Question about Bose Car Audio & Video
Clock only works on bose wave system
Any button pressed except volume or time and clock flashes with a dot in lower right corner. Volume goes up and down but no sound, also i can set time. No aux,cd,fm or am.
SOURCE: Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Posted on Dec 21, 2007
  • 48 Answers
SOURCE: Bose AWR1-1W soundless
get bose to make a warranty replacement or repair, its not a user servicable part, infcat its going to be difficult to find the exact problem even if you REALLY want to open it up, it may also be a faulty opamp on IC not switching.
Posted on Mar 11, 2008
  • 48 Answers
SOURCE: Bose Wave System CD 2000 FM volume much lower cd stops if volume higher.
sounds like a loose cable from the control bard to , some one will have to open up to fix, i recommend bose do that for you,
as for fm volume, the same could be the cause as the fm antenna coudl be disconnected, ( are you using an external FM antenna ?)
rockmeister
  • 2047 Answers
SOURCE: Bose Wave Radio, Model AWR1-1W When turned on
Loud buzz is usually caused by static and radio interference in radios. If none of this is affecting you unit presently there there is a probability that some cables which aid the fm antenna in receiving stations this could act as static which brings about the buzz on the unit. Either way it is caused by interference on the fm receiver end and all you have to do is get that serviced and the problem is solved.
Hope this solution has been helpful?
Posted on Dec 30, 2010
dunnbiker
  • 8546 Answers
SOURCE: My bose wave radio 1
Not explicily, but on page 18 of the manual (Bose.com) clock setting is explained...
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
Posted on Sep 08, 2011
How do you make the number that tell time light up darker so you can read it.
If you want to make the display brighter (remember, it auto dims in low light):
1. Hold down the "clock set" button while pressing the "volume" button up or down (up for brighter, down for dimmer).
Jun 10, 2014 | Bose Wave Radio
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
My bose wave radio 1 somehow switched to military time. There is no clock set button?
Sep 08, 2011 | Bose Wave Radio
My Bose Wave is doing fine except that the brightness of the display in the front goes dim and bright, sometimes flickering. Most of the time it is dim and not readable. I did change out the 9V battery...
Hi.
This is a common problem with this model.
The LCD has a dimmer circuit that can be responsible, in some case it is not the dimmer regulation, but the LCD control circuit itself. In that case you have no LCD backlight and the display is almost unreadable. If that is the problem, changing dimmer settings with procedure below will not help.
Most of the time the problem is dimmer regulation.
About dimmer regulation:
Try disconnecting the unit power cord for ten minutes and connect back.
Try holding down CD or CLOCK button and pressing at the same time the volume buttons. This procedures regulates Bose dimmers setting in a scale from one to 9. The dimmer has separate settings for medium and low brightness. Set both to 5 if you want to disable dimmer settings.
Dec 09, 2010 | Bose Wave Radio
Radio display is not bright
Press and hold alarm time for about a second, then press your tune/playlist button until your bright hi or bright lo choices display, once you chose which lighting you want, do not press anything else. It will set to your last selection.
Oct 31, 2010 | Bose Wave Radio
SETTING THE CLOCK ON JVC AUTO RADIO
Press and hold SEL until menu appears
Using the scan button (FWD/REV), select Clock H
Using the volume knob, set the value
Using the scan button (FWD/REV), select Clock M
Press SEL to save and exit
Jan 22, 2010 | JVC KD-G230 CD Player
Pioneer super tuner3d
  1. Turn the radio off by pressing and holding the SRC button (under the label OFF).
  2. Press and hold the Audio button in the upper right corner of the radio. After holding the button for about 3 seconds, the clock will begin to blink (the hours).
  3. Use the up and down arrows to increase or decrease the time hours or minutes. Use the left and right buttons to toggle between setting the hours and/or minutes.
  4. When done, push and hold the Audio button again fir about 3 seconds until the clock stops blinking (hours or minutes).
Nov 16, 2008 | Pioneer DEH-1600 CD Player
Bose wave 2 .
Hi - You can download the manual from the link underlined in blue below:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 17, 2008 | Sony ICF-C273 Clock Radio
Bose wave does'nt display light ' can't see the time, Help
Hi
I read that if you hold down the Clock Set button and use the volume adjust you can change the display brightness.
Hope this helps with your rpoblem
Aug 09, 2008 | Bose Wave Radio
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Car Audio & Video Logo
Top Bose Car Audio & Video Experts
xxxxxx xxx
David Burbee
David Burbee
Bill Boyd
Are you a Bose Car Audio and Video Expert? Answer questions, earn points and help others
