Question about Motorola Radio Communications
What are the default frequencies for the Motorola ex500
  • 5 Answers
This radio does not have default channels. It is programmed with software to whatever channels are needed. You will have to take it into a Motorola shop to get it programmed or search the web for a programming cable and software.
Posted on Jan 11, 2018
What are the default PL codes for the Motorola VL50?
I don't have a VL50, but a CLS is frequency two, code one. There is a way to reset to Factory default: press & hold PTT switch and the Monitor as you turn it on. If I got it wrong, try the scan switch instead of monitor. How this helps, if you want the actual numbers, post again please.
Feb 11, 2015 | Motorola Radio Communications
How do you program the PL on a Motorola AUX4100 radio.
The AX series is factory programmed on default frequencies and codes, or dealer programmable from 435-480 MHz.
Here's a link to the user guide: http://acsspirit.com/brochures/ax_user_guide.pdf
Jun 04, 2014 | Motorola AUX4100 2-Way Radio
Can not change code and frequency
First, we would suggest resetting the radio to the factory default settings by turning the radio on while holding Push to Talk and Menu button for 3 seconds.
After doing this, check to see your radios function with one another. If they do, then proceed to programming the radio to the frequency/PL codes you are wanting. If the radios do not communicate after resetting them, one of the radios has a problem.
Here is a link to the user guide: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf You will find programming instructions on page 28, with a frequency chart located on page 26.
Best regards.
Jul 15, 2010 | Motorola CLS 1410 (4 Channels) 2-Way Radio
I need to get a manual for Ht1000 and ex500.
Unable to locate a PDF file for the EX500 or HT1000 online, however, here are the part numbers you can order by HKLN4118A for EX500 and 6881079C50 for HT1000.
Best regards.
Feb 10, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
Can i change the frequency on this router it is interfearing with my security system
http://broadband.motorola.com/consumers/products/sbg900/downloads/sbg900_user_guide.pdf is a pdf of your manual. On page 71 it shows a menu that allows you to select a channel.
"Channel" is another name for frequency. It probably defaults to channel 1, try setting it to channel 11. Or channel 6.
Jan 24, 2010 | Arris SURFboard SBG900 Wireless Router...
I HAVE 2 MOTOROLA RADIO' S MODEL# EX500 THAT ONLY TALK TO EACHOTH
Assuming you have checked all the channels for functionality, it appears your radios need reprogrammed. This is something which would require you taking the radios to your local Motorola dealer.
Jan 23, 2009 | Motorola Radio Communications
Motorola ex600 two way radio user guides
User Guide: http://southplainscomm.com/images/uploads/ex600.pdf
Refer to page 31 for explanation of zones. (You can have up to 16 channels in a zone.)
Parts list: http://www.wiscomm.com/MotoCatalog/EX500-600.pdf
Jan 08, 2009 | Radio Communications
How do I Reset my T5000 2 way radio to factory default
The T5000 Talkabout radio default settings are not the same as the CP100 and CLS. The CLS and the CP100 UHF are capable of being programmed to match one another on several frequencies, however, the TalkAbout T5000 is not capable of any of them.
The Talkabout radios, as a general rule, are limited to FRS and GMRS frequencies. The CP100 and CLS are from the business and light consumer divisions. They will do most of the common 56 UHF business frequencies.
If you would like to look at the frequency charts yourself, here are some links.
Here are the frequencies possible on the T5000 http://www.fixya.com/support/p514922-motorola_talkabout_t5000_2_way_radio/manual-362/page-17
Here is a link to the CLS radio manual
http://www.123radios.com/Manuals/clsmanual.pdf
Here is a link to a CP100 user manual
http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
Jul 13, 2008 | Motorola TalkAbout T5000 2-Way Radio
Radio Communications Logo
131 people viewed this question
Top Motorola Radio Communications Experts
Steve
Steve Allison
Steve Allison
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
