Question about Philips Televison & Video
My Philips flat tv has a blue screen how do I get tv to work again, as I know nothing about what button to use?thank you
  • 35 Answers
SOURCE: 52" philips flat screen repair
Your best bet is to do a search of your model on ebay, you will likely find one being sold for parts, because usually it's the video boards that go out ij them. So you should find one without a broken screen, but something else on it broken. And if you want to save shipping you can ask the seller to send you just the screen and trash the rest.
Posted on Mar 05, 2008
  • 2337 Answers
SOURCE: Philips flat screen tv will not power up.
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Posted on Dec 20, 2008
SOURCE: Philips flat screen tv reboots
Try sticking in a blank but empty USB memory stick into the USB port.... have the real remote (philips not a universal) ready... Go into the TV Menu..Select Software Update, then select Update Assistant.... then right click over to start now... It will write an HTML file to the memory card.. wait for it to say done,(been awhile since iv done it), plug it into your PC/Mac and open the file on the USB stick.... if you need an update it will check for it... download the update and the instructions to your desktop (might be compressed, if so open it and copy the files according to the readme.... stop the stick (eject) in Windows or the mac equivalent... pull it out of the pc.. turn OFF the tv and insert...
This can very likely stop the reboot loop.. Iv seen mentions of some tv firmware revisions having this problem.
Posted on Mar 08, 2009
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
Here is a photo of the board where I have removed the two from my TV. You can see the two open holes.
Posted on Dec 12, 2009
sabreusa
  • 271 Answers
SOURCE: My Philips flat screen tv
It could be a power supply problem. In this model at least 2 capacitors, go bad in the power supply I think they're 1000uf/10V. If you look at the power supply board you will notice a bad cap with a blister on the top. The whole power board is from $100 - $200. I fixed a lot of these sometime the Y or sustain board goes bad. Visual inspection then measuring voltages..
Best of luck
Nour Sabre
Posted on Nov 03, 2010
Element flat screen tv screen appears off when power is on
At this stage, try replacing ps Caps. Old elements had cap problems in ps area.
Feb 11, 2014 | Element Electronics Televison & Video
Philips tv digital disappeared
There may be a firmware upgrade needed here--ask Philips what is available for this model.
Jun 13, 2012 | Philips 37PFL5332D 37 in. LCD Television
I have a Philips 52PFL7422D/37 52" TV. For the last year now the TV will make a clicking sound like it is turning on but never does. After a couple of seconds to a minute the TV makes another...
I have the same model and the same problem... I am told the power display board is is the issue and may need to replacing. New board costs around $80,or a bad capacitor depending on your paitence.
Nov 23, 2010 | Philips 52PFL7422D/37 TV
Philips 42pfl7762D-lcd blue screen, remote control
Hi! I have the probably same problem (since today) - all I know is that it is because the TV is set to digital instead of analogue, and it won't allow me to put it back into analogue mode - when I try that, i get the cross you mentioned. The strange thing is, that there are no menus visible at all. But the volume and screen output format buttons are workijng and show on the TV. Otherwise the screen is blue. Any solutions?
May 15, 2010 | Philips 42PFL5332D 42 in. LCD Television
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Blue screen?!
im not sure what that button is for i think pan and scan but anyway try holding the power button down for several seconds to rebut the player hopfully this works let me know if not and well try something else
Sep 21, 2008 | Insignia Televison & Video
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Blue screen with sound but nothing else!
I, too, acquired a Phillips without a manual and was experiencing a similar problem. My model is PTV 916, but if your TV has a "source select" button, say a prayer and press the button. From that point, I don't know what else I did, but I do get TV programs now.
Jan 04, 2008 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
