Question about Plumbing
Why does my plumbing system make a moaning sound when I flush a toilet?
    Top Expert:
  • 53,736 Answers
The vent system is blocked making displaced air cause the noise
get in a plumber to clean out the system
Posted on Dec 08, 2017
  • 297 Answers
SOURCE: Basement up flush toilet systems
sorry Fran,that is what they run.thats just for the unit don't forget install cost too.good luck with this project.
Posted on Jul 15, 2009
projdoc
  • 2237 Answers
SOURCE: toilet wont flush completely. it may take 4 times
there is no air release. the vent must be clogged somewhere. you can take a hose up there and see if it drains all the way or floods over. since the tub drain has a trap and the toilet itself is a trap, there has to bee a good amount of air pressure coming up without a release. i would say an obstruction. possibly at the junction of the main and the vent.
Posted on Nov 13, 2009
SOURCE: toto toilet with gmax flushing system blue top
I have the same problem and can not find a solution. The toilet flushes fine but then a delay in filling up the tank occurs. Is there a part I can replace? Does something need to be cleaned or cleared?
Posted on Jan 15, 2010
  • 50 Answers
SOURCE: When flushed, the toilet (sounds like a lite scream)
try to replace the fluidmaster it is either that or your supply line is kinked,that or check the little black hose inside the toilet tank make sure that hose is not kinked,if neither hose is kinked replace the fluidmaster
Posted on Mar 12, 2010
heatman101
  • 43501 Answers
SOURCE: My up flush toilet makes a humming sound every 5
The pump has either gone bad or it is siezed up...you can try to unplug the pum and let it sit for a few hours then plug it back in... sometimes if you jog it on and off a few times you can get tiit to break loose and work again...if not you will have to take it out and replace the pump.
heatman101
Posted on May 04, 2010
How do I fix a toilet that bubbles (small air bubbles from below) and flushes slow, and not completely very often?
Remove the toilet & have a plumbing company power snake
as much of the entire homes waste drain as possible
Maybe clogged inside the home on most runs & also out to
the street,have them do as much as they can, out to the street
Remove all toilets, so they can do good job & you can check &
clean them from under it
Have them run a camera down ALL drains & to the street
Jul 19, 2014 | Briggs Abingdon Ada Toilet Express
Toilet bowl will not drain when flushed
if your flapper is held open and the toilet rises to the rim and does not flush then you need a closet auger and clean out the toilet as it has debris restricting the flush
Mar 02, 2014 | Plumb Craft Perfect Flush Toilet Kit
Loud squealing noise from water softener when toilet flushed
The unit may be in a regeneration cycle during the day. Reset to proper time of day.
It also sounds like you may need an air arestor installed on the plumbing in the house. When air becomes trapped in the plumbing lines it can cause the plumbing to "hammer" during periods of heavy usage. You would need to contact a plumber for proper placement of this device on your plumbing system.
RJ
Nov 28, 2013 | Valumax 5600SXT 30k Water Softner
Where can I get rid of my cat's waste?
You should tie the waste in a plastic bag and throw it away to the toilet, it is 100 percent flushable and you shouldn't worry about it.
Aug 15, 2012 | Cats
Is is possible to make a full flush toilet from an American Standard Cadet 3. The toilet is on a septic system and does not have the power to move waste all the way to the septic tank.
If your toilet is not moving waste all the way to the septic, then there may be a blockage in the waste line or it may not be plumbed correctly. There is no reason why you should not be able to make a full flush on septic. I have live on septic for many years and it should flush as well as living in the city. Is your water supply nice and strong? This sound like a gravity issue with the waste line or a blockage, If you can get under your house and see how the waste line is run, that would be helpful, it should be aimed straight down underneath your toilet and never running uphill at any point on the way to the septic tank. Also is there a vent in the waste line at the proper distance. If not, that could also be the issue. Good luck. P.s. does your septic tank need pumped out?
Nov 25, 2010 | American Standard Cadet 3 Right Height...
The flush valve closes almost immediately so that there is an inadeuate flush. The valve is a large cylinder about the width of a soda can and there is no adjustment I can see.
you will need to find a plumbing store and purchase a new one, I live in SC and Larrys' Plumbing sales them, so I am sure like a HD Furgersens etc. will. Good Luck Tim
Oct 23, 2010 | Kohler Toilet - One Piece with Ingenium...
I have a quantum toilet that flushes normally but then syphons the water from the bowl Possible problem?
Look for your main plumbing vent that goes out your roof, is it pluged with a nest or something? When your drain system drains, it needs outside air from the vent to keep the system from vaccume lock. Same as vapor lock in the gas line on your vehicle. If the system is'nt getting air it will **** the water from the traps in your drain system like it is doing in your toilet. You may have to have a professional drain cleaner or plumber correct your pluged vent.
Feb 27, 2010 | Mansfield Plumbing Products Mansfield...
Pretty new toilet seems to drip down the drane pipe after flush. Sounds like a little trickle as if there is too much water in the bottom an it is running out.
Sounds like the flapper isn't sitting properly. Take the lid off the tank and put a few drops of food coloring in it. Let it sit for a while (do not flush). If the water in the bowl turns that color, that means the flapper needs replacing. Simple to do and costs about 5 bucks. Good luck
Feb 16, 2010 | Crane Plumbing Toilet To Go Tall...
Plumbing Logo
47 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
