Question about The Computers & Internet
I don not have a service manual. I need to open the unit and fix sticky keys. What do I do
2007 Honda ST 1300 PanEuropean ignition shutter locked lost my key
Hi, Anonymous the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://burgmanusa.com/forums/14-burgman-400-pre-2007/38019-how-do-i-open-ignition-switch-key-hole-shutter.html
Honda Ignition Door Lock Issues Key will not turn or sticky keys
Honda 2003 ST1300 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 2008 ST1300 Owner Manual
Mar 28, 2014 | 2007 Honda ST 1300 PanEuropean
My remote door opener don t work
You will need to reprogram them to your door opener.
Its about a $50.00 service call from an authorized service tech, or you can simply call the manufacturer and they would talk you through it.
You can also try the manufacturers web page and look for a manual for your particular unit.
Jan 13, 2014 | 2002 Pontiac Bonneville
I don't know how to remove the keyboard
Suzuki? keyboard?
all sticky keys are dirty.
some you can clean, others not.
only way to tell is LOOK.
if it can not be dissembled, then it can not.
some keyboards, have no screws and use melted plastic or glue
preventing any service.
look. then see.
Feb 03, 2013 | Suzuki Cars & Trucks
How do I fix sticky keys on netbook?
Physically sticky keys because you spilled something on them or sticky keys keyboard shortcuts?
The first you don't really unless you want to dismantle the keyboard and clean the entire thing (do-able but it would take you a long time and you risk breaking the pieces under each key) I would just buy a new keyboard on ebay for $15-30 and have someone replace it.
Second, keyboard short cuts you can disable under Control Panel > Ease of Use > "Make the keyboard easier to use" and uncheck sticky keys.
Comment if you need more assistance and please rate the solution if you found it useful.
Thanks,
Justin
Nov 07, 2011 | Acer Aspire One Netbook 8.9" Notebook
Well, my Netbook scrolls down randomly. Either up or down. No matter what I do it won't stop, I usually bang on the directional keys and it does stop for a short period. I really don't want to keep...
Sticky keys might be the problems.
1.Press SHIFT 5 times repeatedly
2.Cleanup the touchpad on the right corners ( unit OFF )
3.Seem the PgUp and PgDn keys STICKY >>> try clean it with a dry soft brush
Aug 16, 2011 | HP Mini 1000 Netbook
Sticky keys how do i fix it?
Hi Dgr Welcome to fix ya !
The sticky keys are part of Windows Ease of Access Center Accessibility program.
1. The easiest way to enable/disable the sticky keys is to press the "Shift " key five times. This will turn on/turn off the program.
2. The second way is to press the Windows logo key + U at the same time. This will open the Ease of Access Center. Then select the link that reads" Make the keyboard easier to use."
3. Under the section that reads, "Make it easier to type" you have the option to enable the Sticky Keys or a link to Set Up Sticky Keys. Select whether you want to set up the Sticky Keys or just enable them if you have previously set them up. If setting them up for the first time, remember to click "Apply" after making your selections.
Hope this helps. If you need further assistance, just leave a comment at the end of this solution and I'll be glad to help. Thanks for using Fix Ya.
Jul 10, 2011 | Computers & Internet
Constantly stops with code "DC" even with very
Do you want to DIY the fix?
Google this Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum no cost and you can get the Service Manual from this site.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine. At that post I discuss what cause is and the fix.
In that Sticky are other what I find to be common Service Repair notes for issues with the machine.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air f
Mar 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My letter 'e' is sticky and I have to press extra hard - do the individual keys come out of a laptop Acer 5720 please
Hello, If your laptop keys are sticky and its causing problem typing, you can replace just the one key which is sticky, visit this site
www.laptopkey.com
I got two of my laptop keys fixed by this company and im satisfied by their service, they send all the underneath fixings with the key , so its easy to fix , hope this helps you :)
Jan 05, 2010 | Acer NSK8458AN Keyboard
Sharp OZ-730 sticky keys
I have a a Sharp yo-480. I've fixed sticky keys many times. I back-up data in the organizer first. (yo-480 doesn't have a flash memory) then carefully dissasemble unit. Lift out rubber keypad and use WD-40 to wipe circut board and keypad. It's the sticky residue that makes the keys stick
Nov 16, 2009 | Sharp Wizard OZ-730
4 of my keys stick on my computer and somtimes don,t com on at all do you have a solution
Dear,
Get your key board cleaned by technician once. This will solve your issue
Oct 12, 2009 | Acer Aspire 4720 Notebook
Computers & Internet Logo
67 people viewed this question
Top The Computers & Internet Experts
James Arnold
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
