus and slowly adjust the tripod to try and find the light source. Once you have it in view, you can't miss it. The moon filled the view in the telescope once we got it in view so it wasn't because the object was small or too dim to see.
