Question about Vizio Televison & Video
When I turn on the tv I cannot turn the volume down. I have to push every button and after several minutes the volume can be adjusted. I have tried several Vizio remotes and still have the problem
ronpar
  • 27 Answers
SOURCE: Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Posted on Dec 06, 2007
SOURCE: direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Posted on Jul 29, 2008
SOURCE: direct tv remote- volume control
Here is how you fix it:
http://www.dbstalk.com/showthread.php?t=116241&highlight=SAMSUNG+REMOTE
Posted on Aug 27, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
djicenova
  • 319 Answers
SOURCE: Toshiba 50HDX82 TV Volume Problem???
IR interface board could be bad
Posted on Feb 27, 2009
TV volume goes to loudest on it's own
It sounds like you may have a stuck micro button (volume button on tv) . You might try to push the up volume button on the tv several time and try to get it unstuck (if in fact that is the problem). Also sometime I have had situtions where the board holding these switches on the inside of the t was broke and had to be soldered and repaired.
If I can be of any more help, please email me at wyoed1@aol.com. "Original Radio Man" Ed
Feb 12, 2013 | Sharp 25R-S100 25" TV
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
Turns on, but buttons don't respond.
If you have a remote,just press down on the volume up button and roll it around in circles.It sounds stuck and that sometimes will help unstick it.Also do it on the TV's button.If that doesn't work please let me know and we'll try something else.Good luck!
Aug 01, 2010 | Polaroid FLM-3232 Television
How do you set the clock on sony xplod 100db+?
The clock uses a 12-hour digital indication...... Press and hold the select button...... The setup display appears...... Press the select button repeatedly until “CLOCK-ADJ” appears...... Press (DSPL...... The hour indication flashes...... Rotate the volume control dial to set the hour and minute...... To move the digital indication, press (DSPL...... Press the select button...... The setup is complete and the clock starts......
Jan 28, 2010 | Car Audio & Video
HOW DO YOU Adjust clock on 2004 ford focus c-max?
FROM THE OWNERS MANUAL
8. Clock: Press and hold CLK button until the
hour digit flashes. Turn the volume
control to increase/decrease the
hours. Press again to set the minutes. Turn the volume control to
increase/decrease the minutes
Dec 03, 2008 | 2004 Ford Focus
Unwanted rectangular black area appears on screen blocking 40% of picture
This could be the result of a partly shorted vertical winding on the deflection yoak.Since the line is on an angle and not straight across.
Nov 07, 2008 | Durabrand DWT1304 13" TV
Clock
Push the small button beside the 1.
scroll through the options with the volume dial until you get to "clock adjust" hit enter (top button) then adjust the hour with the volume knob. Hit enter again and adjust the minutes.
press ret (bottom button on the left to bring you back to the main confirugarion screen (should see clock adjust again) then press and hold esc. (middle button between ret and ent) until the regular playback screen comes back.
Nov 09, 2007 | Alpine CDA-9883 CD Player
Power, volume buttons
Is this on the remote or the buttons on the TV?
Aug 17, 2007 | RCA P46810LV 46" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
