Question about Yamaha Computers & Internet
How to open a Yamaha clp560 keyboard and repair sticky keys
    Top Expert:
  • Yamaha Master
  • 8,376 Answers
Hi Gary,
this is all i could find.
go to this link and you should see some youtube videos showing how to open it.
hope this helps you out.plus you should see the link for the manual.
How to open Yamaha clp560 keyboard Google Search
Posted on Dec 08, 2017
SOURCE: 2 keys(reeds) are not working ,my keyboard is yamaha DGX200,how to open it
عزف
Posted on Oct 31, 2008
It is a design fault. A technician advertising on the net informed me i can get it fixed by him and yamaha will pick up the fee.
Posted on Nov 14, 2008
TimmayG
  • 86 Answers
SOURCE: Sticky keys on keyboard
A good idea is to get a cloth (avoid tissues or paper wipes) and give that a spray with some form of window or screen cleaner and go over the keyboard a few times, for really sticky keys, gently remove them and give the underside and the base of the key a good wipe.
If you are unsure how to remove keys, please don't hesitate to reply (i will need the Model of the machine eg: acer extensa 5620)
Please don't spray the cleaner directly on the keyboard and dont use high grade cleaner as this can damage the keyboard
Posted on Dec 01, 2009
Testimonial: "thanks"
SOURCE: Open up new apple bluetooth keyboard
Well they are meant to be sealed so your best bet would be to get some spray cleaner, and spray the gunk away, that should be fine, if it hasn't faulted yet it MUST be sealed properly, so just do it "in situ" .
Posted on May 05, 2010
  • 45 Answers
SOURCE: Aspire 4720 PC Notebook: sticky keys, some liquid wet the keyboard...
Its hard to get them working again properly, i had to replace 4 sticky keys finally. I found this company who sell laptop keyboard keys at a very good rate, and even have tutorial's on how to fix the keys , that makes it really easy ...
www.laptopkey.com
Posted on Jul 21, 2010
Re: Microsoft wired 600 keyboard/sticky keys... Wanting to know how do I enable sticky keys on my Microsoft wired 600 keyboard pls?
Sticky Keys is a software function. I am assuming you are using Windows - open the Control Panel, select the Ease of Use Center, select Make the keyboard easier to use. In here, you can turn on and setup Sticky Keys.
Dec 21, 2016 | Microsoft Computers & Internet
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
    You might have "sticky keys" so try this:
    When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
      • Press the "Shift" button five times in a row to turn off sticky keys.
      • Open the "Start" menu and then click "Control Panel."
      • Click "Ease of Access Center" from within the Control Panel window.
      • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
      • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
      • Click "Apply" to save your changes and then click "OK" to close the window.
    Hope this helps. Good Luck!
    Aug 05, 2013 | Toshiba Satellite L645DS4040 Laptop
    I want to lock the keyboard so my daughter can play with the keyboard but not have the buttons do anythiung
    1. Press the Windows logo key + U to open the ease of access center.
    2. Click on the "make the keyboard easier to use"
    3. Select "turn on sticky keys" and "turn on filter keys." Select "save." Your computer will now only make sounds when the keyboard is hit.
    4. Follow steps 1 through 3 to unlock your keyboard. Unselect the "sticky keys" and "filter keys" and click on "save."
    Mar 15, 2011 | Acer 91.63X07.001 Keyboard
    How to turn off explorer sticky keys
    In the Control Panel (Classic View), open the Ease of Access Center control panel. Follow the link that says, "Make the keyboard easier to use." Uncheck the box that says "Turn on Sticky Keys." You can also follow the "Set up Sticky Keys" link to adjust the Sticky Keys options.
    Hope this helps!
    Mar 10, 2011 | Microsoft Windows Vista Home Basic Edition...
    Have a clp300 sticky keys
    Not sure what you mean by sticky... If sticky to the touch, clean them carefully with a soft cloth wetted with Windex and then dry with dry cloth.
    If the keys stick down, check if there is clearance from the board in front of them. If they are dragging here, you may need to have the keyboard adjusted to have adequate cleance. This is not an uncommon problem that can happen due to warping or humidity and temperature changes.
    Drag a business card between the front of the keys and the front rail to check for clearance.
    Aug 02, 2010 | Yamaha Music
    Shift key not working
    You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
    **Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
    **If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
    May 29, 2010 | HP Compaq nc6000 Notebook
    Dropped soda in my acer keyboard-did not seem to harm electronics, but keys are starting to stick . I turned it upside down right away. computer seems to work ok- other than sticky keys
    Get a clean, damp, warm and soapy dish cloth or face flannel. Gently wipe the keys that are effected, keep on doing this until the keys become loose and not too sticky.
    Regards.
    Apr 12, 2010 | Acer NSK8458AN Keyboard
    I need to repair a sticky key on a P120. Is there a repair manual?
    Call around to local music stores and ask about the closest authorized Yamaha repair center. If it is still under warranty, they should replace the keybed free of charge.
    Here is a great website with the do's and don'ts about self keyboard repair. http://www.mikebarden.com/view.php/area/1/digital-piano-repairs-keyboard-repairs
    Sep 17, 2009 | Yamaha Full-Size Keyboard
    How doI open a Yamaha P120 to fix sticky keys?
    I've had the very same problem twice so far. The only solution I figured is to simpy purchase an equivalent key (contact Yamaha service in your country for this) and to replace the broken one. The reason why the key doesn't work smoothly as the other one is not dirt therefore any cleaning won't help. The key is cracked deep in the place where it's attached to its 'axis'. So you'll need to remove all the screws and unmount the cover (it needs a sideshift to open once the screws are removed), be careful with the speaker wires. However you'll need firm moves anyway. Opening is tricky and gets me surprised anytime I do it so you'll need some courage :). Replacing the key is even more tricky. You'll have to remove the broken one by pulling it horizontaly (use some force, it's broken anyway). Placing a new key you'll need to uplift the 'hammer' and then slide a new one. I'm sure you'll figure it out once you see it with your own eyes (it's really hard to decribe but not so hard to do it). Hope you'll do fine. I haven't tried glueing the crack for I doubt it would work for long. Good luck!
    Jan 28, 2009 | Yamaha Full-Size Keyboard
    Computers & Internet Logo
    80 people viewed this question
    Top Yamaha Computers & Internet Experts
    Carlos L. Burgos
    Carlos L. Burgos
    xalint1
    xalint1
    Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
