Question about Cell Phones
How do I hard reset the phone - Cell Phones
    Habit-Forming:
    New Friend:
  • Cell Phones Expert
  • 81 Answers
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS...
While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step).
A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key.
Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up.
Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK.
After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK.
Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen.
7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS.
Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit.
The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press the Volume up key to boot in this mode.
Wait for the "triangle!/Android" screen to pop up. Once it does press both the Volume up and Volume down keys simultaneously. A Recovery Menu should pop up.
Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection.
After it's done make sure "reboot system now" is highlighted and then tap the Power button.
In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through.
8. Here is a hard reset for a Sharp Android Smartphone.
While the device is off, hold the Sym button (it's located on the keyboard) and the Power button simultaneously.
Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection.
Scroll down to Yes - delete all user data and then press the Power key to confirm.
Once it is done select reboot system now and press the Power key to confirm and reboot your handset.
Important Note: On some Sharp models (such as the Sharp FX Plus ADS1) if holding the Sym button and Power key simultaneously doesn't take you directly to the Android system recovery screen you might have to do one additional step. If using this hard reset key combination takes you to a screen which shows an exclamation mark within a triangle, then press the Home key (while on that exclamation mark screen) and this should take you to your Sharps Android system recovery options.
9. Here is a common method used to hard reset an LG Android smartphone. So if you need to hard reset an LG Optimus this is the hard reset key combination to try first.
After the LG phone has been powered off, press and hold the Volume Down button. While holding the Volume Down button, press and hold the Home button. While holding both the Volume Down button and Home button, press and hold the Power button.
Continue holding these three keys down simultaneously until the LG logo appears.
Once the LG Logo appears release all of the keys. This will complete the reset on many LG phones; you will be given the option to "Select your language" and can proceed with setting up your device as if you were setting up the phone for the first time.
If however, you are taken to a fastboot screen or a screen with additional options then use the Volume Down key to scroll to and highlight the wipe data/factory reset option and then press the Menu key to make the selection.
The phone might give you a confirmation screen in which you can use the Volume Down key to scroll to and highlight Yes -- delete all user data and then press the Menu key to make the selection.
If you get an option to reboot system now then select that option with the Menu key. The phone will reboot, which can take a couple of minutes, and the hard reset will be complete.
10. A less common method to hard reset an Android smartphone, but the following key combination can be used to reset some cell phones including the Samsung Gio (GT-S5660).
Power the phone off, by using the power button or by removing and then reinserting the battery (when possible).
While the phone is off press and hold the Home button and the Power key at the same time (the Home key is typically the big button on the bottom center of the phone under the display/touch screen).
When the phone starts to power on and you see the phones logo you can release the power button but keep pressing the Home button until the Android system recover screen appears. Once it pops up you can release the Key(s).
Use the Volume keys to highlight the "wipe data/factory reset" option, and then use the Home key to make the selection. Scroll down using the Volume keys again until the "Yes-delete all user data" option is highlighted and then press the Home key to select that as well.
The system recover screen should pop back up and when it does make sure that "reboot system now" is highlighted and press the Home key to make the selection. The phone will restart and the hard reset will be done.
11. Another uncommon hard reset technique but similar to the one used in method #2. This process can be used to hard reset T-mobiles Prism and Prism II as well as AT&Ts Huawei Fusion (U8652).
Turn off the phone and then press and hold the Volume Up key and Power key simultaneously until the Android system recover screen appears.
Use the Volume Down key to highlight the "wipe data/factory reset" option and then use the Power button to make the selection.
Use the Volume Down key to highlight "Yes -- delete all user data" and use the power key to proceed with the reset.
Once the reset is complete the phone may return to the Android system recover screen. If it does then use the Volume Down button to highlight "reboot system now" and press the Power key to confirm the action.
The phone will restart and the hard reset will be complete.
More information about phone repair guides, you can ask help for Vip Fix Shop Team.
Posted on Dec 08, 2017
I have nokia 6680 I I forgot screen lock code when I turn my phone on it asking for lock code so now how I can open it ?
How can you forget a code you set and have been using multiple times a day? The default code is 12345. If you 'found' the phone, perhaps it is still set to the default.
NOKIA 6680 - How to Hard Reset my phone - HardReset.info
www.hardreset.info/devices/nokia/nokia-6680/hardreset/first-method/
Hard Reset NOKIA 6680. First method: Power on your handset. Hard Reset NOKIA 6680. Then please press and hold * key + 3 key + Call button + Power button, until you see Nokia logo. HardReset NOKIA 6680; After that enter your lock code. * The default lock code is 12345; Now your phone will reset and restart.
www.hardreset.info/devices/nokia/nokia-6680/hardreset/third-method/ Hard Reset NOKIA 6680. Third method: Switch on your phone. Hard Reset NOKIA 6680. Next press Menu button and goto Settings -> Phone -> Phone management -> Factory Settings -> Delete data and restore -> Yes Factory Reset NOKIA 6680; Then your device will reset and reboots. That's all. See the Previous method!
www.hardreset.info/devices/nokia/nokia-6680/hardreset/second-method/ Hard Reset NOKIA 6680. Second method: Turn on your cell phone. Hard Reset NOKIA 6680. You should now type this code: *#7370#; Then press your lock code. * The default lock code is 12345; After that your phone will reset and restarts. Success! See the Previous method! See the Next method! How to Hard Rest NOKIA ...
Nokia 6680 hard reset
www.hard-reset.com > Nokia hard reset Apr 3, 2010 - Nokia 6680 hard reset: Press these buttons * + 3 + call + Power on your phone. Before the device is reset, you need to provide the lock code. The default lock code is.
Nokia 6680 Hard reset - How To Factory Reset
https://www.hardreset99.com/nokia-hard-reset/nokia-6680-hard-reset-factory-reset/ Feb 18, 2017 - Nokia 6680 Hard reset and Factory reset. Forgot your android mobile Password or PIN or Pattern, Here you can get recovery solutions for free.
NOKIA 6680 Hard Reset - IMEI.info
www.imei.info/hard-reset-1350-nokia-6680/ Are your looking for a way to make your NOKIA 6680 work faster? Do you wish to clear all of the data on your NOKIA 6680 before selling it to someone else? Well what you need is the factory reset. What is it? Factory reset (aka hard reset) is an operation which deletes all data (including settings, applications, calendars, ...
videos
nokia 6680 hard reset Google Search
Mar 24, 2018 | Nokia Cell Phones
Bought a zte boost max from a person .took it to boost to switch my boost phone to zte and representative acidentially reset phone so now it says need old email address and passwordany way to fix
How to Hard Reset Boost Mobile ZTE MAX 9520 ... - YouTube
? 1:40
https://www.youtube.com/watch?v=SkMDrK5fWSA
May 17, 2014 - Uploaded by HARD RESET KING
Reset Hard Reset for ZTE ZMAX Locked with Google, Screen pattern or PIN - Duration: 1:59. by Klavdio ...
ZTE Boost Max - how to hard reset my phone - HardReset.info
www.hardreset.info/devices/zte/zte-boost-max/
Hard Reset ZTE Boost Max. First method: Turn off your phone. Format ZTE Boost Max; Press and hold Volume Up + Power at the same time for a few seconds.
How to: Factory Reset a BoostMobile ZTE Phone ...
https://raydatroubleshooter.wordpress.com/.../how-to-factory-reset-a-boo...
Jan 05, 2016 | ZTE Cell Phones
E52 HANDSET IS NOT BOOTING UP
Try doing a hard reset for the phone and then see if the phone works. A hard reset will ensure that the phone memory is formatted and all the factory settings are restored but doing a hard reset will delete all the files. To perform a Hard reset on the phone, Locate the following keys (* , 3 and talk/green key). Press all the above keys along with Power button and keep it pressed till Nokia booting screen appears. After hard reset, see if the phone is able to boot or not.
Regards
AJay
Oct 18, 2011 | Nokia E52 Smartphone
How to hard reset nokia 5130
You can reset it using a soft or hard reset. The following instructions provide you with information on how to reset the Nokia 5130 using both methods.
  • Soft Reset
The soft reset is often the better option if you are worried about losing data. There is a chance the soft reset will also default to the factory settings, but there is a bigger chance that it will not. With a soft reset you will enter in *#7380#. This tends to clear any pending errors and on most phones it will help your phone work properly.
  • Hard Reset
  • The code for Hard Reset is *#7370#. Enter these digits into the phone and press yes to confirm. This will start the initialization process. Make certain you have already saved all important data. You do not want to lose your contacts, memo, or other information due to a hard reset. You may have issues with a Nokia phone that is not turned on. If there are problems such as these you can try hitting three buttons simultaneously. Hit the +*+3. If you can hit these three buttons all at once you may be able to get the phone to turn on, and then you can go through the hard reset with the proper codes.
These codes work with all of the Nokia models including the 5130. You may find other options do exist such as the power button while pressing the space key and delete key, and caps/ shift button will also hard reset the phone.
It all depends on whether or not the *# keys work. Sometimes they won't work if the phone is in phone lock or key pad lock and you need to get it open first.
Oct 02, 2011 | Nokia 5130 Cellular Phone
Any one knows how to format phone memory of 7210 supernova
There are two types of reset Soft and Hard reset.Soft reset restores only settings whereas hard reset resets entire phone memory
For soft reset *#7780#
For Hard reset
*#7370#
Oct 27, 2010 | Nokia 7210
How do i reformat my 6303 classic? It always hung everytime i useD it? So i hope you help me to fix it.tnx godblesS
There are two ways to reformat your phone. One is soft reset and the other one is hard reset. Soft reset resets the phone and quick format the phone memory. Hard reset completely wipes the phone memory and automatically reinstall the phone's firmware. So if your phone has a many problems, i would recommend doing a hard reset.
To hard reset the phone, switch off your phone. Then press and hold "green call key, * and 3" together and switch on your mobile. Don't release these three buttons untill you see the nokia hand shake. After that release the buttons and your phone is reset.
To soft reset. Dial *#7370#. Then enter the security code (default is 12345). That's all.
Hope it helps. Please rate the answer. Thanks for using FixYa.
Aug 26, 2010 | Cell Phones
Pantech c150 phone locked up. How can I reset?
Search Results
PANTECH C150 - How to Hard Reset my phone - HardReset.info
www.hardreset.info/devices/pantech/pantech-c150/ Hard Reset PANTECH C150. Switch on the cell phone. Hard Reset PANTECH C150. Press this in sequence: *01763*737381#; Wait until your phone restarts. That's all. If this was useful, please share to help others and follow us on Facebook, Twitter and Google+. WARNING ! Hard Reset will erase all of your data
PANTECH C150 - Frequently Asked Questions ... - HardReset.info
www.hardreset.info/.../pantech/pantech-c150/.../reasons-why-you-might-need-to-hard... Hard Reset in C150 Will help to: PANTECH C150 runs too slowly; Reset and disable forgotten screen lock password or pattern; Might resolve hang-ups & freezing problems; Might resolve unexpected Application crashes; Wipes personal data phone before you sell your phone or after you buy one; Regain default ...
Hard Reset PANTECH C150 - IMEI.info
www.imei.info/hard-reset-3111-pantech-c150/ Hard Reset PANTECH C150. Are your looking for a way to make your PANTECH C150 work faster? Do you wish to clear all of the data on your PANTECH C150 before selling it to someone else? Well what you need is the factory reset. What is it? Factory reset (aka hard reset) is an operation which deletes all data ...
pantech c150 hard reset Google Search
Dec 11, 2017 | Pantech C150 Cellular Phone
To format nokia3110
for soft reset *#7780#. For hard reset type *#7370#. hard reset will delet all data on your phone like contacts,messages,photos,videos,music etc. please take a back up before performing a hard reset. if it ask for passcode by default it is 12345 for both hard reset and soft reset.
May 11, 2010 | Nokia 3110 Cellular Phone
I forgot my security code in my phone to access it so how to operate it
Dear you should reset your phone hard bcaz if u try to soft-reset,code will be ask to do reset So u have to do a hard reset of your phone.
Dec 04, 2009 | Nokia 5310 Cellular Phone
Cell Phones Logo
76 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
