Question about Exercise & Fitness
My model 1F86-344 buttons stick when raising or lowering temp, the numbers go on their own when you let go of the button and stop at highest or lowest temp, what would cause this?
  • 1462 Answers
SOURCE: which way do you turn the temp. knob
loper the number on the thermostat dial, warmer the fridge. higher the number, colder the fridge. normal setting is about "3"
Posted on Apr 19, 2007
catriver
  • 878 Answers
SOURCE: Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
Posted on May 12, 2007
  • 12 Answers
SOURCE: temperature control
For the Kenmore, keep pushing the button and it should cycle back to the top of the temperature range.
Posted on Oct 05, 2008
jerryg50
  • 1689 Answers
SOURCE: 35 in. GE tube TV volume issue
The front panel control assembly, or the circuit area for this panel most likely has a fault condition.
I have also seen some of the button switches fail on the control panel.
Jerry G.
Posted on Feb 10, 2009
  • 366 Answers
SOURCE: The temp. lower button does not work. Can only
sounds like your topside controller needs to be replaced.
Posted on Nov 14, 2009
How do we raise the temperature in our fridge and freezer?
Well, you didn't leave a model number, so I'll just give you the generic answer: If you keep pressing the Frz or Ref temp buttons, the temperature will cycle down to the lower limit and then pop back up to the upper limit and then repeat all over again. If not, look for up/down buttons, or +/- buttons.
Oct 21, 2014 | Refrigerators
Can the infiniter 100 red laser pointer pop balloons?
STEP MOTOR TEST-
Enter TEST MODE-
1.) Plug in foot pedal
2.) Press reverse button and hold while turning on the power switch.
Advance through test segments by pressing up/down key
LCD shows "STEPPING MOTOR"
• Raise irhe needle bar to highest position and push
START/STOP key
• Lower the needle bar to lowest position and push
START/STOP key
• Tum the handwheel and check the feed dog position
SYPMTOM's
• Not working correctly
• Stepping motor (zigzag) get default position
• Feeding, tension motors get default position
• Feed dog goes to home position
SOLUTION's
• Replace stepping motor
• Replace tension sensor
Jul 02, 2014 | Office Equipment & Supplies
Horizon treadmill model ls925t will not allow the grade to be adjusted. It is stuck at the highest grade
RUN THE SOFTWARE CALIBRATION. God bless you
The Steps for Newer Style Console Calibration
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Apr 02, 2013 | Horizon Exercise & Fitness
Lower incline
Dear Sir:
I STRONG recommend RUN the calibration Software Inmediately, for eay Diagnose and troubleshooting, most of them instruction has coming in the Hood of Motor, follow the instruction or use your instruction manual.
Adjust the sensor speed attached the diagram. Tight the wires from sensor speed. The sensor speed can be faulty. Adjust the Pot with the gear in the same motor, both can be faulty. And finally the main motor board can be wrong. sincerely.
God bless you.
ernesto cuadra
managua, nicaragua.
Feb 12, 2012 | Proform Exercise & Fitness
How to disable the energy saver of the amana ptac unit. Once the AC reach the lowest temp on the room , the unit turn off, then when room temp raise it turn on.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=PTH153B50AJ&siteCd=AMA
This is the link to find the manual for your unit. Make sure the model number is correct. You should be able to find the info you are looking for if it is possible to disable the energy saver. Hopefully this will help.
Mar 20, 2009 | Amana PTH153B50AJ Heat Pump Air...
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Jan 13, 2009 | Refrigerators
Temperature control
Sep 04, 2007 | Kenmore 63822 / 63824 Bottom Freezer...
Which way do you turn the temp. knob
Apr 19, 2007 | Magic Chef MCBR170 Compact Refrigerator
Exercise & Fitness Logo
24 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
