Question about Savin Office Equipment & Supplies
Need a replacement photo conductor for Savin 816
    Top Expert:
  • Savin Master
  • 43,901 Answers
Fixya does not sell replacement photo conductors.
Posted on Dec 07, 2017
Arius
  • 446 Answers
SOURCE: Color Photo Conductor Unit
the vertical line that you saw is an indication of either it is normally worn out, or something has caused the scratched, by any material ( PC drum is very sensitive to any material and can easily damaged or scratched any solid and unwanted dirt inside) see you actual meter reading. if it falls on the first thousand copies or print then it might have caused by a scratched, if it falls beyond the PM parts repalcement then there is nothing you can do but to replace this.
sometimes you can swap the colors, by the affected color use the yellow drum unit to the affected drum, the vertical would not that be obvious.
Posted on Jul 24, 2008
  • 143 Answers
SOURCE: savin 816 photoconductor troubleshooting
Enter the SP mode.
Clear Mode 1,0,7 Hold down the Clear/Stop Key. Select Copier SP the go to SP7 - Data Log, then go to 804 and hit enter/execute. This will clear the PM Counter.
Posted on Sep 01, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: what shoud I do when error 84 replace
    Photoconductor is the part of the printer where the image gets created this is a very delicate and important part in the Laser printing process. If you open the printer and remove the toner, you should see it sometimes is like a green or blue color. The message 84 is just telling you that the photoconductor has reached the end of life and needs to be replace. Here is also a link on how to do the replacement http://bit.ly/bn2HFc
    Posted on Feb 09, 2010
    • 217 Answers
    SOURCE: I have a bad photo conductor in my printer and
    Instructions for resetting photoconductor count on E450
    http://support.lexmark.com/index?page=content&id=HO3155&actp=search&viewlocale=en_US&userlocale=EN_US&segment=SUPPORT&productCode=LEXMARK_E450DN&searchid=1269982667366
    Posted on Mar 30, 2010
    SOURCE: Customer with Brother Intelifax
    I have a fax line with packet8 which is a voip carrier. I am having trouble receiving faxes. I was told to change the baud rate on the fax to less than 9600. I don't know how to do it on my brother intellifax 4100e. can you advise?
    Thanx,
    Posted on Mar 23, 2011
    We have an Savin Copier 816 which has an error message to load paper. There is paper in the tray.
    Hello!
    If you are sure that there is paper in the tray the problem is in the papaer sensor.
    It maybe broken or out off the place.
    Take the tray out and look inside. Maybe you see the sensor out off the place. If so just put it gently in the place.
    Hope this helps you.
    See you!
    Aug 29, 2011 | Savin Office Equipment & Supplies
    After changing the black cartridge of epson aculaser c1100, a message flashed: Service Req E511
    Welcome to FixYa, the world's largest product support community.
    The message E 511: Service Required is commonly due to the Photo Conductor Unit's tabs getting stuck. So the first thing we need to do is to remove the PHoto Conductor Unit. Here are the step to remove the Photo Conductor Unit off of your EPSON Aculaser C1100.
    1. Turn the printer on, and open cover B.
    2. Raise the yellow lever inside cover B.
    3. Remove the photoconductor unit.
    4. Check the white tabs on the underside of the photoconductor unit. These are spring-loaded plastic tabs that should depress when you press and release it. If the white tabs no longer spring back you need to replace the photoconductor unit.
    After removing or ultimately replacing the photoconductor unit, please follow the step by step giude on how to remove the photoconductor unit in reverse order.
    Jun 09, 2011 | Epson Aculaser C1100 Printer
    Customer with Brother Intelifax 4100e cannot "handshake" with our Savin 816 multifunction. The Savin is receiving hundreds of faxes daily, and is also used to scan to document management, etc. ...
    Thanx,
    Mar 22, 2011 | Brother IntelliFax-4100e Fax
    IS THERE A TRICK TO INSTALLING THE PCU ON THE CL3500N? IT SEEMS AS THOUGH IT SHOULD BE A SIMPLE PROCESS HOWEVER IT IS NOT LOCKING INTO PLACE. THANK YOU
    Photo Conductor Unit Color
    A Turn off the power, and then unplug the power cable.
    B Open the right cover.
    C Pull out the green levers on the left and right that are securing the inner
    cover.Replacing
    D Lift the inner cover until it stays up.
    E Remove the photo conductor unit.
    F Pinch the
    green lever to unlock the unit.
    G Pull out the photo conductor unit carefully.
    H Pinch the green lever to unlock the unit.
    I Pull out the photo conductor unit carefully until it stops.
    J Pinch the green part to release the unit
    .K Pull out the photo conductor unit carefully. Be sure to hold the unit with both hands, and pull it out carefully.
    L Take out the new photo conductor unit.
    M Remove the cap attached to the photo conductor unit. The cap is no longer needed and can be disposed of.
    N Remove the tape from around Photo Conductor Unit by peeling it down-ward, and then remove the unit
    Mar 11, 2011 | Ricoh Aficio CL3500N Laser Printer
    Panasonic kx-t7433 phone does not power up
    The phone uses the outside pairs of a 4-conductor base cord to make the digital phone work. Check to see that you are using at least a 4 conductor base cord. Try moving it to another jack that works. If it powers up there, you probably have a mis-wired jack. You can also test it by plugging it into the cabinet directly if you have a TD-816.
    Carl
    Oct 23, 2009 | Panasonic KX-T7453 Corded Phone
    Savin 816 photoconductor troubleshooting
    Enter the SP mode.
    Sep 01, 2009 | Ricoh Aficio 250 Copier
    Reset Photo Conductor Kit
    Hi!
    For step by step procedure to reset Photo Conductor counter please see the following link---
    Photo Conductor Counter Reset
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    Jul 02, 2009 | Lexmark E450dn Laser Printer
    Replacing the photo conductor
    You didn't mention make or model so I will guess. Most of the Savin/Ricoh brand small machines that have a small pcu require you to pull out a mylar strip in order to drop developer down where it needs to be. So my guess is that it needs to be pulled all the way out and on the end you will see a little bit of toner. Now alot, but a little on the end. Also the box that it came in should have some directions for installation. Good luck. Please rate this. Thanks.
    Jul 01, 2009 | Office Equipment & Supplies
    Paper jams
    there are two parts to the copy of this machine, one is the photo conductor (drum, green cylinder ***'y) and the toner which fits in the drum ***'y.
    you replaced the drum but you need to replace the toner as well (low toner)
    then turn off and hold the start key an dturn on to get into service mode, scroll to reset photo count, select.
    Aug 20, 2008 | Lexmark E340 Laser Printer
    54 people viewed this question
    Top Savin Office Equipment & Supplies Experts
    quennie732
    Adorjani Laszlo
    Don  Farrell
    Don Farrell
    Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
