Question about Dryers
My General Electric Dryer will nor turn on. Is there some basic trouble shooting I could do?
    President:
  • 1,776 Answers
Make sure that the house breaker is not tripped for the circuit that the dryer is on. If that is ok, then look for a blown thermal fuse. It is usually located inside the back of the dryer and attached to the exhaust duct. It is about one inch long and can be checked with an ohm meter or multimeter for continuity. If it has none, it is defective and must be replaced. If the fuse is good, I would check continuity on the main dryer power cord. You could also check to see that the outlet the dryer is plugged into is providing the proper amount of voltage. Hope this helped and best wishes.
Posted on Jul 29, 2009
Replace hing on front load ge washer
Ge has a trouble shooting section on their website you type in the part you want. I hope this help
Dec 30, 2014 | General Electric GE WPDH8900J Front Load...
Dryer stops, restarts minutes later
It seems like clogged vent problem but as I always say The best method is to do your home work and you must do total trouble shooting procedure and replace defective parts if necessary and
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
Dec 07, 2013 | General Electric Dryers
My GE DHDSR46 gas dryer won't start, what should I
505 is the thermal limit.
Looks like this:themobilian_2319.jpg
Hunt for junk and clean that out, then replace this fuse if it is bad.
See the white button to the right of the driver?
Thats the door switch, if open, that dryer won't run.
More Here
May 07, 2011 | General Electric DHDSR46GGWW Gas Dryer
Dryer is about 5 years old. Has begun to squeak loudly when clothes begin to spin
Are you comfortable taking the dyer apart? There are just a few simple screws to remove. It sounds like a bad blower wheel. If you follow the link you should be able to trouble shoot the issue.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info
Mar 01, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
Basic order of troubleshoot - gas dryer, electric on (light on when opened), won't rotate or start, hear buzzing when pushing button. No section for Kenmore 70901 gas dryer on this site. I want basic order...
Buzzing as in end cycle tone? That would indicate a stuck switch on the motor and freeing it would buy time until new motor could be installed. Low humm as in motor is stuck and cannot turn would require removing belt and see if motor is stuck, drum is stuck or something in exhaust fan holding it back.
Eric
Jun 11, 2010 | Kenmore Dryers
I have a General Electric Clothes Dryer that will now turn on when I hit the start button. It is wired to a 220 circuit and is getting power to the machine. Model number DDE804SLKCWH Heavy Duty 18. Im...
There could be a number of things that would do that...As this tip will show you, the thermal fuse is the first place to start...
There is also a list of other things to check here also...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 07, 2010 | Dryers
My dryer will only heat on one setting on the timer.Is the timer bad?If i put the timer on any other setting it does not heat.It is a older Ge but has always worked well.
The answer is maybe....
The problem could be the timer, but most likely is something like the thermostat...
You will need to trouble shoot the problem to figure out what is going on there...
Here is a tip that I wrote that will help you...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 06, 2010 | General Electric DCVH680EJWW Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
