Question about The Computers & Internet
My 730 does not read my bernina usb. Gives me an error message to save current motif and the computer memory has nearly reached its limit, switch off and on to continue. But nothing helps.
    New Friend:
  • 30 Answers
Need to make space on harddrive. run diskcleaner
Posted on Jan 10, 2018
pankaj_dic
  • 1252 Answers
SOURCE: DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
hi
is it working some times back on your pc
when it is connected to your pc and power on, check the usb status some times the port become disabled
or
yes if it is then you restore your pc back to the date when its working fine to do this go to program - accessories - system tools-system restore option
Posted on Oct 03, 2008
  • 64 Answers
SOURCE: I have a multipass 730
1) Press Menu-Copy-# to enter SERVICE MODE
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
HTH
Posted on Oct 27, 2008
daddykevin13
  • 11 Answers
SOURCE: ''USB: Function not allowed''
Are you dragging and dropping your files into the RECEIVED folder first? If not, you need to. From there, the phone should open up the files.
Posted on Feb 18, 2009
  • 171 Answers
SOURCE: tomtom 730 doesn't switch on!
Hopefully all you need to do is a soft reset. To do this use a streightened paper clip and insert it into the small round hole marked reset on the bottom of your tt. Gently press the reset button in until you feel a click. Hold the reset button in for 20 seconds. Hope this does the job.
Posted on Jun 08, 2009
SOURCE: maximum limit applications reached ( LG cookies)
When you see that push the middle button. then tap the purple arrow in the top right corner and hit end all. I'm still trying to figure out a way to to allow more applications. But it's certainly better than having to turn your phone off. hope this helped it's my first comment :^)
Posted on Oct 22, 2009
My 730 embroidery message came up after it would not download what I had on my stick please save your currant motif your embroidery computer has nearly reached its limit. What does this mean
usually this means you are out of memory or the stick has failed those sticks only can be used so many times and then they need to be replaced in some cases they can get damaged also
Feb 03, 2018 | The Computers & Internet
Error message asking for chip to be formatted but will loose all pix if I do How can I save all my pix if I try to download it gives me there is nothing on memory card
Try reading the card on a computer via USB card reader,if that works download the pictures and then format the card.
Nov 21, 2016 | Pix Cameras
I just bought a 730 Bernina sewing and embroidery system. I just tried to send design to embroidery machine and got the message I have no memory left. How can I add memory?
My suggestion is to transfer unused designs onto a USB stick or connect your sewing machine to your computure and save them.Then you can delele them and have enough space to put additional designs on your machine.You can call your dealer and ask, but I dont think it can be done without sending it back to the manufactor. If it can be done it would know doubt be fairly expensive.
Nov 20, 2014 | Bernina Sewing Machines
With embroidery card inserted into module, no motifs appear on the display screen.
Here are two other possibilities other than electrical problems with your Bernina. There are embroidery design cards that were made for the 200 & 730 that simply do not work in a 180. There is nothing marked on the card or the packaging that will tell you what model machine the card will work in. I sold a bunch of my design cards on eBay last winter and I tested all of them in both a 730 and a 180 before making the ad discription. I found that most of the design cards worked in the 180 & 730, but there were a few that only worked in the 730. So if your design card is one of those that won't work in a 180, that could be your problem.
You did not say if you have other design cards that do work or there is only one you tried. Possibly the card itself is bad.
A static shock to the card could possibly damage it.
So if you take your machine to a dealer to have it looked at, take your design card along.
The 180's memory for storing designs is located in the embroidery module, not the machine itself. If that memory is filled up with other designs this can cause a problem.
So your problem is most likely with the design card or with the embroidery module. Should you need to get another embroidery module, that module needs to be the same version number as your machine or it will not work. I have a. video posted on YouTube that shows you how to check the version number of your machine and module. That information is in my "Bernina check hours 165, 170, 180, 185" video. Put that in the YouTube search box and you will find my video. Plus I have other helpful Bernina videos posted.
Aug 14, 2014 | Bernina Artista 180
Bernina Artista 200. Recently upgraded software to Version 7. Now my machine will not recognize my Bernina Mini CD drive or USB stick. The area on the machine itself that shows the "plug" for the...
You will need to find who is the maker of the CD player and what model it is then do a internet search for the newest driver, then install it on your PC.
Jul 18, 2014 | Bernina artista 200
Bernina 730 artista: error message Main motor doesn't most Pos speed
Try going to this link, it may help you.
http://www.bernina.com/en-US/SupportData/BERNINA-Nah-und-Stickmaschinen/artista/Manuals/032131-70-04_0509_a730_EN
Jan 25, 2014 | Bernina Sewing Machines
How do I get memory?
Hi do you have the USB port on the side of your sewing machine? If so, you can plug in a USB stick. You transfer your designs from the computer to the USB thumb drive. Then plug in the USB and you get your designs. I use a sandisk 8th stick called cruzer blade. Buy it cheap on eBay or at staples. I know this USB flash drive works but you can try others as well. Don't buy the bernina USB stick it is a ripoff.
Sep 04, 2012 | Bernina artista 200
Bernina 730 sewing machine. The memory in the machine has limited capacity.
According to the Bernina website (right side of page,under "key features"), the machine has a USB port. Presumably, one could plug in a USB drive and expand the memory of the machine.
Click here to go to site. Then click "USB Interface and Bernina USB Memory stick"
Mar 27, 2011 | Computers & Internet
My sony digital camera model dsc w 220 is not working properly. There is a problem when that one getting 95 photos it shows file error, memory stick duo formatting is error. please just to guide to rectify...
Sounds memory stick is bad, try another memory stick in camera.
Current memory stick got storage problem on some specific capacity and gives error on reaching that limit. Buy another memory stick and check.
Jul 09, 2009 | Sony Cameras
Computers & Internet Logo
85 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
