Question about Acer AspireT135 (AST135US3302) PC Desktop
My acer ast135-u-s3302 was shutting down due to what seem to be overheating issues. This would occur when the cpu temperature reading was indicating 96-97 degrees celcius, sometimes immediately after turning the system on in the mornings. Both fans seem to be running okay. While removing the heat sink the cpu remained stuck to the heat sink and some pins got bent. Tried to straighten them and reinstalled but now the system does not boot up and I cannot find the amd sempron 3300+ 2 GHz 754 socket processor. Any idea where I can get it or a suitable substitute? Also what could have caused the high temperature readings?
    New Friend:
  • 63 Answers
This is WAY TOO HOT. It looks like you need a new CPU, since you can't really straighten those tiny pins. AMD chips run hot, but no where near 95C. They should not run higher than about 55C.
Posted on Jul 29, 2009
Overheating and shut down d915grv
CPU/ Processor resources and due to the heavy processing the PC heats up. Excessive heat up beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heat up.
Heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the PC, which clogs the fan and heat sink.
1. Make sure the fan is running. (if not, it needs replacement)
2. Clean the fan and heat sink (thermal module). Take out the fan and heat sink. clean them with the help of tooth brush and put it back.
3. Also, make sure that the PC is placed in a well ventilated environment and the air flow the the PC is correct.
The procedure is very simple and I believe immediate action is required to prevent any damage to your machine and data.
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
May 27, 2013 | Intel D915GAV Motherboard
Overheating
CreativeTECH
May 27, 2013 | Intel Computers & Internet
Acer aspire overheating fix
What model of acer apire ?
When a laptop gets hot physically hot, to the touch you know something isn\'t quite right. It\'s normal for a computer to get a bit warm as it runs, which is why computers have a built-in cooling fan in addition to a heatsink and cooling vents. Excessive heat, however, is almost always an indication that something is malfunctioning. This is no different with the Acer Aspire 5000.
What\'s Happened If you\'ve ever looked inside of a computer or seen an "exploded view" of a laptop, you will know that thousands of components work together to ensure your computer\'s best performance. The cooling fan is activated by temperature readings from the central processing unit, which heats up and cools down depending on what it is being used for. Sitting idle, the temperature of the CPU will be low and the fan won\'t come on. When the computer is performing a few tasks simultaneously, the CPU is taxed and the fan kicks in. When you hear the fan whirling excessively, the computer is overheating which can damage the CPU. Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. b> Checking Temperatures You can download programs to monitor the core temperature of your CPU. Programs like Core Temp, Speed Fan or Motherboard Monitor use the hardware monitoring devices built into your Aspire notebook to track its core temperature. Different sources suggest that the Aspire 5000 can run at a different maximum temperatures. Users on Tech Support Forum say 50 to 60 degrees Celsius is normal even optimal and that above 75 degrees is a problem. Acer\'s technical manual for the Aspire talks about external temperatures for running the computer efficiently (between minus 20 and 30 degrees), but it says nothing of internal temperatures. A few different users reported overheating to the point of 90 degrees, at which point the computer freezes and shuts off. Warranty Fix Computer original equipment manufacturers like Acer sell every computer with a limited warranty. Overheating is usually covered by this warranty. If your computer is repeatedly reaching high temperatures, and you\'ve recorded the temperatures with software, contact Acer for a replacement or a repair. Out-of-Warranty Fix The simplest way to address an overheating problem is to let the computer breathe a little. Make sure that you use it on a flat, hard surface so that air can pass to the fan easily and without interruption. You can buy laptop cooling pads at most computer stores that are designed with this in mind. As a complex fix for an out-of-warranty system, you can follow a picture tutorial from MPS Computers to replace the sealant around the heatsink with a new glue called Arctic MX-2. This glue allows more heat to escape and brings the core temperatures down about 10 degrees. Acer Aspire Overheating issues http://www.techsupportforum.com/forums/f108/acer-aspire-overheating-issues-214199.html 257 software downloads results for "temperature"
b> Acer Support - ASP Login http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_AS3000_3500_5000_BOOK.pdf
Feb 26, 2013 | Acer Aspire Computers & Internet
Hello, my Optiplex, whenI am playng, suddenly shuts down. I mean there isn't a SW crash, only the PC shuts down and I am obliged to reboot. May be a temperature problem? Tanks Marco (Rome Italy)
Gaming consumes more CPU/ Processor resources and due to the heavy processing the PC heats up. Excessive heatup beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
Heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the PC, which clogs the fan and heatsink.
CreativeTECH
May 31, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
My Laptop, ACER ASPIRE 5738G overheats during gaming. When it reaches a temp more than 70 C it shuts down. I tried unscrewing it to blow out the vents.. but the casing doesnt want to come loose. i...
Gaming (and graphics application) consumes more CPU/ Processor resources and due to the heavy processing the PC (CPU & GPU) heatup. Excessive heatup beyond usual is alarming and PC shuts down by itself when the processor/ GPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
Laptop heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the laptop, which clogs the fan and heatsink.
1. Make sure the fan is running. (if not it needs replacement)
2. Clean the fan and heat sink (thermal module). Click here for GENERAL Acer Laptop disassembly instructions and refer to
Removing the System Fan/Thermal Module after removing the outer cover. Take out the fan and heat sink. clean them with the help of tooth brush and put it back. Also, repair manual can be searched online or downloaded for referrence.
The procedure is very simple, but if you are not comfortable with working inside electronics, I suggest that you should get you laptop checked by a professional for servicing (if required). I believe immediate action is required to prevent any damage to your machine and data.
Hope it Helps! Let me know if i could be of any further assistance.
CreativeTECH
May 02, 2011 | Computers & Internet
My acer aspire 8930 9600m gt gpu keeps overheating what is the problem
2. Clean the fan and heat sink (thermal module). Click here for laptop disassembly instructions and refer to
CreativeTECH
Apr 16, 2011 | Acer Aspire AS5252V333 Notebook
I was running the program "windon Defender" on it and walked away. When I returned the computer was off and wasn't turn back on.
The Windows Defender Application is the Antivirus Software which will be pre-installed with the Windows Operating System(Windows Vista, Windows 7).
The Computer will always Shut down after any Windows Updates or any Operating System Updates are downloaded and installed.
If you are connected to the Internet and running Windows Defender, the Computer will automatically download the Updates for the Windows Defender Application.
Once the Updates are downloaded and installed, the Computer will prompt for a shut down.
The count down will be for 10 seconds.
After 10 seconds, the Computer will install the downloaded Updates and shut down.
This might be the reason for the Computer to shut down while using the Windows Defender.
If the Computer still shuts down randomly, the issue might be due to overheating.
All the Processors in Notebooks are designed to shut down automatically, if there is any overheating issues.
The overheating issue mainly occurs due to the malfunction of the Cooling fan.
If the Computer shuts down frequently, the issue might be due to the above factors.
It would be better to get the Unit examined at the Service Center.
Jun 22, 2010 | Acer (56.04145.901) (5604145901) Power...
Upgrade needed?
Well, i took a look whaats on your Acer, you definetly need to upgrade your graphic card, and u need a lot more memory.
The graphic card u need is an APG 8X card, make sure that the new graphic card is a fast one coz your processor is a sempon, its like an intel celeron, not realy made for games.
The momory you have is 512mb, you have 2 slots and you can max have 2gb, i sugest you buy 2x1gb sticks, the memorytype is 184 Pin DIMMs 400MHz.
Here is the details for your pc:
http://www.dealtime.com/xPF-Acer-Acer-Aspire-T135-Desktop
Good luck
Dec 06, 2008 | Acer (AST135-U-S3100) PC Desktop
Read disk error occured during rebooting
The acer recovery software sometimes has it's glitches. The CD might be fine, its just the data that wa written to the disk @ time of recovery creation was corrupt at some point.
If your machine shuts down randomly there can be only 3 possible solutions to this one:
  1. Your battery from your laptop has an issue. Try letting the laptop run on AC power ONLY.
  2. Your CPU is overheating, caused by a broken or unresponsive CPU heat sink fan, which causes your pc to shutdown (will always auto- shutdown at a certain temperature to prevent damage to the CPU. Check if you can feel "air" coming out of your laptop, suppose to be a hatched outlet at the side or at the back or on the top cover.
  3. You have a Virus that is shutting down the pc when it wants to. NO Operating system issue can cause your PC to shutdowb; only a virus can do that.
Summary, check your battery, check if your CPU fan is running, and make a virus scan (if the pc doesnt shut down). Remember to make a backup of your DATA, cause Acer (i dont think they will) don't do backups. Waranty on Acers is usually 3 years, depending on the country. So they should replace and repair, everything.
Apr 17, 2008 | Computers & Internet
CPU fan not working
you need to check your power supply if this is okay you need to replace the cpu fan. the cause of shutting down is the overheating of your cpu
Jan 06, 2008 | Acer Veriton 5200D PC Desktop
Acer AspireT135 (AST135US3302) PC Desktop Logo
394 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
