Question about The Audio Players & Recorders
I have a Denton DRA "565RD receiver. I have sound but it powered up and it did work yesterday. I checked all the connections and they seem to be okay. I used it yesterday.
  • 395 Answers
SOURCE: connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
Posted on May 21, 2008
  • 7 Answers
SOURCE: MY DENON DRA-435 A RECEIVER
These recievers were infamous for the power transformers going bad(opening) if more than 2 speakers were hooked up and it was cranked up.Did it die while playing?Do you have 4 or more speakers hooked up?Was there a power surge?Let me know........
Posted on Jul 23, 2008
  • 3 Answers
SOURCE: Polaroid DRA-01601A will not power up
99.9 % of the times its the capacitor which is blown. I had spent few weeks to investigate on this and ultimately found this solution. Till date I have replace two capacitors. To determine which capacitor is gone, Check on the flat silver surface of capacitor. If its not 100% flat it means its gone and you need replacement. Pl. check my attached file to understand on details of inside configuration.
Hopefully it works for you.
I am not able to upload pdf which I have created. Pl. contact me via email to get pdf file
viki_3578@yahoo.com
Regards,
viki_3578
Posted on Nov 10, 2008
  • 11800 Answers
SOURCE: DRA-565RD: The receiver plays
In that case the problem is inside it: when the unit works it heats up and a piece dilates, touching the ground and shorting everything. Or the part dilates and loses contact causing a loss of power.
Open the unit and look very carefully for uninsulated parts, exposed or weakened solderings and damaged wires.
Posted on Sep 05, 2010
  • 2973 Answers
SOURCE: I have had a Denon
Your friend is correct. The transformer may be shorting. Just smell the transformer and see if you smell burnt enamel. That typical smell when an electrical gadget gets burnt. If yes then you must replace the transformer. Only you must get one of exactly the same specs. And fortunately, these days you can get a much smaller and a heavier duty transformer than what you have presently. You can do it at home.
Posted on Nov 24, 2010
When on FM tuner, stereo stops playing after a few minutes
Right then sounds like the connection from the aerial lead into the receiver - check out the socket where the aerial plugs into!
Is it loose at all or could there be a bad connection inside the unit.
Get the cover OFF and investigate yourself before you rush down to that very friendly repair man along the street.
Jan 05, 2014 | Denon DRA-365R Receiver
Denon DRA-275R
Listen for a relay clicking inside. It you hear it but get no power, it is a problem with the relay. If there is no click, it is probably the power supply.
Aug 01, 2008 | Denon DRA-275R
Dennon DRA 697ci with bose 901 speakers.....just moved to new house....hooked up stereo and can only get minimal output
I assume it used to work. You need to ensure the connections to and from the active equalizer are all proper. I would think you have it in the Pre-Main loop.
It sounds to me like you have an in/out reversal at the EQ or a dead Tape Monitor selected.
Or MUTING is selected on the DRA.
Dec 25, 2010 | Denon DRA-697CI
I have a Denon receiver dra 545a that won't power on... how costly might it be to repair
Sounds like the power supply went out. Check inside to see if a fuse is blown. Replace it once (with the exact rating) and if it blows a second time, then you have something shorting out and can be costly to repair. DO NOT replace the fuse with a higher rating for it might cause a fire.
Oct 31, 2010 | Denon DRA-397
Will not power up.voltage on both posts behind switch.no voltage on secondary of transformer. anyone seen this before???
There should be a fuse between the switch and the primary. Have you verified that there is voltage on the primary or checked the continuity of the mains fuse?
Feb 09, 2010 | Denon DRA-565RD
Denon dra-95vr receiver has no sound out. All
Two things to check. First, the 95VR can be deceiving because it has a "variable loudness" control that some may mistake for volume. The actual volume is controlled by the big up and down arrows on the upper right side. If the volume is turned up, you should see the volume bar graph display show up. If none of the inputs are giving you volume, and the volume is turned up, then try running the output from the processor loop output in the back to another amplifier. The processor out is jumpered to the processor in for normal operation. Missing jumpers could cause a problem also. If there is sound coming to the processor out, then you have a problem with the power amplifiers. Best to refer that to a technician.
Dec 29, 2009 | Denon Audio Players & Recorders
Connecting new tv to DRA-685
May 21, 2008 | Denon DRA-685 Receiver
Stereo receiver is in a Panel Lock On mode and will not stay on
Hi, Press the B and the Mode buttons and then hit the power button.  This should unlock the panel....it worked for me.
Apr 12, 2008 | Denon DRA-397
Right channel not working
Hi....you may want to check the speaker fuse, located on the rear of the unit.. sometimes too small wattage speakers get hooked up and the speaker fuse will blow as to not hurt the speakers.
Hope this helps.
Squipps
Feb 07, 2008 | Denon DRA-685 Receiver
21 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
